I want to sandbox user programs with default profiles and custom overrides
I guess a lot of existing profile collections like this one dont work on NixOS. The ${HOME} variables are treated as nix variables.
but here is a view of what I got:
programs.firejail = {
wrappedBinaries = {
# BROWSER
firefox = {
executable = "${lib.getBin pkgs.firefox}/bin/firefox";
profile = "${pkgs.firejail}/etc/firejail/firefox.profile";
environment.etc = {
# DEFAULTS
"firejail/firejail.config".text = ''
# Enable native notifications.
dbus-user.talk org.freedesktop.Notifications
# https://paramdeo.com/blog/sandboxing-firefox-using-firejail-for-private-browsing
# prevent app from getting new privileges (required for chromium)
force-nonewprivs yes
# hardened malloc
# https://wiki.archlinux.org/title/Firejail#Use_with_hardened_malloc
# https://github.com/NixOS/nixpkgs/blob/dbc1b2bd8cbce0ba11768151c7ce2c44fbd9dd89/nixos/modules/config/malloc.nix
env LD_PRELOAD='${pkgs.graphene-hardened-malloc}/lib/libhardened_malloc.so'
# Theme
env GTK_THEME=Breeze:dark
### hardening ###
# https://github.com/chiraag-nataraj/firejail-profiles/blob/fcd08dd32874f9fb5c856375659c434c922f156a/common.inc
blacklist /usr/local/bin
blacklist /usr/local/sbin
blacklist /boot
noexec ${HOME}
noexec /tmp
noexec ${RUNUSER}
private-tmp
read-only /tmp/.X11-unix
private-dev
nodvd
nosound
notv
nou2f
novideo
no3d
disable-mnt
private-opt emp
private-srv emp
shell none
seccomp
seccomp.block-secondary
noroot
caps.drop all
apparmor
nonewprivs
ipc-namespace
machine-id
nodbus
nogroups
# no internet
net none
netfilter
# block dynamic execution from memory
memory-deny-write-execute
# override existing one
"firejail/firefox.local".text = ''
# MISSING: applications portal
# Allow screensharing under Wayland.
dbus-user.talk org.freedesktop.portal.Desktop
# Allow inhibiting screensavers.
dbus-user.talk org.freedesktop.ScreenSaver
# from chiraag nataraj
# https://github.com/chiraag-nataraj/firejail-profiles/blob/fcd08dd32874f9fb5c856375659c434c922f156a/firefox.profile
ignore private-dev
ignore nou2f
ignore net none
ignore nodbus
ignore nosound
ignore novideo
ignore no3d
ignore memory-deny-write-execute
and so on.
It seems that using overrides configs are preferred over runtime arguments, cleaner to write.
Apparently, firejail.config is the place to set default values, not sure.
And there are some variables that are firejail specific I guess or not. I think they are used by the script in the repo, translating those to nix would be nice.
Also, where are the default profiles stored? whereis firejail didnt give me an etc directory where they are loaded.
