I would like to use the package dvtm with a custom configuration, which is done by recompiling with a custom config.h file. According to PR #16560, this is possible.
Here is the nix expression for this package:
Unfortunately I do not understand where the file config.h should be placed, or how customConfig should be used. My question is as follows:
What should I add to my configuration.nix in order to use dvtm with a custom configuration file?
I realize this is a rather specific question, unfortunately I’m lacking some basic knowledge. Any help would be much appreciated.
What @luke-clifton said should work. However, it’s simpler and clearer to just do the override where you’re referencing it rather than modifying the package set:
