Hi - fiddled around with my nix-darwin config and now I get this error:
error: builder for '/nix/store/djgk8cklcxjwiiazgsll2nw226xp0xkw-darwin-system-24.11.20241105.8c4dc69+darwin5.158198a.drv' failed with exit code 1;
last 7 log lines:
> In /nix/store/d5vrnjr93vqpd8bik95mqr6l79zv7ndl-darwin-system-24.11.20241105.8c4dc69+darwin5.158198a/activate line 1322:
> while read src; do
> ^--^ SC2162 (info): read without -r will mangle backslashes.
And I don’t even remotely have a clue on the where to start to look to sort that.
Ive think reverted back to the config that worked but still the same error - any pointers in the right direction is greatly appreciated.
The error itself is coming from shellcheck, which it does look like nix-darwin will run the activation script through–and it does look like this was merged about an hour before your post:
I don’t see while read src in the nix-darwin source, so I think the script it’s objecting to is coming in from either your local config or maybe some other module you’re including.
You can see some post-merge comments in the PR thread above for other people reporting the same issue and recommendations from maintainers.
