Using Espanso on Wayland NixOS
OK. I had to restart for things to work.
The port to NixOS 25.11 is working. But Espanso is not always working after computer sleep on my machine. I had to restart it to make it work again.
Are you also experiencing this problem?
I created a service to restart Espanso after sleep. It works with dbus so it depends on Gnome.
services.espanso = {
      package = pkgs-unstable.espanso-wayland;
on Niri, but nothing triggers :-/
EDIT: just found out that on wayland, need to set the layout if non-US and I’m not US ^^ it works now
Even with the service, Espanso is not always working even when its status is saying that it is running. So, I am removing it. :frowning:
Have you tried to change the backend setting? For Zen I had to add a per-app config to force clipboard, and set inject as the default one (instead of auto)
No. I just moved to Niri from Gnome. Maybe, I’ll try back.
You might be interested in this PR, it solved ~all my issues with auto-pasting in apps on Wayland (KDE)
