- So this is a post about how I successfully migrated to NixOS and set it up for development with: Python, PyTorch, CUDA, etc.
- Since for this scenario I find that documents, projects, and practices are scattered across the internet and many of them are not actually up-to-date, and for someone new to NixOS or Nix, setting things up can be challenging, I’m posting the way how I arrived at this conclusive solution in case someone else in the future might find this helpful.
- Here are the hardware and software environments I’m working with:
- I’m running NixOS, Nixpkgs unstable on an AMD 5600 CPU and NVIDIA RTX 3060 graphics card. I’m quite familiar with uv, which handles Python dependencies well, and since my collaborators might not all work on NixOS, I’ll stick with uv as I used to do. I think the community has come up with a really good solution: uv2nix, I find it really convenient to work on.
- So this is my flake.nix:
{ description = "WIP Analysis Project"; nixConfig = { extra-substituters = [ "https://nix-community.cachix.org" ]; extra-trusted-public-keys = [ "nix-community.cachix.org-1:0dq3bujKpuEPMCX6U4WylrUDZ9JyUG0VpVZa7CNfq5E=" ]; }; inputs = { nixpkgs.url = "github:NixOS/nixpkgs/nixpkgs-unstable"; flake-parts.url = "github:hercules-ci/flake-parts"; pyproject-nix = { url = "github:pyproject-nix/pyproject.nix"; inputs.nixpkgs.follows = "nixpkgs"; }; uv2nix = { url = "github:pyproject-nix/uv2nix"; inputs.pyproject-nix.follows = "pyproject-nix"; inputs.nixpkgs.follows = "nixpkgs"; }; pyproject-build-systems = { url = "github:pyproject-nix/build-system-pkgs"; inputs.pyproject-nix.follows = "pyproject-nix"; inputs.uv2nix.follows = "uv2nix"; inputs.nixpkgs.follows = "nixpkgs"; }; }; outputs = { self, nixpkgs, flake-parts, pyproject-nix, uv2nix, pyproject-build-systems, ... }@inputs: flake-parts.lib.mkFlake { inherit inputs; } { systems = [ "x86_64-linux" "aarch64-linux" ]; perSystem = { config, self', inputs', pkgs, system, ... }: let pkgs = import inputs.nixpkgs { inherit system; config = { allowUnfree = true; # cudaSupport = true; }; }; python = pkgs.python312; workspace = inputs.uv2nix.lib.workspace.loadWorkspace { workspaceRoot = ./backend; }; overlay = workspace.mkPyprojectOverlay { sourcePreference = "wheel"; }; editableOverlay = workspace.mkEditablePyprojectOverlay { root = "./backend"; }; customOverlay = self: super: { torch = super.torch.overrideAttrs (old: { nativeBuildInputs = (old.nativeBuildInputs or [ ]) ++ [ pkgs.cudaPackages.cudatoolkit pkgs.cudaPackages.cudnn pkgs.cudaPackages.libcusparse pkgs.cudaPackages.libcusparse_lt pkgs.cudaPackages.libcufile pkgs.cudaPackages.libnvshmem pkgs.cudaPackages.nccl ]; autoPatchelfIgnoreMissingDeps = (old.autoPatchelfIgnoreMissingDeps or [ ]) ++ [ "libcuda.so.1" ]; }); nvidia-cufile-cu12 = super.nvidia-cufile-cu12.overrideAttrs (old: { nativeBuildInputs = (old.nativeBuildInputs or [ ]) ++ [ pkgs.rdma-core ]; }); nvidia-nvshmem-cu12 = super.nvidia-nvshmem-cu12.overrideAttrs (old: { nativeBuildInputs = old.nativeBuildInputs ++ [ pkgs.openmpi pkgs.pmix pkgs.ucx pkgs.libfabric pkgs.rdma-core ]; }); nvidia-cusparse-cu12 = super.nvidia-cusparse-cu12.overrideAttrs (old: { nativeBuildInputs = (old.nativeBuildInputs or [ ]) ++ [ pkgs.cudaPackages.libnvjitlink ]; }); nvidia-cusolver-cu12 = super.nvidia-cusolver-cu12.overrideAttrs (old: { nativeBuildInputs = (old.nativeBuildInputs or [ ]) ++ [ pkgs.cudaPackages.libnvjitlink pkgs.cudaPackages.libcusparse pkgs.cudaPackages.libcublas ]; }); }; pythonSets = (pkgs.callPackage pyproject-nix.build.packages { inherit python; }).overrideScope ( pkgs.lib.composeManyExtensions [ pyproject-build-systems.overlays.wheel overlay customOverlay ] ); in { devShells.default = let pythonSet = pythonSets.overrideScope editableOverlay; virtualenv = pythonSet.mkVirtualEnv "wip-analysis-dev" workspace.deps.all; in pkgs.mkShell { packages = [ virtualenv pkgs.uv pkgs.ruff pkgs.cudaPackages.cudatoolkit pkgs.cudaPackages.cudnn pkgs.cudaPackages.cuda_nvcc ]; env = { UV_NO_SYNC = "1"; UV_PYTHON = pythonSet.python.interpreter; UV_PYTHON_DOWNLOADS = "never"; }; shellHook = '' echo "WIP-ANALYSIS-DEV" export REPO_ROOT=$(git rev-parse --show-toplevel) unset PYTHONPATH ''; }; packages.default = pythonSets.mkVirtualEnv "wip-analysis-env" workspace.deps.default; }; }; } - A few points I found really hard to overcome:
- On consumer-grade hardware, you should definitely set up caching, since compiling from source will take hundreds of years and ultimately leave nothing for you.
