Hi every one
I recently try to install Nixos on my Thinkpad T440p but the Intel Corporation Wireless 7260 isn’t detected in the NetworkManager interface.
I use Nixos 18.09 on stable channel with a KDE Desktop.
I try different things like :
boot.kernelModules = [ "kvm-intel" "iwlwifi" ];
or
boot.extraModprobeConfig = ''
options iwlwifi bt_coex_active=0 power_save=Y
options iwldvm force_cam=N
but anything works.
Thanks for your help
Regards
Hey Vskilet,
this might not entirely address your problem, but did you hear already
about nixos-hardwaren [0]? It’s a collection of NixOS modules and the
T440p is already packaged there.
Maybe the module helps with your WiFi (I don’t understand it enough for
that) and if not, you could eventually bring your succesful solution
upstream there.
[0] https://github.com/NixOS/nixos-hardware
c0bw3b
November 1, 2018, 10:33pm
3
Solved by setting this in configuration.nix :
hardware.enableRedistributableFirmware = true
opened 09:52AM - 01 Nov 18 UTC
closed 05:51PM - 01 Nov 18 UTC
## Issue description
I installed Nixos 18.09 on a Thinkpad T440p with the stabl… e channel but my wifi card isn't detected.
with `lspci` I can see the interface but not with an `ip a`.
I tried different things like :
boot.kernelModules = [ "iwlwifi" ];
### Steps to reproduce
# lscpi
03:00.0 Network controller: Intel Corporation Wireless 7260 (rev bb)
# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s25: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 68:f7:28:a7:d8:45 brd ff:ff:ff:ff:ff:ff
## Technical details
My system infos :
- system: `"x86_64-linux"`
- host os: `Linux 4.14.76, NixOS, 18.09.932.09195057114 (Jellyfish)`
- multi-user?: `yes`
- sandbox: `yes`
- version: `nix-env (Nix) 2.1.1`
- nixpkgs: `/nix/var/nix/profiles/per-user/root/channels/nixos`
