I got a new motherboard with an RTL 8922ae wifi chip, and from what I can tell, the drivers for it are in the rtl89 module, and that module should come standard in the kernel since version 5.16.[1]
However, when I add it to my module list, it gives back this output:
root module: rtl89
modprobe: FATAL: Module rtl89 not found in directory /nix/store/020lzs1bwrrgx1yv1jlprlsb3jbgkf3m-linux-6.6.79-modules/lib/modules/6.6.79
My relevant nix config is as follows when it fails:
hardware.enableRedistributableFirmware = true;
hardware.enableAllFirmware = true;
boot.initrd.availableKernelModules = [ "xhci_pci" "ahci" "nvme" "usbhid" "usb_storage" "sd_mod" "rtl89" ];
boot.kernelModules = [ "kvm-intel" "r8125" "rtl89" ];
#boot.blacklistedKernelModules = [ "rtl8xxxu" ];
boot.extraModulePackages = with config.boot.kernelPackages; [
rtl8812au
r8125
boot.initrd.kernelModules = [ "8812au" "r8125" "rtl89" ];
Am I missing something? I feel like maybe there’s a simple error here that I’m not catching. I’m using the LTS kernel with NixOS 24.11.
normally you should not need this module. I would recommend to take it out of the boot config in available KernelModules, kernelModules, extraModulePackages and initrd.kernelModules.
Than test it again.
My current configuration isn’t using the module in any of the config, since it won’t build with it there.
I can see the device is accurately identified in lspci
, but it doesn’t seem recognized at all otherwise. lsmod
and modprobe
don’t show the module, either.
ok that is strage. Can you post your config and your system specs? Especially which mainboard you got.
System info and relevant config below. I apologize that my config is a bit of a mess.
Edit: I’ll be heading to sleep after this post and will check back here in the morning to answer any questions.
System Info:
OS: NixOS 24.11 (Vicuna) x86_64
Host: X870E AORUS ELITE WIFI7 (Default string-CF-WCP-ADO)
Kernel: Linux 6.6.79
Display (QG241Y S): 1920x1080 @ 165 Hz in 28" [External] *
Display (R240HY): 1920x1080 @ 60 Hz in 24" [External]
CPU: AMD Ryzen 9 9950X (32) @ 5.75 GHz
GPU 1: AMD Radeon Graphics [Integrated]
GPU 2: NVIDIA GeForce RTX 3090 Ti [Discrete]
Memory: 27.25 GiB / 60.44 GiB (45%)
configuration.nix
{ config, pkgs, ... }:
imports =
./hardware-configuration.nix
./unstable.nix
#./garbage.nix
<home-manager/nixos>
# Bootloader.
boot.extraModulePackages = [ pkgs.linuxPackages.v4l2loopback ];
boot.supportedFilesystems = [ "ntfs" ];
boot.kernel.sysctl = {
"zswap.enabled" = 1;
"kernel.sysrq" = 1;
#boot.kernelPackages = pkgs.linuxPackages_latest;
nix = {
optimise = {
automatic = true;
dates = [ "08:30" ];
gc = {
automatic = true;
dates = "Sun 07:30:00";
options = "--delete-older-than 7d";
networking.hostName = "jamie-battlestation"; # Define your hostname.
networking.stevenblack.enable = true;
networking.nameservers = [ "9.9.9.9" "1.1.1.1" ];
#networking.wireless.enable = true; # Enables wireless support via wpa_supplicant.
# Enable networking
virtualisation.docker = {
daemon.settings.data-root = "/store/docker";
enableOnBoot = true;
enableNvidia = true;
hardware.nvidia-container-toolkit.enable = true;
virtualisation.libvirtd.enable = true;
virtualisation.libvirtd.qemu.swtpm.enable = true;
#systemd.enableUnifiedCgroupHierarchy = false;
# Set your time zone.
time.timeZone = "America/Chicago";
i18n.extraLocaleSettings = {
LC_ADDRESS = "en_US.UTF-8";
LC_IDENTIFICATION = "en_US.UTF-8";
LC_MEASUREMENT = "en_US.UTF-8";
LC_MONETARY = "en_US.UTF-8";
LC_NAME = "en_US.UTF-8";
LC_NUMERIC = "en_US.UTF-8";
LC_PAPER = "en_US.UTF-8";
LC_TELEPHONE = "en_US.UTF-8";
LC_TIME = "en_US.UTF-8";
services.locate.enable = true;
