System with Minimal XMonad Configuration Fails
I’m unable to successfully install a default, minimal xmonad system using nixos 24.11.
Expected behavior: xmonad works out of the box as per XMonad - NixOS Wiki
Actual behavior: system boots to xmonad, but configuration file fails to compile
My system definition is a flake.nix:
  description = "A simple NixOS flake";
    nixpkgs.url = "github:NixOS/nixpkgs/nixos-24.11";
    kmonad = {
      url = "git+https://github.com/kmonad/kmonad?submodules=1&dir=nix";
  outputs = { self, nixpkgs, kmonad, ... }@inputs: {
    nixosConfigurations.myhost = nixpkgs.lib.nixosSystem {
      system = "x86_64-linux";
      modules = [
        ./configuration.nix
        kmonad.nixosModules.default
that invokes a configuration.nix (whose xmonad definition is taken from the wiki) (I commented out everything irrelevant):
{ config, lib, pkgs, ... }:
  #enable flakes
  #hardware config import
  #boot loader/lvm stuff
  services.xserver = {
    windowManager.xmonad = {
      enableConfiguredRecompile = true;
      config = builtins.readFile ./xmonad.hs;
      enableContribAndExtras = true;
  #libinput stuff
  #network/timezone/locale stuff
  #kmonad service
  #syncthing stuff
  #sound stuff
  #emacs stuff
  #user definition
  #system packages (no ghc, xmonad, or haskell-related packages)
  programs.direnv.enable = true;
  #system state version suff
with an xmonad.hs:
import XMonad
import XMonad.Config.Desktop
main = xmonad desktopConfig
        { terminal = "ghostty"
The system boots to a display manager and then xmonad, but journalctl -t xmonad shows errors:
Mar 03 17:34:18 myhost xmonad[1390]: XMonad is recompiling and replacing itself with another XMonad process because the current process is called "xmonad" but the compiled configuration should be called "xmonad-x86_64-linux"
Mar 03 17:34:18 myhost xmonad[1390]: XMonad will use ghc to recompile, because neither "/home/myuser/.config/xmonad/build" nor "/home/myuser/.config/xmonad/stack.yaml" exists.
Mar 03 17:34:18 myhost xmonad[1390]: XMonad skipping recompile because it is not forced (e.g. via --recompile), and neither xmonad.hs nor any *.hs / *.lhs / *.hsc files in lib/ have been changed.
Mar 03 17:34:19 myhost xmonad[1390]: xmonad: X11 error: BadAtom (invalid Atom parameter), request code=18, error code=5
Mar 03 17:34:26 myhost xmonad[1539]: xmonad is /run/current-system/sw/bin/xmonad
Mar 03 17:34:26 myhost xmonad[1541]: XMonad will use ghc to recompile, because neither "/home/myuser/.config/xmonad/build" nor "/home/myuser/.config/xmonad/stack.yaml" exists.
Mar 03 17:34:26 myhost xmonad[1541]: XMonad recompiling (forced).
Mar 03 17:34:27 myhost xmonad[1541]: Errors detected while compiling xmonad config: /home/myuser/.config/xmonad/xmonad.hs
Mar 03 17:34:27 myhost xmonad[1541]: $ /nix/store/09lshns3b6wlmz6wzpkik8rp9w16fd5b-ghc-9.6.6-with-packages/bin/ghc --make xmonad.hs -i -ilib -fforce-recomp -main-is main -v0 -outputdir /home/myuser/.cache/xmonad/build-x86_64-linux -o /home/myuser/.cache/xmonad/xmonad-x86_64-linux
Mar 03 17:34:27 myhost xmonad[1541]: xmonad.hs:1:1: error:
Mar 03 17:34:27 myhost xmonad[1541]:     Could not load module ‘XMonad’
Mar 03 17:34:27 myhost xmonad[1541]:     It is a member of the hidden package ‘xmonad-0.17.2’.
Mar 03 17:34:27 myhost xmonad[1541]:     You can run ‘:set -package xmonad’ to expose it.
Mar 03 17:34:27 myhost xmonad[1541]:     (Note: this unloads all the modules in the current scope.)
Mar 03 17:34:27 myhost xmonad[1541]:     Use -v (or `:set -v` in ghci) to see a list of the files searched for.
Mar 03 17:34:27 myhost xmonad[1541]:   |
Mar 03 17:34:27 myhost xmonad[1541]: 1 | import XMonad
Mar 03 17:34:27 myhost xmonad[1541]:   | ^^^^^^^^^^^^^
Mar 03 17:34:27 myhost xmonad[1541]: xmonad.hs:2:1: error:
Mar 03 17:34:27 myhost xmonad[1541]:     Could not load module ‘XMonad.Config.Kde’
Mar 03 17:34:27 myhost xmonad[1541]:     It is a member of the hidden package ‘xmonad-contrib-0.18.0’.
Mar 03 17:34:27 myhost xmonad[1541]:     You can run ‘:set -package xmonad-contrib’ to expose it.
Mar 03 17:34:27 myhost xmonad[1541]: 2 | import XMonad.Config.Kde
Mar 03 17:34:27 myhost xmonad[1541]:   | ^^^^^^^^^^^^^^^^^^^^^^^^
Mar 03 17:34:27 myhost xmonad[1541]: xmonad.hs:3:1: error:
Mar 03 17:34:27 myhost xmonad[1541]:     Could not load module ‘XMonad.StackSet’
Mar 03 17:34:27 myhost xmonad[1541]: 3 | import qualified XMonad.StackSet as W -- to shift and float windows
Mar 03 17:34:27 myhost xmonad[1541]:   | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Mar 03 17:34:27 myhost xmonad[1541]: Please check the file for errors.
Mar 03 17:34:27 myhost xmonad[1552]: Warning: Missing charsets in String to FontSet conversion
The default xmonad terminal is unchanged, and M-q (xmonad --recompile) breaks with the same compiler errors from the above log. Thanks for reading
try installing something like xfce and doing this from there
maybe it’s happening because xmonad can’t replace itself
I’ve been using GNOME on NixOS (for about a year); when I update my system configuration from within GNOME to use xmonad (configuration.nix shown above) the system successfully restarts X11 but then when I boot into the new system, it’s clear my config hasn’t been compiled into xmonad (because the default terminal is unchanged)
There is the similar issue on github, and it’s resolved.
Try restarting the display-manager service, maybe it will help
