Today I wanted to download an unpatched binary for an addon for a game that I play. I made a derivation that uses autopatchelf to link the libraries correctly, but there were two that were giving me a lot of trouble:
- libcrypto.so.1.0.0
- libssl.so.1.0.0
Both of these libraries are normally provided by openssl, but this binary in particular required some really outdated versions of them that are only still used by two packages in the entirety of nixpkgs.
Here’s the solution I found that worked:
# I genuinely can't believe that I actually need to do this.
robo3t_movedlibs = pkgs.robo3t.overrideAttrs (oldAttrs: rec {
installPhase = ''
runHook preInstall
mkdir -p $out/lib
tar -xzf $src
cp robo3t-${oldAttrs.version}-linux-x86_64-${oldAttrs.rev}/lib/libssl.so.1.0.0 $out/lib/
cp robo3t-${oldAttrs.version}-linux-x86_64-${oldAttrs.rev}/lib/libcrypto.so.1.0.0 $out/lib/
runHook postInstall
pkgs.stdenv.mkDerivation rec {
pname = "ddstats";
version = "0.6.10-181";
src = pkgs.fetchurl {
url = "https://github.com/lsaa/ddstats-rust/releases/download/v${version}/ddstats-rust-linux-x86_64.zip";
hash = "sha256-FlbmyvQNyV9s360oag9iRmctH+7jje0BlVpYrWDnza4="; # Make sure to replace this with the correct hash
unzip
autoPatchelfHook
robo3t_movedlibs
buildInputs = with pkgs; [
glibc
libgcc
gcc
zlib
xorg.libxcb
installPhase = ''
unzip $src
install -Dm755 ddstats-rust $out/bin/ddstats-rust
postInstall = ''
autoPatchelf $out/bin/ddstats-rust
In the robo3t override I had to move the two library files from their usual directory into $out/lib because that’s apparently just where autopatchelf looks by default. Then I used the package as a build input and it was able to find them.
There has got to be a better way to achieve this outcome right? Was there some way I could have told autopatchelf specifically where to look for those files in the package directory instead of having to override the package to move them around? Or maybe even some way to just download the libraries from somewhere outright using fetchurl or something?
