Hi all,
Currently running NixOS with Sway as my window manager. Recently I tried to run a nixos-rebuild switch
and was getting this error:
Failed assertions:
- The option definition `sound' in `/etc/nixos/configuration.nix' no longer has any effect; please remove it.
The option was heavily overloaded and can be removed from most configurations.
Previously in my configuration file I had:
sound = {
mediaKeys.enable = true;
If I comment out the sound option the config will build, but I don’t have use of the volume keys anymore. If I run wev
and press the media keys, they are not detected. Is there a known change I need to make? Please let me know if I need to share more of my config file.
