Hello,
My day’s been spent hitting my head against this technical wall and I can’t seem to break through it by happenstance.
My problem is simply that I can’t play audio through my functional 3-pin-headphones on my laptop (Chromebook) with its integrated jack, even though the laptop’s speakers work and outputting audio through USB-C to HDMI works.
I’m using pwvucontrol to configure my audio sources and outputs, and a perhaps unrelated odd behavior I noticed is that my laptop speakers crackle when I play audio through them, but also when I try to play audio through my headphones even though the speakers don’t output audio.
Another oddity in pwvucontrol that I don’t understand is the “Speaker” and “Headphones” port, where even if I switch my headphone output port to “Headphones” it does not work, and does not seem to do anything to laptop speaker output either (and they get reverted if I adjust audio via audio keys).
I’m using packages from channel 25.05 and my original installed NixOS version is 25.05.
Here’s my audio config in the configuration.nix file:
# Enable sound with pipewire.
security.rtkit.enable = true;
services.pipewire = {
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
#jack.enable = true;
#media-session.enable = true;
I also tried adding options snd_hd_intel model=headset-audio as a boot.extraModproeConfig but to no avail.
I’m not sure what other information I could provide that could be useful, so I’ll paste output from a few commands I’ve seen used in related threads:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sofglkda7219max [sof-glkda7219max], device 0: Speakers (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: sofglkda7219max [sof-glkda7219max], device 1: Headset (*) []
Subdevices: 1/1
card 0: sofglkda7219max [sof-glkda7219max], device 5: HDMI1 (*) []
Subdevices: 1/1
card 0: sofglkda7219max [sof-glkda7219max], device 6: HDMI2 (*) []
Subdevices: 1/1
card 0: sofglkda7219max [sof-glkda7219max], device 7: HDMI3 (*) []
Subdevices: 1/1
amixer -c0
Simple mixer control 'Headphone',0
Capabilities: volume pswitch
Playback channels: Front Left - Front Right
Capture channels: Front Left - Front Right
Limits: 0 - 63
Front Left: 63 [100%] [6.00dB] Playback [on]
Front Right: 63 [100%] [6.00dB] Playback [on]
Simple mixer control 'Headphone Gain Ramp',0
Capabilities: pswitch
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'Headphone Jack',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Headphone ZC Gain',0
Mono:
Front Left: Playback [off]
Front Right: Playback [off]
Simple mixer control 'ToneGen',0
Capabilities: volume volume-joined
Capture channels: Mono
Limits: 0 - 15
Mono: 0 [0%] [-45.00dB]
Simple mixer control 'ToneGen DTMF',0
Mono: Playback [off]
Simple mixer control 'ToneGen DTMF Key',0
Capabilities: enum
Items: '0' '1' '2' '3' '4' '5' '6' '7' '8' '9' 'A' 'B' 'C' 'D' '*' '#'
Item0: '0'
Simple mixer control 'ToneGen Off Time',0
Limits: 0 - 63
Mono: 1 [2%]
Simple mixer control 'ToneGen On Time',0
Limits: 0 - 63
Mono: 2 [3%]
Simple mixer control 'ToneGen Sinewave Gen Type',0
Capabilities: enum
Items: 'Sum' 'SWG1' 'SWG2' 'SWG1_1-Cos'
Item0: 'Sum'
Simple mixer control 'ToneGen Sinewave1 Freq',0
Limits: 0 - 65535
Mono: 5461 [8%]
Simple mixer control 'ToneGen Sinewave2 Freq',0
Limits: 0 - 65535
Mono: 16384 [25%]
Simple mixer control 'Sidetone',0
Capabilities: volume volume-joined pswitch pswitch-joined
Limits: 0 - 14
Mono: 14 [100%] [0.00dB] Playback [off]
Simple mixer control 'Line Out',0
