Howdy –
I have an outstanding PR (adding an expression and NixOS module for bees, an extent-layer btrfs deduplicator) which @Infinisil was kind enough to review, but for a shell wrapper contained therein.
The script in question is at bees: init at 0.6.1; nixos/modules: services.bees init by charles-dyfis-net · Pull Request #48423 · NixOS/nixpkgs · GitHub it intends to perform the same function as the upstream tool at bees/beesd.in at 14ccf88050ff83ece75f633245110f3deb8693bc · Zygo/bees · GitHub, but without requiring the UUID of the filesystem to be deduplicated to be hardcoded in the configuration (which is quite thoroughly baked into the original).
Upstream bees has indicated that they could possibly be amenable to merging a future version of my wrapper (for inclusion in a future version of bees) if it’s extended to be backwards compatible with existing config files – I might pursue that approach, but it’d be good to get the current version of bees available in Nix even as-is; and requiring configuration.nix to know about filesystem UUIDs (as would be necessary to generate config files for use by the original upstream wrapper without needing to perform runtime inspection steps) is pretty much unacceptable on its face.
Would anyone who considers themselves handy enough with bash to review some code that’s fairly aggressive about leveraging modern language features where doing so aids correctness be available to review?
Many thanks,
– Charles
