Using Nix for development, building, and testing android project
Is there any good documentation or tutorial or maybe snippet that i can take a look for android specific project?
I have android project that I want to use nix as my cd/ci to help me maintain it. I have seen several repo but I want to know if there is anyone here has experienced with large android project?
Sander made a tutorial some time ago, explaining how to build Android apps in Nix:
I noticed GitHub - uniphil/nix-for-devs: nix-shell recipes altho I haven’t tried it.
You should ask Sander van der Burg. He has done a lot with Android and Nix. See this talk he gave at the Amsterdam Nix Meetup:
thank you to all of you. I am reading it right now.
Here is a small nix file I use for developing a react-native project:
{ pkgs ? import <nixpkgs> { } }:
with pkgs; mkShell {
  ANDROID_HOME = "${androidsdk_extras}/libexec";
  nativeBuildInputs = [
    androidsdk_extras
    jdk
    nodejs-9_x
It’s also worth mentioning this PR, which adds multiple versions of buildTools: androidenv: autogenerated build-tools and addons repositories by yorickvP · Pull Request #37805 · NixOS/nixpkgs · GitHub
There’s also obelisk which was recently announced. Not sure about the details of how to use it though, I haven’t tried it myself.
Thank you, i will take a look into the PR
I have tried obelisk, but it seems that it is too opinionated for me and i never try for android fwiw (just use it for haskell project)
how do you start emulator with this? I can’t in my machine. There seems to be no system images (in ${androidsdk}/libexec/system-images)
The result of android list targets is:
Available Android targets:
id: 1 or "android-26"
     Type: Platform
     API level: 26
     Revision: 2
     Skins: HVGA, QVGA, WQVGA400, WQVGA432, WSVGA, WVGA800 (default), WVGA854, WXGA720, WXGA800, WXGA800-7in
 Tag/ABIs : no ABIs.