- Google Gemini or ChatGPT know very little about Nix or NixOS, Flake, or Python development on NixOS; I don’t trust them on general suggestions or solutions, But they really helped me find the Nix packages that provide the libraries needed for uv2nix to patch Python dependencies.
- So this is my workflow: first, initiate a Python project with uv (
nix shell nixpkgs#uv nixpkgs#python3thenuv init --app --package) and set up a flake.nix file in the project root then enter dev shell. - use
uv addto add dependencies anduv lockto update uv.lock file, and if using direnv,direnv reloadto re-evaluate the flake to make the new dependencies available in the environment. - a few more words about Using an Nvidia graphics card on NixOS, from my NixOS configuration:
{ config, pkgs, ... }: { imports = [ ./hardware-configuration.nix ]; networking.hostName = "Syy-PC"; # for Nvidia GPU services.xserver.videoDrivers = [ "nvidia" ]; hardware.graphics.enable = true; hardware.nvidia = { open = true; package = config.boot.kernelPackages.nvidiaPackages.stable; modesetting.enable = true; }; # Use CUDA Binary Cache nix.settings = { substituters = [ "https://nix-community.cachix.org" ]; trusted-public-keys = [ "nix-community.cachix.org-1:mB9FSh9qf2dCimDSUo8Zy7bkq5CX+/rkCWyvRCYg3Fs=" ]; }; nixpkgs.config.cudaSupport = true; # nixpkgs.overlays = [ # (self: super:{ # btop = super.btop.override { cudaSupport = true; }; # }) # ]; # This value determines the NixOS release from which the default # settings for stateful data, like file locations and database versions # on your system were taken. It‘s perfectly fine and recommended to leave # this value at the release version of the first install of this system. # Before changing this value read the documentation for this option # (e.g. man configuration.nix or on https://nixos.org/nixos/options.html). system.stateVersion = "25.05"; # Did you read the comment? } - Hope I didn’t get things wrong and this post helps someone out.
- Thanks and references:
- uv2nix and its hello-world flake template: uv2nix/templates/hello-world
- Nvidia - NixOS wiki (quite confused why the old nixos.wiki keeps showing up in web searching results instead of this new one.
- Questions about
nixpkgs.config.cudaSupport- Reddit - many posts in discourse.nixos.org, thank you guys!
Kudos for this guide.
By following it and adapting from GitHub - sepiabrown/denoising-diffusion-pytorch.nix: https://github.com/lucidrains/denoising-diffusion-pytorch nixified as well, I was able to successfuly set up a development environment for Pytorch + CUDA.
Nix fetchers sometimes felt awfully long for some libraries archive, I would assume that I was ratelimited by NVidia at some point.
Thank you very much for the guide!
Just to help any anyone coming here from the future. Right now, a few weeks before the 26.05 release, we have cuda ABI 13 in repositories, so we can need change from *-cu12 to *-cu13 for the PyPI packages.
Also, to work with torchvision we need to add:
torchvision = super.torchvision.overrideAttrs (old: {
# libc10.so, libtorch*.so live inside the torch wheel, not under a
# standard lib/ prefix, so autopatchelf can't find them automatically.
preFixup = (old.preFixup or "") + ''
addAutoPatchelfSearchPath ${self.torch}/${python.sitePackages}/torch/lib
to our customOverlay set.
