Varia installation error: “platformdirs not installed”
Here are the full logs:
these 2 derivations will be built:
  /nix/store/q8mwdfdiffhfjslpx6jgy26176fbl3fi-python3.12-aria2p-0.12.1.drv
  /nix/store/rhd0xnhq0aynz8vlab5zdaxp2d4qvcdx-varia-2025.1.24.drv
aria2p> building '/nix/store/q8mwdfdiffhfjslpx6jgy26176fbl3fi-python3.12-aria2p-0.12.1.drv'
aria2p> Sourcing python-remove-tests-dir-hook
aria2p> Sourcing python-catch-conflicts-hook.sh
aria2p> Sourcing python-remove-bin-bytecode-hook.sh
aria2p> Sourcing pypa-build-hook
aria2p> Using pypaBuildPhase
aria2p> Sourcing python-runtime-deps-check-hook
aria2p> Using pythonRuntimeDepsCheckHook
aria2p> Sourcing pypa-install-hook
aria2p> Using pypaInstallPhase
aria2p> Sourcing python-imports-check-hook.sh
aria2p> Using pythonImportsCheckPhase
aria2p> Sourcing python-namespaces-hook
aria2p> Sourcing pytest-check-hook
aria2p> Using pytestCheckPhase
aria2p> Running phase: unpackPhase
aria2p> unpacking source archive /nix/store/nimi3j58garqk38palmyqm425fndic0s-source
aria2p> source root is source
aria2p> setting SOURCE_DATE_EPOCH to timestamp 315619200 of file "source/tests/test_utils.py"
aria2p> Running phase: patchPhase
aria2p> Running phase: updateAutotoolsGnuConfigScriptsPhase
aria2p> Running phase: configurePhase
aria2p> no configure script, doing nothing
aria2p> Running phase: buildPhase
aria2p> Executing pypaBuildPhase
aria2p> Setting PDM_BUILD_SCM_VERSION to 0.12.1
aria2p> Creating a wheel...
aria2p> pypa build flags: --no-isolation --outdir dist/ --wheel
aria2p> * Getting build dependencies for wheel...
aria2p> * Building wheel...
aria2p>  - Adding .pdm-build/aria2p-0.12.1.dist-info/METADATA -> aria2p-0.12.1.dist-info/METADATA
aria2p>  - Adding .pdm-build/aria2p-0.12.1.dist-info/WHEEL -> aria2p-0.12.1.dist-info/WHEEL
aria2p>  - Adding .pdm-build/aria2p-0.12.1.dist-info/entry_points.txt -> aria2p-0.12.1.dist-info/entry_points.txt
aria2p>  - Adding .pdm-build/aria2p-0.12.1.dist-info/licenses/LICENSE -> aria2p-0.12.1.dist-info/licenses/LICENSE
aria2p>  - Adding src/aria2p/__init__.py -> aria2p/__init__.py
aria2p>  - Adding src/aria2p/__main__.py -> aria2p/__main__.py
aria2p>  - Adding src/aria2p/api.py -> aria2p/api.py
aria2p>  - Adding src/aria2p/cli/__init__.py -> aria2p/cli/__init__.py
aria2p>  - Adding src/aria2p/cli/commands/__init__.py -> aria2p/cli/commands/__init__.py
aria2p>  - Adding src/aria2p/cli/commands/add.py -> aria2p/cli/commands/add.py
aria2p>  - Adding src/aria2p/cli/commands/add_magnet.py -> aria2p/cli/commands/add_magnet.py
aria2p>  - Adding src/aria2p/cli/commands/add_metalink.py -> aria2p/cli/commands/add_metalink.py
aria2p>  - Adding src/aria2p/cli/commands/add_torrent.py -> aria2p/cli/commands/add_torrent.py
aria2p>  - Adding src/aria2p/cli/commands/call.py -> aria2p/cli/commands/call.py
aria2p>  - Adding src/aria2p/cli/commands/listen.py -> aria2p/cli/commands/listen.py
aria2p>  - Adding src/aria2p/cli/commands/pause.py -> aria2p/cli/commands/pause.py
aria2p>  - Adding src/aria2p/cli/commands/purge.py -> aria2p/cli/commands/purge.py
aria2p>  - Adding src/aria2p/cli/commands/remove.py -> aria2p/cli/commands/remove.py
aria2p>  - Adding src/aria2p/cli/commands/resume.py -> aria2p/cli/commands/resume.py
aria2p>  - Adding src/aria2p/cli/commands/show.py -> aria2p/cli/commands/show.py
aria2p>  - Adding src/aria2p/cli/commands/top.py -> aria2p/cli/commands/top.py
aria2p>  - Adding src/aria2p/cli/main.py -> aria2p/cli/main.py
aria2p>  - Adding src/aria2p/cli/parser.py -> aria2p/cli/parser.py
aria2p>  - Adding src/aria2p/client.py -> aria2p/client.py
aria2p>  - Adding src/aria2p/debug.py -> aria2p/debug.py
aria2p>  - Adding src/aria2p/downloads.py -> aria2p/downloads.py
aria2p>  - Adding src/aria2p/interface.py -> aria2p/interface.py
aria2p>  - Adding src/aria2p/options.py -> aria2p/options.py
aria2p>  - Adding src/aria2p/py.typed -> aria2p/py.typed
aria2p>  - Adding src/aria2p/stats.py -> aria2p/stats.py
aria2p>  - Adding src/aria2p/utils.py -> aria2p/utils.py
aria2p>  - Adding aria2p-0.12.1.dist-info/RECORD -> aria2p-0.12.1.dist-info/RECORD
aria2p> Successfully built aria2p-0.12.1-py3-none-any.whl
aria2p> Finished creating a wheel...
aria2p> Finished executing pypaBuildPhase
aria2p> Running phase: pythonRuntimeDepsCheckHook
aria2p> Executing pythonRuntimeDepsCheck
aria2p> Checking runtime dependencies for aria2p-0.12.1-py3-none-any.whl
aria2p>   - platformdirs not installed
error: builder for '/nix/store/q8mwdfdiffhfjslpx6jgy26176fbl3fi-python3.12-aria2p-0.12.1.drv' failed with exit code 1;
       last 25 log lines:
       For full logs, run 'nix log /nix/store/q8mwdfdiffhfjslpx6jgy26176fbl3fi-python3.12-aria2p-0.12.1.drv'.
error: 1 dependencies of derivation '/nix/store/rhd0xnhq0aynz8vlab5zdaxp2d4qvcdx-varia-2025.1.24.drv' failed to build
Solved by adding pkgs.pythonPackages.platformdirs to programs.nix-ld.libraries
This was because aria2p failed to build.
It also failed on Hydra: Hydra - Log of step 1 of build 290721027 of job nixos:trunk-combined:nixpkgs.varia.aarch64-linux.
Varia now builds: Hydra - Log of build 291932419 of job nixos:trunk-combined:nixpkgs.varia.aarch64-linux
So please update your nixos-unstable channel/flake now.
