Suspend problem
Erm, are you sure you’re up-to-date and not on a weird mix of channels? The default stable kernel currently builds fine, which should be unrelated to actual hardware, and the rcu patch hasn’t been necessary for what feels like over a year now.
I’m currently seeing absolutely zero issues on a 4060ti, and was until it blew itself up on a 2070 super. This is all relevant config (any unset hardware.nvidia settings are deliberately left to their defaults):
hardware.nvidia = {
  package = config.boot.kernelPackages.nvidiaPackages.mkDriver {
    version = "565.77";
    sha256_64bit = "sha256-CnqnQsRrzzTXZpgkAtF7PbH9s7wbiTRNcM0SPByzFHw=";
    sha256_aarch64 = lib.fakeHash;
    openSha256 = "sha256-Fxo0t61KQDs71YA8u7arY+503wkAc1foaa51vi2Pl5I=";
    settingsSha256 = "sha256-VUetj3LlOSz/LB+DDfMCN34uA4bNTTpjDrb6C6Iwukk=";
    persistencedSha256 = lib.fakeHash;
  # This will no longer be necessary when
  # https://github.com/NixOS/nixpkgs/pull/326369 hits stable
  modesetting.enable = lib.mkDefault true;
  # Power management is nearly always required to get nvidia GPUs to
  # behave on suspend, due to firmware bugs.
  powerManagement.enable = true;
  # The open driver is recommended by nvidia now, see
  # https://download.nvidia.com/XFree86/Linux-x86_64/565.77/README/kernel_open.html
  open = true;
boot.kernelPackages = lib.mkForce pkgs.linuxKernel.packages.linux_xanmod;
565.77 is the latest driver, and actually a stable release, the whole “certified” thing is mostly aimed at commercial users AIUI.
YMMV of course, this is mostly for reference. However, there are loads of snippets out there, and many of them are bad advice like not using the open driver and not enabling the powermanagement daemon, which is exactly how you would get issues with sleep.
Yeah. Even before i forked the nixpkgs repo and such, i was still using the default channels and had tons of problems with getting the GPU working correctly.
Ill be honest though, ive not tried the new 565 drivers as ive been a bit gun shy about it. Ive never had a fun time when i mess with the NVIDIA drivers.
Ill give them a whirl though and see if they fixed some stuff.
Consider filing a nix bug, if you’re actually building vanilla nixpkgs you’ve hit some serious reproducibility holes.
Probably, but i’ve dealt with NVIDIA driver bullshit for so long on different distros that i hadnt really though about it given the proprietary nature of NVIDIA’s driverset. (until recently)
To correct tho, the default open source novo drivers DID work and did display and such, just at 30hz refresh and bad scaling and the kernel did compile. But it took some tweaking to get the NVIDIA drivers to build and work correctly.
The default kernel didnt build with the nvidia drivers, i tried probably about 25+ kernels before finally settling on zen1 6.8.9. Some of them built, most did not. Those that did often didnt work well or had some really annoying bugs. This kernel seems to work smoothly, the new kernels will fail when building the NVIDIA modules.
Maybe i just have really shit luck.
I am on driver version 565.77 as well.
I’m also having this problem with driver version 565.77. I’m on NixOS 24.11, and my GPU is a GeForce GTX 1060 3GT OC.
Update: I’m having similar problems with driver version 550.135 (production) on kernel versions 6.6 and 6.12, as well as driver version 570.86 on kernel version 6.13.
I got my nvidia system to behave correctly. It seems there is a bug in the driver and or gnome-shell which has been open a long while and not been fixed, causing the shell to try and interact with the driver after it has been suspended, leading to a kernel panic.
It looks to me like this was first documented online here: Trouble suspending with 510.39.01, Linux 5.16.0: Freezing of tasks failed after 20.009 seconds - #12 by devyn.cairns - Linux - NVIDIA Developer Forums
And someone implemented this as a nix expression here: Suspend/resume cycling on system resume - #12 by blablablerg
I’ve now been able to suspend/resume tens of times without hitting the hang.
I also had an additional problem that my machine was immediately waking up due to some misbehaviour of the logitech keyboard dongle. That’s documented here How does Solaar affect sleep/suspend and wakeup? · Issue #2893 · pwr-Solaar/Solaar · GitHub and Suspend/resume cycling on system resume - #17 by pwaller.
My relevant nixos config is currently:
  # Uncertain this is necessary but there are various reports it makes a difference.
  boot.kernelParams = [ "nvidia.NVreg_TemporaryFilePath=/var/tmp" ];
  boot.extraModulePackages = [ config.hardware.nvidia.package ];
  hardware.nvidia.package = config.boot.kernelPackages.nvidiaPackages.latest;
  hardware.nvidia.powerManagement.enable = true;
  hardware.nvidia.open = true;
  systemd = {
    # Uncertain if this is still required or not.
    services.systemd-suspend.environment.SYSTEMD_SLEEP_FREEZE_USER_SESSIONS = "false";
    services."gnome-suspend" = {
      description = "suspend gnome shell";
      before = [
        "systemd-suspend.service"
        "systemd-hibernate.service"
        "nvidia-suspend.service"
        "nvidia-hibernate.service"
      wantedBy = [
      serviceConfig = {
        Type = "oneshot";
        ExecStart = ''${pkgs.procps}/bin/pkill -f -STOP ${pkgs.gnome-shell}/bin/gnome-shell'';
    services."gnome-resume" = {
      description = "resume gnome shell";
      after = [
        "nvidia-resume.service"
      wantedBy = [
      serviceConfig = {
        Type = "oneshot";
        ExecStart = ''${pkgs.procps}/bin/pkill -f -CONT ${pkgs.gnome-shell}/bin/gnome-shell'';
This worked PERFECTLY for me! I have a 3080ti and I’ve tried every other solution I could find online. Thank you!
I’m excited that you got your system working! :tada: Thanks for sharing your configuration. When I pasted this stuff into my own config and tried to rebuild, I got a weird build error:
error: builder for ‘/nix/store/lrz8fdf2z0dmrswkgi1i0axnd8jxzrqw-nvidia-x11-565.77-6.15.3.drv’ failed with exit code 2
error: 1 dependencies of derivation ‘/nix/store/fk1b64q1d1hacdjw6fdafan3cj9119i1-etc.drv’ failed to build
error: 1 dependencies of derivation ‘/nix/store/xdzk161rl0asc49zqq2969ln2qm5i1kx-firmware.drv’ failed to build
error: 1 dependencies of derivation ‘/nix/store/cim9cyr3w57mja0vsglnwmp9vf070jw3-linux-6.15.3-modules.drv’ failed to build
error: 1 dependencies of derivation ‘/nix/store/blqi4x17qyva340dbb7if3f5za3av0s9-system-path.drv’ failed to build
error: 1 dependencies of derivation ‘/nix/store/gr6c3b9f641kjhqnpdmqr3a6lqmvfn8j-nixos-system-llonio-24.11.719113.50ab793786d9.drv’ failed to build
It seems like the build is triggering the compilation of some C code, which is producing compilation errors. Here’s the first error.
nvidia/nv-cray.c:26:10: fatal error: os-interface.h: No such file or directory
   26 | #include "os-interface.h"
compilation terminated.
I may not be able to do much more testing, because I’m planning to start a different project with the machine I’ve been experimenting with NixOS on, but I wanted to at least post what I’ve got.
