Typhon: Nix-based continuous integration
Hello everyone! Here is a little update on what has been going on:
But most importantly we opened a Zulip instance, where you can come to ask for help and where I will probably continue posting semi-regular updates like this one.
I am not sure that I will keep this thread updated unless there is some big piece of news like a first release, as I don’t want to create spam.
Thank you everyone for the feedback, and I hope I will discuss the design of Typhon with some of you on Zulip!
Heya!
This project is super cool, thanks for sharing this.
Is there any way to trigger builds via a URL and fetch builds via SSH? That way it can be used with Gitolite or pure Git via a hook.
@Marcc The webhook system in Typhon just exposes an API endpoint for each project and passes any POST request that is sent to it to a user-defined action that can in turn send commands to Typhon to create jobsets. Thus as long as you can send POST requests from your forge, you can trigger builds automatically! (in theory… atm you’ll have to do some manual work because of Evaluation is not triggered on new jobsets · Issue #3 · typhon-ci/typhon · GitHub)
You can’t currently retreive build results via SSH, but you can expose them over HTTP! Thanks to the discrete (meaning undocumented) feature that distributes store paths from the API when passthru.typhonDist = true; is set in you job’s derivation.
Out of curiosity, why zulip for chat? The nix community is heavily invested in Matrix. Maybe it would be a good idea to bridge to a Matrix channel?
Gitea and cachix support looks great and shows how we can add forgejo and attic story!
Zulip seemed like a good solution to have easy access to conversation logs. I personally hate Matrix for this, just scrolling up a few messages is an awful thing to do on Element. I am open to the idea of maintaining a bridge, depending on how much work and resources it requires.
lib.gitea.mkProject can be used with forgejo, as it is still a soft fork of gitea and is completely backwards compatible (I actually test Gitea support on codeberg.org)!
While still compatible for now, the decision was recently made to make forgejo a hard fork. Forgejo monthly report - February 2024 — Forgejo
I have my complaints about matrix as well, but also don’t have a zulip account and don’t really want another chat service if I can avoid it. I think it’s important to go where the community is, and for better or worse it’s Matrix for the Nix community.
So I’ve just deployed my own typhon instance and put one of my github repository under the typhone instance as CI. However, the job always fails on evaluation. On the web interface, it just says Failure on the Nix evaluation status and I don’t really know where I should look to find out more information why the evaluation would fail. Any clue where I should take a look? By the way, the repo could be built successfully outside of typhon.
I’ve just created an issue for this feature in the typhon github repository.
