Here is the log: View paste IWVQ
nixos-version: 25.11.20250610.c9cb777 (Xantusia)
Configuration: GitHub - rachitve6h2g/NixDots: NixOS dotfiles and Home-Manager
The whole system is not building, IDK why.
in your flake you have
nixpkgs.url = "github:NixOS/nixpkgs";
is using the default branch which is the master branch of nixpkgs. you should use one of nixos-unstable, nixpkgs-unstable, nixos-25.05 instead like
note, the above won’t necessarily solve your issue
Oh, I didn’t know that. Do I have to do something similar for home-manager as well?
home-manager docs suggest what you are currently doing in your flake, so no need to change it.
But if you want to use nixos stable (currently nixos-25.05) then I suggest doing this
nixpkgs.url = "github:nixos/nixpkgs/nixos-25.05";
home-manager.url = "github:nix-community/home-manager/release-25.05";
home-manager.inputs.nixpkgs.follows = "nixpkgs";
