Wifi connectivity issues with NetworkManager & wpa_supplicant
I’m having trouble with my Wi-Fi. When I use command line tools like nmcli or nmtui to connect to Wi-Fi in the sway window manager, it says Wi-Fi network not found. However, when I’m using KDE, even though the command line tools still don’t work, I can connect to Wi-Fi directly through KDE settings. Here’s the status of the NetworkManager.service:
 Loaded: loaded (/etc/systemd/system/NetworkManager.service; enabled; preset: enabled)
    Drop-In: /nix/store/lrpj1rpa1x128538ldk2vy2c5xc4nmxg-system-units/NetworkManager.service>
             └─NetworkManager-ovs.conf, overrides.conf
     Active: active (running) since Sat 2023-09-09 22:37:01 EDT; 17min ago
       Docs: man:NetworkManager(8)
   Main PID: 865 (NetworkManager)
         IP: 9.6K in, 894B out
         IO: 10.1M read, 88.0K written
      Tasks: 4 (limit: 19072)
     Memory: 14.3M
        CPU: 1.928s
     CGroup: /system.slice/NetworkManager.service
             └─865 /nix/store/3m1cl7q6p0kxjj8aa6700dzdk7qqq5xh-networkmanager-1.42.8/sbin/Ne>
Sep 09 22:51:47 nixos NetworkManager[865]: <warn>  [1694314307.0871] device (wlp3s0): Activa>
Sep 09 22:51:47 nixos NetworkManager[865]: <warn>  [1694314307.0879] platform-linux: do-chan>
Sep 09 22:51:47 nixos NetworkManager[865]: <warn>  [1694314307.0883] device (wlp3s0): Activa>
Sep 09 22:51:50 nixos NetworkManager[865]: <warn>  [1694314310.9817] platform-linux: do-chan>
Sep 09 22:53:40 nixos NetworkManager[865]: <warn>  [1694314420.7303] platform-linux: do-chan>
Sep 09 22:53:40 nixos NetworkManager[865]: <warn>  [1694314420.8076] platform-linux: do-chan>
Sep 09 22:54:06 nixos NetworkManager[865]: <warn>  [1694314446.0870] device (wlp3s0): Activa>
Sep 09 22:54:06 nixos NetworkManager[865]: <warn>  [1694314446.0877] platform-linux: do-chan>
Sep 09 22:54:06 nixos NetworkManager[865]: <warn>  [1694314446.0882] device (wlp3s0): Activa>
Sep 09 22:54:09 nixos NetworkManager[865]: <warn>  [1694314449.9434] platform-linux: do-chan>
These are the logs for the NetworkManager service from journalctl.
I also attempted to use wpa_supplicant and set up my Wi-Fi networks declaratively, but the issue continues. With wpa_supplicant, the Wi-Fi connection isn’t even visible, although I can still connect through Ethernet. Here are the journal logs for wpa_supplicant.
Here is my wpa_supplicant section in configuration.nix file:
# enable wpa_supplicant
  66   │   networking.wireless.enable = true;
  67   │   networking.wireless.networks = {
  68   │
  69   │     "134Fennel" = {                # SSID with no spaces or special characters
  70   │       psk = "132Eennel";
  71   │       priority = 2;
  72   │     };
  73   │
  74   │     "Mohawk-WiFi" = {
  75   │       priority = 2;
  76   │       auth =
  77   │       ''
  78   │         eap=PEAP
  79   │         identity="userID"
  80   │         password="mypassword"
  81   │       '';
  82   │       extraConfig =
  83   │       ''
  84   │         phase2="auth=MSCHAPV2"
  85   │       '';
  86   │     };
  87   │   };
NixOS System:
  • system: "x86_64-linux"
  • host os: Linux 6.1.51, NixOS, 23.11 (Tapir), 23.11pre522946.0bffda19b8af
  • multi-user?: yes
  • sandbox: yes
  • version: nix-env (Nix) 2.17.0
  • channels(root): "nixos"
  • nixpkgs: /nix/var/nix/profiles/per-user/root/channels/nixos
