I’m trying to use MIQT to mess around with QT. I’m having trouble though, as I get this error near the end of my logs
os
fmt
runtime/cgo
github.com/mappu/miqt/libmiqt
github.com/mappu/miqt/qt6
# github.com/mappu/miqt/qt6
# [pkg-config --cflags -- Qt6Widgets]
Package Qt6Widgets was not found in the pkg-config search path.
Perhaps you should add the directory containing `Qt6Widgets.pc'
to the PKG_CONFIG_PATH environment variable
No package 'Qt6Widgets' found
I’ve tried searching for Qt6Widgets in the package repository but I haven’t found anything that seems to be the answer. Cheers!
