I want to wrap complex C++ framework userver to nix package.
This project is CMake based and in configurePhase it is set local virtual env for functional testing part.
In this virtual env cmake try to install yandex-taxi-testsuite. This package exist on pypi but not in the nixpkgs, so i built it as nix pkgs via buildPythonPackage.
There is nix files:
default.nix
system ? builtins.currentSystem,
pkgs = import <nixpkgs> { inherit system; };
pkgs.callPackage ./userver.nix {}
pythonLibs.nix:
lib,
fetchPypi,
python313Packages,
pythonPackages = python313Packages;
rec {
pytest-runner =
pname = "pytest-runner";
version = "6.0.1";
pythonPackages.buildPythonPackage {
inherit pname version;
src = fetchPypi {
sha256 = "cNRzlYWnAI83v0kzwBP9sye4h4paafy7MxbIiILw9Js=";
pyproject = true;
build-system = with pythonPackages; [ setuptools-scm ];
yataxi-testsuite =
pname = "yandex-taxi-testsuite";
version = "0.4.5";
src = fetchPypi {
inherit version;
pname = (lib.replaceString "-" "_" pname);
sha256 = "OrTvWO6I2ghCdL79XsUUY8E/vg8H6bwUmk5PnwPF3Ok=";
pyproject = true;
build-system = with pythonPackages; [ setuptools ];
buildInputs = with pythonPackages; [
pytest-runner
pyyaml
aiohttp
yarl
py
pytest-aiohttp
pytest
dateutils
cached-property
userver.nix
pkgs,
callPackage,
stdenv,
fetchFromGitHub,
customPythonPackages = callPackage ./pythonLibs.nix {};
stdenv.mkDerivation {
pname = "userver-lib";
version = "3.0";
src = fetchFromGitHub {
owner = "userver-framework";
repo = "userver";
rev = "v3.0";
sha256 = "uI91z2pSIoc3Az/N4dwsmkFb7gcFGKx39cHmkPIhpOE=";
cmakeFlags = [
"-DUSERVER_DOWNLOAD_PACKAGES=OFF"
"-DUSERVER_CHECK_PACKAGE_VERSIONS=0"
"-DUSERVER_PIP_USE_SYSTEM_PACKAGES=ON"
cmake
yaml-cpp
zstd
cryptopp
fmt_11
cctz
jemalloc
re2
buildInputs = with pkgs; [
openssl_4_0
boost186
gtest
(python313.withPackages (
ps: with ps; [
pip
virtualenv
customPythonPackages.yataxi-testsuite
gbenchmark
in configure phase cmake create virtual env and trying to install yandex-taxi-testsuite via network however it is already installed:
$ nix-shell -E '(import <nixpkgs> {system="x86_64-linux";}).callPackage ./userver.nix {}'
[nix-shell:~/temp]$ pip list -v
Package Version Location Installer
distlib 0.4.0 /nix/store/z7j6xbhw0kppf07w6gr4sdgjy38jap8g-python3-3.13.12-env/lib/python3.13/site-packages
filelock 3.20.3 /nix/store/z7j6xbhw0kppf07w6gr4sdgjy38jap8g-python3-3.13.12-env/lib/python3.13/site-packages
pip 25.0.1 /nix/store/z7j6xbhw0kppf07w6gr4sdgjy38jap8g-python3-3.13.12-env/lib/python3.13/site-packages
platformdirs 4.5.0 /nix/store/z7j6xbhw0kppf07w6gr4sdgjy38jap8g-python3-3.13.12-env/lib/python3.13/site-packages
virtualenv 20.33.1 /nix/store/z7j6xbhw0kppf07w6gr4sdgjy38jap8g-python3-3.13.12-env/lib/python3.13/site-packages
yandex-taxi-testsuite 0.4.5 /nix/store/z7j6xbhw0kppf07w6gr4sdgjy38jap8g-python3-3.13.12-env/lib/python3.13/site-packages
Problem is that i can’t change behaviour of this virtual env because it is part of cmake configure phase. Here is full build log:
/nix/store/2mfsph3zyb82ia6qwfyksw5jl0lla625-userver-lib-3.0.drv
building '/nix/store/2mfsph3zyb82ia6qwfyksw5jl0lla625-userver-lib-3.0.drv'...
