Hi, I’ve been looking for a way to install drivers for a USB Wi-Fi adapter (TP-Link AX300) for a while, but I never manage to do it, even trying non-original Chinese drivers. Has anyone had the same problem and managed to solve it?
How would you usually get this adapter to work on a different distro? Knowing that would help identify if there’s a package already available in Nixpkgs for it, or if you’d need to write one yourself.
Also, what is the model of your wifi adapter? Searching up TP-LINK AX300 gives me a lot of USB adapters, which is difficult to narrow down with.
There isn’t a package in Nixpkgs, only the official driver that doesn’t work in NixOS (I also had problems with other distros)
The model is TP-LINK Archer TX1U Nano
