Hello,
I am trying to configure my system to support my old GPU (AMD R9 290X for the reference), thus I am trying to use an older linux kernel (4.9) to be able to use the amd drivers still compatible with my GPU.
After applying the following diff :
Diff between the two configurations (click to open)
diff --git a/machines/hyperion/default.nix b/machines/hyperion/default.nix
index 6a0c3e8..f593535 100644
--- a/machines/hyperion/default.nix
+++ b/machines/hyperion/default.nix
@@ -22,13 +24,26 @@
+ hardware.opengl = {
+ enable = true;
+ driSupport = true;
+ driSupport32Bit = true;
boot = {
- kernelPackages = pkgs.linuxPackages_latest;
+ kernelPackages = pkgs.linuxPackages_4_9.ati_drivers_x11;
and run sudo nixos-rebuild switch
I get the following error message (excerpt; full log with the trace in the spoiler at the end ) :
while evaluating 'apply' at /nix/var/nix/profiles/per-user/root/channels/nixos/nixos/modules/system/boot/kernel.nix:39:15, called from /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:333:11:
attribute 'extend' missing, at /nix/var/nix/profiles/per-user/root/channels/nixos/nixos/modules/system/boot/kernel.nix:39:31
Would anyone know why this happens and would have a fix for it ?
Full `sudo nixos-rebuild switch` log with trace
building Nix...
error: while evaluating the attribute 'config.system.build.toplevel' at /nix/var/nix/profiles/per-user/root/channels/nixos/nixos/modules/system/activation/top-level.nix:276:5:
while evaluating 'foldr' at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/lists.nix:39:20, called from /nix/var/nix/profiles/per-user/root/channels/nixos/nixos/modules/system/activation/top-level.nix:140:12:
while evaluating 'fold'' at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/lists.nix:42:15, called from /nix/var/nix/profiles/per-user/root/channels/nixos/lib/lists.nix:46:8:
while evaluating the attribute 'assertions' at undefined position:
while evaluating anonymous function at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:75:45, called from undefined position:
while evaluating the attribute 'value' at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:338:9:
while evaluating the option `assertions':
while evaluating the attribute 'isDefined' at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:375:5:
while evaluating the attribute 'values' at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:364:9:
while evaluating the attribute 'values' at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:458:7:
while evaluating anonymous function at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:350:28, called from /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:350:17:
while evaluating 'dischargeProperties' at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:417:25, called from /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:351:62:
while evaluating 'dischargeProperties' at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:417:25, called from /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:423:11:
while evaluating the attribute 'content' at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:502:14:
while evaluating the attribute 'boot.kernelPackages.kernel' at undefined position:
while evaluating the option `boot.kernelPackages':
