Trouble pinning package with home-manager and flakes
Hello, I’m using home-manager as flake to configure my setup (GitHub - nxy7/dotfiles). I was using helix editor from forked version for a long time, now when I tried pinning it back to latest changes on master branch I’m receiving some errors. I can build helix repo with nix build github:helix-editor/helix just fine, so I concluded it has to be something with the way i setup my home-manager.
I’d be glad for any guidance, examples of non nix-os configurations using flakes, home-manager and pinning versions of package or if someone has enough spare time, I’d be glad for pointing errors in my setup (link above).
Here are error logs from nix run . switch -- --flake . command.
error:
       … while evaluating the attribute 'buildCommand' of the derivation 'home-manager-generation'
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/pkgs/stdenv/generic/make-derivation.nix:302:7:
          301|     // (lib.optionalAttrs (attrs ? name || (attrs ? pname && attrs ? version)) {
          302|       name =
          303|         let
       … while evaluating the attribute 'text' of the derivation 'activation-script'
          302|       name =
          303|         let
       … while evaluating call site
       at «none»:0: (source not available)
       … while calling 'mkCmd'
       at /nix/store/jmbwf2vqfidi4bs48f6zsdx2pdchkm5f-source/modules/home-environment.nix:657:17:
          656|       let
          657|         mkCmd = res: ''
          658|             _iNote "Activating %s" "${res.name}"
       … while evaluating the attribute 'data'
       at /nix/store/jmbwf2vqfidi4bs48f6zsdx2pdchkm5f-source/modules/lib/dag.nix:89:37:
           88|     in if sorted ? result then {
           89|       result = map (v: { inherit (v) name data; }) sorted.result;
           90|     } else
       at /nix/store/jmbwf2vqfidi4bs48f6zsdx2pdchkm5f-source/modules/lib/dag.nix:83:9:
           82|         name = n;
           83|         data = v.data;
           84|         after = v.after ++ dagBefore dag n;
       … while calling 'g'
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/attrsets.nix:595:19:
          594|           g =
          595|             name: value:
          596|             if isAttrs value && cond value
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/attrsets.nix:598:20:
          597|               then recurse (path ++ [name]) value
          598|               else f (path ++ [name]) value;
          599|         in mapAttrs g;
       … while calling anonymous lambda
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:274:72:
          273|           # For definitions that have an associated option
          274|           declaredConfig = mapAttrsRecursiveCond (v: ! isOption v) (_: v: v.value) options;
          275|
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:752:9:
          751|     in warnDeprecation opt //
          752|       { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
          753|         inherit (res.defsFinal') highestPrio;
       … while evaluating the option `home.activation.installPackages.data':
       … while evaluating the attribute 'mergedValue'
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:787:5:
          786|     # Type-check the remaining definitions, and merge them. Or throw if no definitions.
          787|     mergedValue =
          788|       if isDefined then
       … while evaluating the attribute 'values'
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:781:9:
          780|       in {
          781|         values = defs''';
          782|         inherit (defs'') highestPrio;
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:880:7:
          879|     in {
          880|       values = concatMap (def: if getPrio def == highestPrio then [(strip def)] else []) defs;
          881|       inherit highestPrio;
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:767:17:
          766|         # Process mkMerge and mkIf properties.
          767|         defs' = concatMap (m:
          768|           map (value: { inherit (m) file; inherit value; }) (builtins.addErrorContext "while evaluating definitions from `${m.file}':" (dischargeProperties m.value))
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:767:28:
       … while evaluating definitions from `/nix/store/jmbwf2vqfidi4bs48f6zsdx2pdchkm5f-source/modules/home-environment.nix':
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:768:137:
          769|         ) defs;
       … while calling 'dischargeProperties'
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:839:25:
          838|   */
          839|   dischargeProperties = def:
          840|     if def._type or "" == "merge" then
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:592:44:
          591|       defnsByName' = byName "config" (module: value:
          592|           [{ inherit (module) file; inherit value; }]
          593|         ) configs;
       … while evaluating the attribute 'passAsFile' of the derivation 'home-manager-path'
          302|       name =
          303|         let
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/pkgs/build-support/buildenv/default.nix:77:5:
           76|     # XXX: The size is somewhat arbitrary
           77|     passAsFile = if builtins.stringLength pkgs >= 128*1024 then [ "pkgs" ] else [ ];
