I am creating a derivation for a very simple package. The default.nix:
{ stdenv, fetchFromGitHub, pandoc, cgreen }:
stdenv.mkDerivation rec {
pname = "uint128";
version = "20200902";
src = fetchFromGitHub {
owner = "mkgvt";
repo = "uint128";
rev = "master";
sha256 = "0b3p8qka7yqq8km754k2dimjg9pxaf9mlnnzmvajvfw8xg6mh13k";
buildInputs = [
cgreen
pandoc
enableParallelBuilding = true;
doChecks = true;
checkTarget = "tests";
meta = with stdenv.lib; {
description = "A C library supporting operations on 128-bit unsigned integers";
homepage = "https://github.com/mkgvt/uint128/";
license = licenses.lgpl3;
platforms = platforms.unix;
maintainers = with maintainers; [ mkg ];
The overlay ~/.config/nixpkgs/config.nix that makes it available:
sources = import ./nix/sources.nix;
pkgs = import sources.nixpkgs {};
allowUnfree = true;
packageOverrides = pkgs: {
cgreen = pkgs.callPackage ./packages/cgreen {};
uint128 = pkgs.callPackage ./packages/uint128 {};
But when I attempt to build the package from ~/.config/nixpkgs/packages/uint128:
$ nix-build -E 'with import <nixpkgs> {}; callPackage ./default.nix {}'
/nix/store/pk6y1zb4bgfwm6iaax6pr54s4hh1dgx0-uint128-20200902.drv
building '/nix/store/pk6y1zb4bgfwm6iaax6pr54s4hh1dgx0-uint128-20200902.drv'...
unpacking sources
unpacking source archive /nix/store/dlb3x8cw1pr9lwh2j2f7z6z5wk36cczy-source
source root is source
patching sources
configuring
building
build flags: -j4 -l4 SHELL=/nix/store/9ywr69qi622lrmx5nn88gk8jpmihy0dz-bash-4.4-p23/bin/bash
gcc -MM -MF uint128_tests.d uint128_tests.c
pandoc -o LICENSE.html LICENSE.md
pandoc -o README.html README.md
gcc -fPIC -I. -Wall -Wpedantic -Wextra -c uint128_tests.c uint128.h
gcc -shared -o uint128_tests.so uint128_tests.o -lcgreen
sh: /usr/bin/env: not found
No tests found in 'uint128_tests.so'.
make: *** [Makefile:36: tests] Error 1
make: *** Waiting for unfinished jobs....
builder for '/nix/store/pk6y1zb4bgfwm6iaax6pr54s4hh1dgx0-uint128-20200902.drv' failed with exit code 2
error: build of '/nix/store/pk6y1zb4bgfwm6iaax6pr54s4hh1dgx0-uint128-20200902.drv' failed
Running the tests from within a pure environment works fine:
$ nix-shell --pure
$ make tests
Running "uint128_tests" (9 tests)...
"uint128_tests": 16 passes in 2ms.
Completed "uint128_tests": 16 passes in 2ms.
using this shell.nix:
pkgs = import <nixpkgs> {};
with pkgs;
mkShell {
buildInputs = [
cgreen
pandoc
Note: the package for cgreen is very similar and builds fine:
{ stdenv, fetchFromGitHub, cmake, asciidoctor }:
pname = "cgreen";
version = "1.3.0";
owner = "cgreen-devs";
repo = "cgreen";
rev = version;
sha256 = "07qgxcfb73dmgcxglxjxk1lj5zdb1x5wi022hr1hivj5psm6pvhr";
buildInputs = [
cmake
asciidoctor
patches = [ ./patch.nm-path ];
doChecks = true;
description = "A C & C++ unit tester and mock framework with a taste of BDD";
homepage = "https://cgreen-devs.github.io/";
license = licenses.isc;
To summarize, even though cgreen and uint128 package have very similar default.nix files and are both accessed through an overlay, the uint128 package can’t find /usr/bin/env and fails while the former does not fail. What am I doing wrong?
