I’m sorry but I don’t think I understand the question. We’re patching (or rather unpatching the patchelf step) nvidia_x11 pkg so that the drivers work in the FHS containers in k3s which won’t have the /nix/store in them. The drivers need to be discovered twice via ldconfig - once by the nvidia container runtime on the host for mounting into the container, and once by the container itself. How would the userspace drivers inherit that property?
I can decompose the question into smaller ones:
How do you decide, at build time, which
nvidia_x11to take? Because the container must mount the userspace drivers (includinglibcuda.soandlibnvidia-ml.so) compatible (=precisely the same, or at least newer) with the kernel module used by the host machine at runtime -
… which won’t have the /nix/store in them
But the drivers are still mounted impurely from the host, why not mount the
/nix/store/xxxx...-nvidia_x11&c paths as well -
This happens for some packages. If possible, the desirable way to approach this is to remove/make optional all of the references to
ld.so.cache, and replace the “path inference” results with the predictable values. For a container running on a NixOS host, this path would be/run/opengl-driver/lib, plus targets of the symlinks therein. The drivers deployed there by NixOS in that location are known to be compatible with the kernel used at runtime
I’m asking because I think we should want to integrate the solution into nixpkgs. Thanks!
Ok! We’re bumping up against the edge of my knowledge here, but if I understand correctly:
nvidia_x11to take?I assume you’re talking about this line here:
unpatched-nvidia-driver = (super.pkgs.linuxKernel.packages.linux_5_15.nvidia_x11_production.overrideAttrs (oldAttrs: { builder = ../overlays/nvidia-builder.sh; }));And indeed I chose that through trial and error. Which package is the standard one to install that will be guaranteed to be compatible with the kernel?
This is done by the
nvidia-container-runtime. Where is chooses to mount the drivers in the container – regardless of how it finds them – is a bit deeper in the codebase than I looked. The discovery mechanism is vialdconfig, but currently we are pointing it at the drivers in/nix/store/xxx...-nvidia-x11on the host here. Are you asking why/nix/store/xxx-nvidia-x11is not mounted directly (at the same path) in the container? -
ld.so.cache, and replace the “path inference” results with the predictable valuesI believe this would require a different patch of
libnvidia-containerso that it searches/run/opengl-driver/libinstead of relying onldconfigwhile on the host. I’m not sure how deep that would go, but it may be possible. The search forld.so.cacheis hardcoded into the library here, a path altered by this patch and incommon.hby this patch. I think this would fundamentally changelibnvidia-container’s discovery mechanism. The difficulty there is that this code seems to run once on the host and once in the container, so getting it to use different discovery mechanisms depending on the context would take more considerable understanding of the library, esp. since containers will not adhere to the NixOS paths. Alternatively, gettinglibnvidia-containerto mount the NixOS paths, then update the container’s ownld.so.cacheto reference those paths is a different challenge. For example, I’m not sure if the following search paths provided byld.so.conf.din thenvidia-device-plugincontainer are baked into the container, or altered bylibnvidia-containerat runtime.$ kubectl exec -n kube-system -it nvidia-device-plugin-pz56s -- /bin/sh $ cat /etc/ld.so.conf include /etc/ld.so.conf.d/*.conf $ cat /etc/ld.so.conf.d/*.conf # libc default configuration /usr/local/lib /usr/local/nvidia/lib /usr/local/nvidia/lib64 # Multiarch support /usr/local/lib/x86_64-linux-gnu /lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu
Would love to see a pure integration in nixpkgs! My feeling is that some deeper C skills than I possess would be necessary here.
rusty-jules has pretty much said everything but I’ll add what I can remember. I’ve since abandoned my NVIDIA integration in k3s since there were a host of other issues.
libnvidia-container has a list of files it looks for https://github.com/NVIDIA/libnvidia-container/blob/1eb5a30a6ad0415550a9df632ac8832bf7e2bbba/src/nvc_info.c#L51
Which then finds the library paths using the ldcache https://github.com/NVIDIA/libnvidia-container/blob/1eb5a30a6ad0415550a9df632ac8832bf7e2bbba/src/nvc_info.c#L220
Ideally, we’d be using the NVIDIA/CUDA driver pod from NVIDIA, but my attempts have failed due to layout of NixOS (don’t quite remember errors, but I’d imagine the classic problems with trying to use imperative programs).
2/3.
If you were to try to make it NixOS-friendly, a better alternative it write it from scratch. In comparison in making due with the ldcache approach, it is a lot more prone to needing active maintenance from upstream changes.
fwiw using the cdi integration with containerd seems much better. I have a working setup, though I’m still using the nvidia ldcache shenanigans to generate the cdi spec via nvidia-ctk cdi generate, but this is patchable and/or writable from scratch. For what it’s worth it seems to work more or less out of the box, though I had to manually patch the output (with jq) to mount /run/opengl-driver into the sandbox to get a well-known LD_LIBRARY_PATH to work with, but the autogenerated spec (essentially nvidia-ctk cdi generate used on an ldconfig dump of /run/opengl-driver) actually managed to at least resolve every symlink into the store along with the relevant devices on its own.
We definitely need to reach out with the upstream and discuss a way for them to (1) stop relying on the obscure glibc internals such as /etc/ld.so.cache, and (2) stop assuming that mounting the host system’s drivers is the right thing to do (generally speaking, it’s not, because the container image might come with a different libc).
The first step would be to introduce the static configuration option allowing the user to explicitly list the paths to the drivers, at build time or in a config file read at runtime. In principle, the /etc/ld.so.cache already is that, except writing one affects more than just the ctk.
I’m planning to open an issue/PR eventually but it’ll probably take me ages, and I’ll be really happy if somebody goes ahead before then
I’ll also add that this doesn’t only affect k3s, but also for example apptainer/singularity which are important for the HPC stuff
Hi! Trying to update libnvidia-container and nvidia-container-toolkit in apptainer: unbreak --nv by SomeoneSerge · Pull Request #279235 · NixOS/nixpkgs · GitHub, but I’m mostly motivated by apptainer’s needs. Could somebody test these changes with containerd?
EDIT: nvidia-container-toolkit: 1.9.0 -> 1.15.0-rc.3 by aaronmondal · Pull Request #278969 · NixOS/nixpkgs · GitHub has been merged
Hi! Now that nvidia-container-toolkit is available on nixpkgs-unstable, does it mean that we can just make it available in environment.systemPackages and it’s just Going To Work™️?
I’ll probably be testing it soon but I thought I’d ask if someone’s tried it already?