           78|   }
       … while calling 'g'
          594|           g =
          595|             name: value:
          599|         in mapAttrs g;
          275|
       … while evaluating the option `home.packages':
          787|     mergedValue =
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:789:59:
          789|         if all (def: type.check def.value) defsFinal then type.merge loc defsFinal
          790|         else let allInvalid = filter (def: ! type.check def.value) defsFinal;
       … while calling 'merge'
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/types.nix:491:20:
          490|       check = isList;
          491|       merge = loc: defs:
          492|         map (x: x.value) (filter (x: x ? value) (concatLists (imap1 (n: def:
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/types.nix:492:35:
          493|           imap1 (m: def':
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/lists.nix:117:29:
          116|   */
          117|   imap1 = f: list: genList (n: f (n + 1) (elemAt list n)) (length list);
          118|
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/lists.nix:117:32:
          116|   */
          118|
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/types.nix:493:21:
          494|             (mergeDefinitions
       … while evaluating the attribute 'optionalValue'
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:799:5:
          798|
          799|     optionalValue =
          800|       if isDefined then { value = mergedValue; }
          780|       in {
          879|     in {
       … while evaluating definitions from `/nix/store/jmbwf2vqfidi4bs48f6zsdx2pdchkm5f-source/modules/programs/helix.nix':
          769|         ) defs;
          838|   */
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/types.nix:497:38:
          496|               elemType
          497|               [{ inherit (def) file; value = def'; }]
          498|             ).optionalValue
       … while calling 'g'
          594|           g =
          595|             name: value:
          599|         in mapAttrs g;
          275|
       … while evaluating the option `programs.helix.package':
          787|     mergedValue =
          780|       in {
          879|     in {
       … while evaluating definitions from `/nix/store/6hrhd5n8sdlarhz86payr6fk9iizmrig-source/home.nix':
          769|         ) defs;
          838|   */
          593|         ) configs;
       at /nix/store/w92n9zhbizs1l3vy1x9aj2j9wc6xscld-source/lib/modules.nix:505:44:
          504|       context = name: ''while evaluating the module argument `${name}' in "${key}":'';
          505|       extraArgs = builtins.mapAttrs (name: _:
          506|         builtins.addErrorContext (context name)
       … while evaluating the module argument `helix-master' in "/nix/store/6hrhd5n8sdlarhz86payr6fk9iizmrig-source/home.nix":
       … while evaluating the attribute 'helix-master'
       at /nix/store/6hrhd5n8sdlarhz86payr6fk9iizmrig-source/flake.nix:25:22:
           24|             extraSpecialArgs = {
           25|               inherit pkgs nci helix-master system;
           26|               username = name;
       at «string»:23:25:
           22|           inputs = builtins.mapAttrs
           23|             (inputName: inputSpec: allNodes.${resolveInput inputSpec})
           24|             (node.inputs or {});
       at «string»:10:13:
            9|     builtins.mapAttrs
           10|       (key: node:
           11|         let
       at «string»:45:21:
           44|
           45|           outputs = flake.outputs (inputs // { self = result; });
           46|
       … while calling 'outputs'
       at /nix/store/d9b7qfqzjbx61kdavq3yw7vjx6y25m41-source/flake.nix:17:13:
           16|
           17|   outputs = inputs@{ nixCargoIntegration, ... }:
           18|     nixCargoIntegration.lib.makeOutputs {
       at «string»:23:25:
       at «string»:10:13:
           10|       (key: node:
           11|         let
       at «string»:45:21:
           44|
           46|
       at /nix/store/hjnfl11gnd6l34j5ry1z4kw14fwdmrq4-source/flake.nix:40:13:
           39|
           40|   outputs = {parts, ...} @ inp: let
           41|     l = inp.nixpkgs.lib // builtins;
       at /nix/store/hjnfl11gnd6l34j5ry1z4kw14fwdmrq4-source/flake.nix:58:5:
           57|   in
           58|     parts.lib.mkFlake {inputs = inp;} {
           59|       imports = [flakeModule];
       … while calling 'mkFlake'
       at /nix/store/jmf4y5avd2x2cqgy5gn66lngkba78ll0-source/lib.nix:138:21:
          137|
          138|     mkFlake = args: module:
          139|       let
       at /nix/store/jmf4y5avd2x2cqgy5gn66lngkba78ll0-source/lib.nix:145:16:
          144|         mod = lib.setDefaultModuleLocation loc module;
          145|         eval = flake-parts-lib.evalFlakeModule args mod;
          146|       in
       … while calling 'evalFlakeModule'
       at /nix/store/jmf4y5avd2x2cqgy5gn66lngkba78ll0-source/lib.nix:90:7:
           89|     evalFlakeModule =
           90|       args@
           91|       { inputs ? self.inputs
       error: attribute 'throwIf' missing
       at /nix/store/jmf4y5avd2x2cqgy5gn66lngkba78ll0-source/lib.nix:2:4:
            1| { lib }:
            2| let
            3|   inherit (lib)
Got it working by using overlay instead of home-manager package option
