Running nixos-rebuild switch in ci/cd with github actions on self hosted runner
Hi I’m quite new to Nix and NixOS, I’m going a bit crazy trying to implement a CI/CD workflow to deploy a simple Go Fiber API to a VM running NixOS. The VM has a self hosted github runner installed with the following config:
fel-master-api-01 = {
  user = "some-user";
  workDir = "/home/some-user/fel-master-api-runner";
  name = "fel-master-api-runner";
  tokenFile = "/root/api.github.token";
  url = "https://github.com/private-repo-url";
  extraLabels = ["fel-master-api-runner" "160"];
  replace = true;
  extraPackages = [
    pkgs.go
    pkgs.sudo
    pkgs.nixos-rebuild
  serviceOverrides = {
    ProtectHome = false;
    NoNewPrivileges = false;
Most steps execute properly, including building the go binary, which I then I have defined as a the ExecStart to a service
systemd.services.fel-master-api = {
  description = "FEL Master API Service";
  after = [ "network.target" ];
  serviceConfig = {
    ExecStart = "/home/some-user/fel-master-api-runner/fel-master-api/fel_master_api";
    Restart = "always";
    User = "some-user";
    EnvironmentFile = "/home/some-user/fel-master-api-runner/fel-master-api/.env";
    WorkingDirectory = "/home/some-user/fel-master-api-runner/fel-master-api";
However to get this working theoretically, the final step of my workflow should be
 - name: Rebuild
        run: echo ${{ secrets.SUDO_PASSWORD }} | sudo -S  nixos-rebuild switch
        env:
          NIX_PATH: nixpkgs=/nix/var/nix/profiles/per-user/root/channels/nixos:nixos-config=/etc/nixos/configuration.nix
but I’ve run into a thousand errors, first of all the sudo and nixos-rebuild commands were not available from the shell the runner is running on apparently, so I added them as extraPackages in the config above. But now I’m getting "no new privileges" flag is set error.
I feel like im approaching this the wrong way or over/under complicating things, any suggestions?
First question: why are you running nixos-rebuild switch?
Basically trying to do anything in my power to restart the systemd service I’m hosting that runs my built Go binary