Running phase: unpackPhase
unpacking source archive /nix/store/jz942hy5c0q6qfgxmsvmfcm81hz027zp-source
source root is source
Running phase: patchPhase
Running phase: configurePhase
cmake flags: -DCMAKE_FIND_USE_SYSTEM_PACKAGE_REGISTRY=OFF -DCMAKE_FIND_USE_PACKAGE_REGISTRY=OFF -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF -DCMAKE_INSTALL_LOCALEDIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/share/locale -DCMAKE_INSTALL_LIBEXECDIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/libexec -DCMAKE_INSTALL_LIBDIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/lib -DCMAKE_INSTALL_DOCDIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/share/doc/userver -DCMAKE_INSTALL_INFODIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/share/info -DCMAKE_INSTALL_MANDIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/share/man -DCMAKE_INSTALL_INCLUDEDIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/include -DCMAKE_INSTALL_SBINDIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/sbin -DCMAKE_INSTALL_BINDIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/bin -DCMAKE_INSTALL_NAME_DIR=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0/lib -DCMAKE_STRIP=/nix/store/8v97ngkcpfzgghwnnr7fsz33p2x22gy9-gcc-wrapper-14.3.0/bin/strip -DCMAKE_RANLIB=/nix/store/8v97ngkcpfzgghwnnr7fsz33p2x22gy9-gcc-wrapper-14.3.0/bin/ranlib -DCMAKE_AR=/nix/store/8v97ngkcpfzgghwnnr7fsz33p2x22gy9-gcc-wrapper-14.3.0/bin/ar -DCMAKE_C_COMPILER=gcc -DCMAKE_CXX_COMPILER=g++ -DCMAKE_INSTALL_PREFIX=/nix/store/xada3hakwalp0bijskd2id0dpm7382im-userver-lib-3.0 -DUSERVER_DOWNLOAD_PACKAGES=OFF -DUSERVER_CHECK_PACKAGE_VERSIONS=0 -DUSERVER_PIP_USE_SYSTEM_PACKAGES=ON
-- The CXX compiler identification is GNU 14.3.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /nix/store/8v97ngkcpfzgghwnnr7fsz33p2x22gy9-gcc-wrapper-14.3.0/bin/g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Building utest with gtest and ubench with gbench
-- rseq-based acceleration is enabled by default
-- Modules type search priority order: .so;.a (Default ordered)
-- C compiler: gcc
-- C++ compiler: /nix/store/8v97ngkcpfzgghwnnr7fsz33p2x22gy9-gcc-wrapper-14.3.0/bin/g++
-- C++ standard 20
-- Using the default system linker, probably GNU ld
-- LTO: disabled (user request)
-- Performing Test LINKER_HAS_ZSTD
-- Performing Test LINKER_HAS_ZSTD - Failed
-- Performing Test LINKER_HAS_GZ
-- Performing Test LINKER_HAS_GZ - Success
-- Using linker debug info compression: z
-- Performing Test HAS_gz_zstd
-- Performing Test HAS_gz_zstd - Success
-- Checking -gz=zstd - found
-- Using compiler debug info compression: zstd
-- Linker global flags: -Wl,--gc-sections
-- ccache: enabled, but not found
-- Release build: CMAKE_BUILD_TYPE == 'Release'
-- Could NOT find Git (missing: GIT_EXECUTABLE)
-- Git not found
-- Python: python3
-- Found OpenSSL: /nix/store/9xc19q5pmpxp993k13ig6bbhzdnnjdfb-openssl-4.0.0/lib/libcrypto.so (found version "4.0.0")
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Could NOT find boost_stacktrace_backtrace (missing: boost_stacktrace_backtrace_DIR)
-- Could NOT find boost_stacktrace_windbg (missing: boost_stacktrace_windbg_DIR)
-- Could NOT find boost_coroutine2 (missing: boost_coroutine2_DIR)
-- Could NOT find boost_config (missing: boost_config_DIR)
-- Could NOT find boost_assert (missing: boost_assert_DIR)
-- Setting up the venv at /build/source/build/venv-utest
-- Installing requirements:
-- /build/source/build/requirements-userver-testsuite.txt
WARNING: The directory '/homeless-shelter/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff5695160>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/wheel/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff581de50>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/wheel/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff581e0d0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/wheel/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff581e350>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/wheel/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff581e5d0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/wheel/
ERROR: Could not find a version that satisfies the requirement wheel (from versions: none)
ERROR: No matching distribution found for wheel
CMake Error at cmake/UserverVenv.cmake:169 (message):
Failed to install venv requirements
Call Stack (most recent call first):
cmake/UserverTestsuite.cmake:42 (userver_venv_setup)
cmake/UserverTestsuite.cmake:532 (_userver_prepare_testsuite)
CMakeLists.txt:243 (include)
-- Configuring incomplete, errors occurred!
error: Cannot build '/nix/store/2mfsph3zyb82ia6qwfyksw5jl0lla625-userver-lib-3.0.drv'.
Reason: builder failed with exit code 1.
Output paths:
Last 25 log lines:
For full logs, run:
nix log /nix/store/2mfsph3zyb82ia6qwfyksw5jl0lla625-userver-lib-3.0.drv
There interesting part in log: WARNING: The directory ‘/homeless-shelter/.cache/pip’ or its parent directory is not owned or is not writable by the current user. The cache has been disabled.
It seems like python packages not available and pip try to download them.
I will glad to get any help or directions to research