# Enable the GNOME Desktop Environment.
services.displayManager.sddm.enable = true;
services.xserver.desktopManager.plasma5.enable = true;
# Configure keymap in X11
services.xserver = {
xkb = {
variant = "";
layout = "us";
services.printing.enable = false;
# Enable sound with pipewire.
security.rtkit.enable = true;
services.pipewire = {
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
jack.enable = true;
#media-session.enable = true;
users.users.jamie = {
isNormalUser = true;
description = "Jamie";
extraGroups = [ "networkmanager" "wheel" "docker" ];
shell = pkgs.fish;
packages = with pkgs; [
firefox
fortune
thunderbird
home-manager.backupFileExtension = "backup";
home-manager.users.jamie = { pkgs, ... }: {
programs.fish.enable = true;
home.stateVersion = "23.11";
# Allow unfree packages
programs = with pkgs; {
noisetorch.enable = true;
java.enable = true;
steam.enable = true;
virt-manager.enable = true;
fish.enable = true;
mosh = {
openFirewall = false;
# $ nix search wget
anki
p7zip
(pkgs.wrapOBS {
plugins = with pkgs.obs-studio-plugins; [
obs-ndi
ndi
audacity
neofetch
du-dust
zoxide
mpv
cron
rnnoise-plugin
flameshot
rofi
qjackctl
mtr
htop
dool
neovim
git
wget
python312
mpv
vscode
go
appimage-run
gcc
spotify
pkgs.man-pages
pkgs.man-pages-posix
galculator
libreoffice-qt6-fresh
prismlauncher
qFlipper
davinci-resolve
ripdrag
fastfetch
feh
godot_4
utsushi
element-desktop
fd
fzf
gnumake
home-manager
rclone
xdotool
starsector
chromium
rustdesk-flutter
steam-run
neovide
nixpkgs.config.permittedInsecurePackages = [
"dotnet-runtime-7.0.20"
environment.variables.EDITOR = "nvim";
environment.variables.MAKEFLAGS = "-j6";
environment.variables.NIXPKGS_ALLOW_INSECURE = "1";
# started in user sessions.
# programs.mtr.enable = true;
# programs.gnupg.agent = {
# enable = true;
# enableSSHSupport = true;
# Enable the OpenSSH daemon.
services.openssh = {
settings = {
PasswordAuthentication = true;
PermitRootLogin = "no";
services.tailscale = {
openFirewall = true;
useRoutingFeatures = "both";
#extraUpFlags = [ "--ssh" "--advertise-exit-node" ];
#extraUpFlags = [ "--ssh" ];
# Open ports in the firewall.
networking.firewall.interfaces.tailscale0 = {
allowedTCPPorts = [ ];
allowedUDPPorts = [ ];
#networking.firewall.allowedUDPPorts = [ 5960 5961 5962 5963 5964 5965 5966 5967 5968 5969 ];
networking.firewall.enable = true;
system.stateVersion = "23.11"; # Did you read the comment?
