I would like to use Nix for development at work. We have a variety of projects, mostly written in C++, and each in their own Git repository. Some of the projects are libraries, which may depend on other of our libraries, and some are applications that use those libraries. Is there a good way to use Nix to work in this setup?
What I’ve tried so far is to make a flake.nix per project, with the build tools and dependencies. I’ve managed to build a few of our projects this way, with flakes pulling in other flakes as dependencies as necessary. This… works, but a couple of things could be smoother:
- Making debug and release builds of everything is possible but kind of a mess. Every flake gets a
debuginput that may be true. - Each flake points to a commit in a git repo. Updating a dependency means updating these commit pointers in a bunch of flakes.
These seem small but add up to quite a lot of ceremony when working with Nix. The main problem is that I have a lot of versions of each app/lib in play at any time (if nothing else, there’s the last release of the main branch, usually there are one of two release branches as well), and for debugging there are also debug versions, and these add up to a bit of a combinatorial explosion of stuff that I have to keep on track by hand.
Does anyone have experience with using Nix in these kinds of large, interdependent projects that weren’t built with Nix in mind?
