Hi there, for anyone with experience with DWL on NixOS, how did you do it? I’m currently running KDE but I would also like to run DWL sometimes. My display-manager is SDDM, I got as far as including DWL in the systemPackages, but dwl didn’t show up as an option to boot in, in my display-manager.
Any help is appreciated!
You should set programs.dwl.enable in NixOS instead of adding to environment.systemPackages. If you want a customized dwl, set programs.dwl.package to the customized package.
Thank you! Will give this a shot and let you know. Would you know by any chance as well if there exists a way to manage dwl from a flake?
Don’t think there is any particular module on top of dwl.override and dwl.overrideAttrs as described in the option docs for programs.dwl.package:
# Lets apply bar patch from:
# https://codeberg.org/dwl/dwl-patches/src/branch/main/patches/bar
(pkgs.dwl.override {
configH = ./dwl-config.h;
}).overrideAttrs (oldAttrs: {
buildInputs =
oldAttrs.buildInputs or []
pkgs.libdrm
pkgs.fcft
patches = oldAttrs.patches or [] ++ [
./bar-0.7.patch
I think manually adding a desktop file this way works, no matter how you install dwl.
{ pkgs, ... }:
mkDesktopEntry =
pkgs.writeTextFile {
inherit name text;
destination = "/share/wayland-sessions/${name}.desktop";
derivationArgs = {
passthru.providedSessions = [ name ];
services.displayManager.sessionPackages = [
(mkDesktopEntry "dwl" ''
[Desktop Entry]
Name=dwl
Comment=dwl
Exec=/run/current-system/sw/bin/dwl
Type=Application
I don’t see any reason to use this. the dwl package provides this file:
❯ cat result/share/wayland-sessions/dwl.desktop
[Desktop Entry]
Name=dwl
Comment=dwm for Wayland
Exec=dwl
Type=Application
So if your “no matter how you install dwl” means through HM, I would just do that. Or do that but keep the wrapper but replace exec ${lib.getExe cfg.package} with exec dwl.
