I’m using Latex with a shell.nix, which I pieced together from some examples. I tried to add the mathdesign package following the “instruction” in Nixos Search Packages. The shell builds without error, but when I try to usepackage{mathdesign} I get the error that mathdesign.sty was not found. Does anyone have an example of a shell.nix or flake.nix that allows me to add additional packages properly? Thanks. (I’m just trying to get garamond font, and that is apparently where it lives.)
FWIW, I’m using:
with import <nixpkgs> {};
basePackages = with texlive; [
combined.scheme-medium
myvscode = pkgs.vscode-with-extensions.override {
vscodeExtensions = with pkgs.vscode-extensions; [
equinusocio.vsc-material-theme
equinusocio.vsc-material-theme-icons
james-yu.latex-workshop
vscodevim.vim
vscode-extensions.valentjn.vscode-ltex
mytex = texlive.withPackages (ps: [ ps.mathdesign ]);
in mkShell {
buildInputs = basePackages ++ [myvscode mytex];
I think your combined.scheme-medium
is actually overwritting mytex
. They are two separate texlive “instances”. Simply having them both in buildInputs
will not compose them together.
As per the nixpkgs manual, you can either use:
texlive.combine { inherit (texlive) scheme-medium mathdesign; }
; or
texliveMedium.withPackages (ps: [ps.mathdesign])
I like the second one better, so here’s how you can tweak your existing .nix to use it:
pkgs = import <nixpkgs> { config.allowUnfree = true; };
vscodeExtensions = (with pkgs.vscode-extensions; [
vscodevim.vim
mytex = pkgs.texliveMedium.withPackages (ps: [ ps.mathdesign ]);
pkgs.mkShell {
buildInputs = [ myvscode mytex ];
Also, try to avoid with
as it makes things more complicated by mixing scopes. I removed the top level with
and enclosed the vscode-extensions one to make things clearer.
Thanks a lot. That’s the guidance I need.
I still get the error mathdesign.sty not found
when I \usepackage[urw-garamond]{mathdesign}
. I tried both approaches without a build error, it just can’t find the sty module.
Hmmm, can you try texliveFull
? If it doesn’t work, then the problem lies elsewhere.
Just tried it and I’m afraid it doesn’t work with full either.
Getting back to this, finally. It seems my problem is related to neovim, not latex per se. I wasn’t actually using vscode for writing my latex, it just was in the flake because I thought I’d try it sometime. Lo and behold, VS Code had no problem finding the additional packages. So I need to figure out how to make neovim aware of them. Meanwhile I’m using VS Code if I need additional packages.
