Hello, i use
sudo nixos-rebuild switch --flake .#VPS-Server-005 --target-host manager@someIP --ask-sudo-password
for make my build remotly, this work faily great until not.
[sudo] password for manager:
warning: Git tree '/etc/nixos' is dirty
[sudo] password for manager@someIp:
(manager@someIp) Password:
copying 0 paths...
stopping swap device: /dev/disk/by-uuid/d5604472-7e21-4894-b30b-d4c4a0cdd945
stopping the following units: acme-renew-wateir.fr.timer, acme-setup.service, acme-wateir.fr.service, forgejo-secrets.service, forgejo.service, newt.service, postgresql-setup.service, redis-searx.service, searx-init.service, searx.service, systemd-modules-load.service, systemd-sysctl.service, vaultwarden.service
NOT restarting the following changed units: -.mount
[agenix] creating new generation in /run/agenix.d/2
[agenix] decrypting secrets...
decrypting '/nix/store/frv7rbz1jvsds664774p84bv74wg6af5-LtnxWKwZdDIxAKzp' to '/run/agenix.d/2/LtnxWKwZdDIxAKzp'...
decrypting '/nix/store/xnd41h98170ppq9zj6g7w4xw0bk934j0-YfDrVBDJcVoYNZeJ' to '/run/agenix.d/2/YfDrVBDJcVoYNZeJ'...
decrypting '/nix/store/2bfdfw4vhr65q7lxw7v4cqz3bmw3r8s7-xHeDf80ikqG65h3u' to '/run/agenix.d/2/xHeDf80ikqG65h3u'...
[agenix] symlinking new secrets to /run/agenix (generation 2)...
[agenix] removing old secrets (generation 1)...
removing group ‘git’
removing group ‘acme’
removing group ‘searx’
removing group ‘vaultwarden’
removing user ‘acme’
removing user ‘git’
removing user ‘searx’
removing user ‘vaultwarden’
[agenix] chowning...
Activation script snippet 'agenixChown' failed (1)
chown: invalid user: ‘vaultwarden:0’
setting up /etc...
Failed to run activate script
reloading user units for manager...
restarting sysinit-reactivation.target
reloading the following units: dbus.service, firewall.service
restarting the following units: boot.mount, nginx.service, sshd.service
starting the following units: postgresql-setup.service, systemd-modules-load.service, systemd-sysctl.service
Failed to start local-fs.target
Failed to restart boot.mount
Command 'ssh -o ControlMaster=auto -o ControlPath=/tmp/nixos-rebuild.vktqx4zb/ssh-%n -o ControlPersist=60 manager@someIp -- sudo --prompt= --stdin env NIXOS_INSTALL_BOOTLOADER=0 systemd-run -E LOCALE_ARCHIVE -E NIXOS_INSTALL_BOOTLOADER --collect --no-ask-password --pipe --quiet --service-type=exec --unit=nixos-rebuild-switch-to-configuration /nix/store/8n79f9v2vyb62qjqan9pjlicj6rdqjb5-nixos-system-VPS-Server-005-25.11.20251226.f560cce/bin/switch-to-configuration switch' returned non-zero exit status 255.
After that i can’t no longer ssh into my builder server.
janv. 05 00:02:49 ThinkCentre-Server-004 sshd-session[2424]: Received disconnect from ::1 port 59978:11: [preauth]
janv. 05 00:02:49 ThinkCentre-Server-004 sshd-session[2424]: Disconnected from authenticating user root ::1 port 59978 [preauth]
janv. 05 00:02:49 ThinkCentre-Server-004 sshd-session[2424]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:02:49 ThinkCentre-Server-004 unix_chkpwd[2435]: password check failed for user (root)
janv. 05 00:02:49 ThinkCentre-Server-004 sshd-session[2433]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:02:51 ThinkCentre-Server-004 sshd-session[2433]: Failed password for root from ::1 port 58272 ssh2
janv. 05 00:02:51 ThinkCentre-Server-004 unix_chkpwd[2437]: password check failed for user (root)
janv. 05 00:02:53 ThinkCentre-Server-004 sshd-session[2433]: Failed password for root from ::1 port 58272 ssh2
janv. 05 00:02:53 ThinkCentre-Server-004 unix_chkpwd[2440]: password check failed for user (root)
janv. 05 00:02:55 ThinkCentre-Server-004 sshd-session[2433]: Failed password for root from ::1 port 58272 ssh2
janv. 05 00:02:55 ThinkCentre-Server-004 unix_chkpwd[2442]: password check failed for user (root)
janv. 05 00:02:55 ThinkCentre-Server-004 sshd-session[2438]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:02:55 ThinkCentre-Server-004 sshd-session[2433]: Received disconnect from ::1 port 58272:11: [preauth]
janv. 05 00:02:55 ThinkCentre-Server-004 sshd-session[2433]: Disconnected from authenticating user root ::1 port 58272 [preauth]
