I am trying to write an nvchad package as a way to learn nix and have got stuck. If you are not aware of nvchad you can think of it like a default set of configs for vim - installing is essentially done by installing neovim and then git clone https://github.com/NvChad/NvChad ~/.config/nvim --depth 1
and from there you configure it.
So far I have got Neovim configured and building using the following override:
{ lib, fetchFromGitHub, pkgs }:
packages = [
pkgs.ripgrep
pkgs.gcc
pkgs.sumneko-lua-language-server
pkgs.neovim-unwrapped.overrideAttrs (oldAttrs: rec {
pname = "neovim";
version = "0.7.0";
src = fetchFromGitHub {
owner = "neovim";
repo = "neovim";
rev = "v${version}";
sha256 = "03wh090acplj5kgrw87m6dh0rh5f71bg60s75qmqcsfjjwg1m1kr";
nativeBuildInputs = oldAttrs.nativeBuildInputs ++ [ pkgs.makeWrapper pkgs.git];
postInstall = ''
makeWrapper "$out/bin/nvim" "$out/bin/nvchad"
wrapProgram $out/bin/nvchad \
--prefix PATH : ${lib.makeBinPath packages}
My rough gameplan was to:
- Clone there repository somewhere (as per the nvchad instructions).
- Update the wrapper so that nvim launches using the
XDG_CONFIG_HOME
env var which would point at the nvchad directory cloned previously.
However I am unsure how to go about this so I’m reaching out to people more experienced in writing nix to get guidance on how to achieve this.
Looking forward to getting some guidance!
neovim 7 is on the Nixpkgs unstable branch, so you can use that instead of the override.
For nvchad, you can create a package using mkDerivation with neovim as an input and the nvchad repo as the src.
In the installPhase, copy everything in $src to something like $out/share/nvchad and symlink ${neovim}/bin/neovim to $out/bin/nvchad. Then, you can wrap nvchad and set the environment variable, (similar to how you set the PATH) to $out/share/nvchad.
Thanks @emmanuelrosa - makes much more sense.
I’ve attempted that but unfortunately it doesn’t look like you can call makeWrapper (or wrapProgram) on a symlinked file as I get the following error:
Builder called die: Cannot wrap '/nix/store/3wb0rjd0mdnn8b7a7bpkn9q128kq094g-nvchad-1.0/bin/.nvim' because it is not an executable file
nix derivation below:
{ stdenv, lib, pkgs, fetchFromGitHub}:
with lib;
stdenv.mkDerivation rec {
pname = "nvchad";
version = "1.0";
owner = "nvchad";
repo = "nvchad";
sha256 = "08p9y19z6cfxsilljypp0bd74mxhi60s0vk202js6i1v9ml0rqsw";
buildInputs = [
pkgs.makeWrapper
installPhase = ''
mkdir -p $out/bin
ln -s ${pkgs.neovim}/bin/neovim $out/bin/.nvim
makeWrapper "$out/bin/.nvim" "$out/bin/nvchad2"
installPhase = ''
mkdir -p $out/bin
makeWrapper "${pkgs.neovim}/bin/neovim" "$out/bin/nvchad2"
Might do the trick, since the wrapper just executes the binary in
question. But I know nothing about nvchad, and don’t understand why
you’re trying to symlink anything, so ignore me if this is silly
Here’s a working example is shown below. I only played with it a bit, so expect some things not to work.
In a nutshell, a nvim is executed with a disposable configuration, wherein nvchad is set up. The config directory is not persistent in order to allow the package to update nvchad while also persisting the user’s custom configuration.
nvchad.nix
{ nixpkgs ? <nixpkgs> }:
pkgs = import nixpkgs {} ;
pname = "nvchad";
version = "1.0";
src = pkgs.fetchFromGitHub {
owner = "nvchad";
repo = "nvchad";
launcher = pkgs.writeScript "nvchad" ''
export PATH="${pkgs.lib.makeBinPath [ pkgs.coreutils pkgs.neovim pkgs.ripgrep pkgs.fd pkgs.ueberzug ]}"
export XDG_CONFIG_HOME=$(mktemp -d)
# FIXME: Use the real XDG_CONFIG_HOME or fallback to $HOME/.config
mkdir -p $HOME/.config/nvchad
# Set up a disposable XDG_CONFIG_HOME
mkdir $XDG_CONFIG_HOME/nvim
ln -s ${src}/LICENSE $XDG_CONFIG_HOME/nvim/LICENSE
ln -s ${src}/README.md $XDG_CONFIG_HOME/nvim/README.md
ln -s ${src}/init.lua $XDG_CONFIG_HOME/nvim/init.lua
cp -r ${src}/lua $XDG_CONFIG_HOME/nvim/lua
chmod u+w $XDG_CONFIG_HOME/nvim/lua
ln -s $HOME/.config/nvchad $XDG_CONFIG_HOME/nvim/lua/custom
# Copy the initial user configuration, if it doesn't already exist.
cp -n ${src}/lua/chadrc.lua $HOME/.config/nvchad/
exec nvim "$@"
pkgs.stdenv.mkDerivation rec {
inherit src version pname;
installPhase = ''
mkdir -p $out/bin
ln -s ${launcher} $out/bin/nvchad
