Here are the actual messages i get during boot, that rtlwifi is not available.
Also my hardware configuration is. I also added “rtlwifi”, “rtlwifi_new” to kernel modules but no luck. hwinfo outputs the following.
12: PCI 300.0: 0282 WLAN controller
[Created at pci.386]
Unique ID: hAO_.kOSB13gZvM0
Parent ID: HnsE.cSCIHQdL1RD
SysFS ID: /devices/pci0000:00/0000:00:1c.5/0000:03:00.0
SysFS BusID: 0000:03:00.0
Hardware Class: network
Model: "Realtek RTL8723BE PCIe Wireless Network Adapter"
Vendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
Device: pci 0xb723 "RTL8723BE PCIe Wireless Network Adapter"
SubVendor: pci 0x103c "Hewlett-Packard Company"
SubDevice: pci 0x804c
Driver: "rtl8723be"
Driver Modules: "rtl8723be"
Device File: wlp3s0
Features: WLAN
I/O Ports: 0x3000-0x30ff (rw)
Memory Range: 0xa1100000-0xa1103fff (rw,non-prefetchable)
IRQ: 17 (no events)
HW Address: 64:78:4b:b9:77:84
Permanent HW Address: 30:30:56:77:G3:cb
Link detected: no
WLAN channels: 1 2 3 4 5 6 7 8 9 10 11 12 13
WLAN frequencies: 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472
WLAN encryption modes: WEP40 WEP104 TKIP CCMP
WLAN authentication modes: open sharedkey wpa-psk wpa-eap
Module Alias: "pci:v000010ECd0000B723sv0000103Csd0000804Cbc02sc80i00"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #19 (PCI bridge)
Thank you !
{ config, lib, pkgs, modulesPath, ... }:
imports = [ ];
# kernel modules
boot.initrd.availableKernelModules = [ "nvme" "xhci_pci" "ahci" "usbhid" "usb_storage" "sd_mod" ];
boot.blacklistedKernelModules = [ ];
boot.kernelModules = [ "kvm-intel" ];
boot.supportedFilesystems = [ "ntfs" ];
# file systems
fileSystems."/boot" = {
device = "/dev/disk/by-label/BOOT";
fsType = "vfat";
fileSystems."/" = {
device = "/dev/disk/by-label/nixos";
fsType = "ext4";
swapDevices = [ ];
nixpkgs.hostPlatform = lib.mkDefault "x86_64-linux";
powerManagement.cpuFreqGovernor = lib.mkDefault "powersave";
hardware.cpu.intel.updateMicrocode =
lib.mkDefault config.hardware.enableRedistributableFirmware;