janv. 05 00:02:55 ThinkCentre-Server-004 sshd-session[2433]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:02:56 ThinkCentre-Server-004 unix_chkpwd[2451]: password check failed for user (root)
janv. 05 00:02:56 ThinkCentre-Server-004 sshd-session[2449]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:02:56 ThinkCentre-Server-004 sshd-session[2438]: Failed password for root from ::1 port 58278 ssh2
janv. 05 00:02:57 ThinkCentre-Server-004 sshd-session[2438]: Connection closed by authenticating user root ::1 port 58278 [preauth]
janv. 05 00:02:58 ThinkCentre-Server-004 sshd-session[2449]: Failed password for root from ::1 port 60232 ssh2
janv. 05 00:03:00 ThinkCentre-Server-004 unix_chkpwd[2452]: password check failed for user (root)
janv. 05 00:03:00 ThinkCentre-Server-004 unix_chkpwd[2455]: password check failed for user (root)
janv. 05 00:03:00 ThinkCentre-Server-004 sshd-session[2453]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:03:01 ThinkCentre-Server-004 sshd-session[2449]: Failed password for root from ::1 port 60232 ssh2
janv. 05 00:03:02 ThinkCentre-Server-004 unix_chkpwd[2456]: password check failed for user (root)
janv. 05 00:03:03 ThinkCentre-Server-004 sshd-session[2453]: Failed password for root from ::1 port 60246 ssh2
janv. 05 00:03:03 ThinkCentre-Server-004 sshd-session[2449]: Failed password for root from ::1 port 60232 ssh2
janv. 05 00:03:03 ThinkCentre-Server-004 sshd-session[2449]: Received disconnect from ::1 port 60232:11: [preauth]
janv. 05 00:03:03 ThinkCentre-Server-004 sshd-session[2449]: Disconnected from authenticating user root ::1 port 60232 [preauth]
janv. 05 00:03:03 ThinkCentre-Server-004 sshd-session[2449]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:03:04 ThinkCentre-Server-004 sshd-session[2453]: Connection closed by authenticating user root ::1 port 60246 [preauth]
janv. 05 00:03:11 ThinkCentre-Server-004 unix_chkpwd[2497]: password check failed for user (root)
janv. 05 00:03:11 ThinkCentre-Server-004 sshd-session[2489]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:03:13 ThinkCentre-Server-004 sshd-session[2489]: Failed password for root from ::1 port 35938 ssh2
janv. 05 00:03:14 ThinkCentre-Server-004 sshd-session[2489]: Connection closed by authenticating user root ::1 port 35938 [preauth]
janv. 05 00:03:34 ThinkCentre-Server-004 unix_chkpwd[2626]: password check failed for user (root)
janv. 05 00:03:34 ThinkCentre-Server-004 sshd-session[2624]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:03:36 ThinkCentre-Server-004 sshd-session[2624]: Failed password for root from ::1 port 38548 ssh2
janv. 05 00:03:38 ThinkCentre-Server-004 sshd-session[2624]: Connection closed by authenticating user root ::1 port 38548 [preauth]
janv. 05 00:03:43 ThinkCentre-Server-004 unix_chkpwd[2630]: password check failed for user (root)
janv. 05 00:03:43 ThinkCentre-Server-004 sshd-session[2628]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1 user=root
janv. 05 00:03:44 ThinkCentre-Server-004 sshd-session[2631]: Connection closed by ::1 port 56432
janv. 05 00:03:44 ThinkCentre-Server-004 sshd-session[2632]: Invalid user admin from ::1 port 56434
janv. 05 00:03:44 ThinkCentre-Server-004 sshd-session[2632]: pam_unix(sshd:auth): check pass; user unknown
janv. 05 00:03:44 ThinkCentre-Server-004 sshd-session[2632]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=::1
janv. 05 00:03:45 ThinkCentre-Server-004 sshd-session[2628]: Failed password for root from ::1 port 56418 ssh2
janv. 05 00:03:45 ThinkCentre-Server-004 sshd-session[2628]: Connection closed by authenticating user root ::1 port 56418 [preauth]
janv. 05 00:03:46 ThinkCentre-Server-004 sshd-session[2632]: Failed password for invalid user admin from ::1 port 56434 ssh2
janv. 05 00:03:47 ThinkCentre-Server-004 sshd-session[2632]: Connection closed by invalid user admin ::1 port 56434 [preauth]
This log come from the builder machine,
full log of this day http://0x0.st/Po2K.txt
It’s seems like this make my builder server ddos it’s self