fonts = {
enableDefaultPackages = true;
noto-fonts-cjk-sans
ubuntu_font_family
unifont
fontconfig = {
antialias = true;
defaultFonts = {
serif = [ "Ubuntu" ];
sansSerif = [ "Ubuntu" ];
monospace = [ "Ubuntu Source" ];
i18n.inputMethod = {
type = "fcitx5";
fcitx5.addons = with pkgs; [
fcitx5-mozc
fcitx5-gtk
{ config, lib, pkgs, modulesPath, ... }:
imports =
[ (modulesPath + "/installer/scan/not-detected.nix")
"/etc/nixos/nvidia.nix"
boot.initrd.availableKernelModules = [ "xhci_pci" "ahci" "nvme" "usbhid" "usb_storage" "sd_mod" ];
boot.kernelModules = [ "kvm-intel" "r8125" ];
rtl8812au
r8125
boot.initrd.kernelModules = [ "8812au" "r8125" ]; # 8812au - A USB wifi dongle
# r8125 - Ethernet module
fileSystems."/" =
{ device = "/dev/disk/by-uuid/7c37b5c2-7597-4189-aaa4-7e3935d6dc44";
fsType = "ext4";
fileSystems."/tmp" = {
device = "tmpfs";
fsType = "tmpfs";
options = [ "size=32G" "mode=1777" "strictatime" "nosuid" "nodev" ];
fileSystems."/home" = {
device = "/dev/disk/by-uuid/13fc85ab-32db-425b-971a-727cd6c138f6";
fsType = "ext4";
options = [ "noatime" ];
fileSystems."/store" = {
device = "/dev/disk/by-uuid/64f58ed5-7d33-42c8-99f0-c1a5de49a3dc";
fsType = "ext4";
fileSystems."/nix" = {
device = "/dev/disk/by-uuid/a3e79842-8c01-4006-a962-2137037aca7f";
fsType = "ext4";
fileSystems."/store/big" = {
device = "/dev/disk/by-uuid/38d6526c-c941-44c7-a859-bb0770344c97";
fsType = "btrfs";
options = [ "compress=zstd" "noatime" "autodefrag" ];
fileSystems."/store/nvme" = {
device = "/dev/disk/by-uuid/aa2428a7-8f2d-48bc-a834-5a3694f30d9a";
fsType = "ext4";
fileSystems."/boot" =
{ device = "/dev/disk/by-uuid/D143-8E40";
fsType = "vfat";
swapDevices = [ ];
# Enables DHCP on each ethernet and wireless interface. In case of scripted networking
# (the default) this is the recommended approach. When using systemd-networkd it's
# still possible to use this option, but it's recommended to use it in conjunction
# with explicit per-interface declarations with `networking.interfaces.<interface>.useDHCP`.
networking.useDHCP = lib.mkDefault true;
# networking.interfaces.enp0s31f6.useDHCP = lib.mkDefault true;
# networking.interfaces.enp6s0.useDHCP = lib.mkDefault true;
nixpkgs.hostPlatform = lib.mkDefault "x86_64-linux";
hardware.cpu.intel.updateMicrocode = lib.mkDefault config.hardware.enableRedistributableFirmware;
OK
First of all can you try this:
https://www.reddit.com/r/MSI_Gaming/comments/1ga8bn1/comment/mbh3rf3/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
Also get rid of the this in your config:
boot.kernelModules = [ "r8125" ];
rtl8812au
r8125
your should not need this. Further it can cause interference, especially the 8812au which is for a USB WIFI adapter.
I’ve been doing some testing. The motherboard thread doesn’t apply to me, but I’ve noticed something else that I didn’t pick up on when I initially made this thread. The rtw89 module isn’t the only module that is not present. If I remove all of that, neither the rtw89 nor the r8125 apply, and I am completely without networking unless I USB tether through my phone.
I’m going to try loading a NixOS LiveUSB and an Arch LiveUSB to see if they have networking on boot.
Edit 1: The wifi adapter is detected successfully on Arch LiveUSB, though the r8125 isn’t. This appears to be a known issue in the Arch community that requires an AUR package to resolve. Will test a NixOS LiveUSB once it downloads.
Edit 2: The NixOS LiveUSB had no network connectivity.
OK
So you want to use the wifi module from your mainboard and not need the dongle?
If that is the case can you do this:
https://www.reddit.com/r/gigabyte/comments/1geme4q/comment/lynk2gn/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
Also can you try to plug the dongle out for that?
The dongle hasn’t actually been used in quite some time, I’m using the r8125 ethernet driver with a 50ft cord. Though I have to install the driver manually and override it’s broken flag since it was also technically supposed to be mainlined in the 5.x kernels somewhere.
Update: Wifi appears to work out of the box on the Zen kernel, however the r8125 driver does not. r8125 in the repo also will not build on the Zen kernel, so it is wifi-only.
Sorry for my late response. Had some stuff going on.
But now I could do some research. So apparently your wifi module should work out of the box:
https://patchwork.kernel.org/project/linux-wireless/cover/20250108020955.14668-1-pkshih@realtek.com/
For your Ethernet connection, you should not need any driver for an Ethernet connection.
This could however be Bios related issue. So can you try doing a Bios update.
