Vr not working correctly, drm leasing issue
Do you get any error when running steam vr with the launch option?
So when I set the launch options and the connection type as TCP I get the error
error in encoder thread: Failed to transfer Vulkan image to CUDA frame Generic error in an external library
But the controlers and headset get recognised but still a Black screen.
When I set the connection type to udp i don’t get the error but therfor the controllers and the headset don’t get recognised.
I get the feeling you’re mixing nixpkgs revisions here.
Which exact revision of nixpkgs is this and is it the exact same nixpkgs revision that the currently deployed NixOS is built from?
Mixing nixpkgs revisions can work for simple CLI stuff but is extremely likely to fall apart for anything that has to do with graphics; even if it’s two revisions from the “same” channel.
Please use exactly one nixpkgs revision.
he installed it correctly. I installed it the same way and it worked like this before i updated.
sorry i couldnt reply yesterday because of the limit for new users
do you mean because im on nixos 24.11 and i installed alvr on unstable?
Yes, that’s very likely to cause issues.
Take everything from the exact same revision of nixpkgs.
that was the exact issue omg
tysm!! <3
thank you for helping too!
Need to try that too. Maybe it resolves my issue too
Wich Version of ALVR have you now?
the one from the unstable branch
im using the steam beta too although the current version (2.8.8) worked too
thanks will try that out