Simple mixer control 'Mic',0
Limits: 0 - 7
Mono: 1 [14%] [0.00dB] Playback [off]
Simple mixer control 'IEC958',0
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'Playback Digital',0
Limits: 0 - 127
Front Left: 111 [87%] [0.00dB] Playback [off]
Front Right: 111 [87%] [0.00dB] Playback [off]
Simple mixer control 'Playback Digital Gain Ramp',0
Mono:
Simple mixer control 'Capture Digital',0
Limits: 0 - 127
Mono: 111 [87%] [0.00dB] Playback [off]
Simple mixer control 'Capture Digital Gain Ramp',0
Mono: Playback [on]
Simple mixer control 'Mixer In Mic',0
Simple mixer control 'Mixer Out FilterL DACL',0
Simple mixer control 'Mixer Out FilterR DACR',0
Simple mixer control 'Mixin',0
Limits: 0 - 15
Mono: 3 [20%] [0.00dB] Playback [off]
Simple mixer control 'Mixin Gain Ramp',0
Mono: Playback [on]
Simple mixer control 'Mixin ZC Gain',0
Simple mixer control 'ADC HPF Corner Audio',0
Capabilities: enum
Items: '2Hz' '4Hz' '8Hz' '16Hz'
Item0: '2Hz'
Simple mixer control 'ADC HPF Corner Voice',0
Capabilities: enum
Items: '2.5Hz' '25Hz' '50Hz' '100Hz' '150Hz' '200Hz' '300Hz' '400Hz'
Item0: '2.5Hz'
Simple mixer control 'ADC HPF Mode',0
Capabilities: enum
Items: 'Disabled' 'Audio' 'Voice'
Item0: 'Audio'
Simple mixer control 'ALC',0
Simple mixer control 'ALC Anticlip',0
Simple mixer control 'ALC Anticlip Step',0
Capabilities: enum
Items: '0.034dB/fs' '0.068dB/fs' '0.136dB/fs' '0.272dB/fs'
Item0: '0.034dB/fs'
Simple mixer control 'ALC Attack Rate',0
Capabilities: enum
Items: '7.33/fs' '14.66/fs' '29.32/fs' '58.64/fs' '117.3/fs' '234.6/fs' '469.1/fs' '938.2/fs' '1876/fs' '3753/fs' '7506/fs' '15012/fs' '30024/fs'
Item0: '7.33/fs'
Simple mixer control 'ALC Envelope Attack Rate',0
Capabilities: enum
Items: '1/4' '1/16' '1/256' '1/65536'
Item0: '1/4'
Simple mixer control 'ALC Envelope Release Rate',0
Capabilities: enum
Item0: '1/4'
Simple mixer control 'ALC Hold Time',0
Capabilities: enum
Items: '62/fs' '124/fs' '248/fs' '496/fs' '992/fs' '1984/fs' '3968/fs' '7936/fs' '15872/fs' '31744/fs' '63488/fs' '126976/fs' '253952/fs' '507904/fs' '1015808/fs' '2031616/fs'
Item0: '62/fs'
Simple mixer control 'ALC Max',0
Limits: 0 - 15
Mono: 15 [100%] [90.00dB]
Simple mixer control 'ALC Max Analog',0
Limits: 0 - 6
Mono: 6 [100%] [36.00dB]
Simple mixer control 'ALC Max Attenuation',0
Limits: 0 - 15
Simple mixer control 'ALC Max Threshold',0
Limits: 0 - 63
Mono: 63 [100%] [0.00dB]
Simple mixer control 'ALC Min Analog',0
Limits: 0 - 6
Mono: 0 [0%] [0.00dB]
Simple mixer control 'ALC Min Threshold',0
Limits: 0 - 63
Mono: 0 [0%] [-94.50dB]
Simple mixer control 'ALC Noise Threshold',0
Limits: 0 - 63
Simple mixer control 'ALC Release Rate',0
Capabilities: enum
Items: '28.66/fs' '57.33/fs' '114.6/fs' '229.3/fs' '458.6/fs' '917.1/fs' '1834/fs' '3668/fs' '7337/fs' '14674/fs' '29348/fs'
Item0: '28.66/fs'
Simple mixer control 'Charge Pump Threshold',0
Limits: 0 - 63
Mono: 14 [22%]
Simple mixer control 'Charge Pump Track Mode',0
Capabilities: enum
Items: 'Largest Volume' 'DAC Volume' 'Signal Magnitude'
Item0: 'DAC Volume'
Simple mixer control 'DAC EQ',0
Simple mixer control 'DAC EQ Band1',0
Limits: 0 - 15
Mono: 8 [53%] [1.50dB]
Simple mixer control 'DAC EQ Band2',0
Limits: 0 - 15
Simple mixer control 'DAC EQ Band3',0
Limits: 0 - 15
Simple mixer control 'DAC EQ Band4',0
Limits: 0 - 15
Simple mixer control 'DAC EQ Band5',0
Limits: 0 - 15
Simple mixer control 'DAC HPF Corner Audio',0
Capabilities: enum
Item0: '2Hz'
Simple mixer control 'DAC HPF Corner Voice',0
Capabilities: enum
Item0: '2.5Hz'
Simple mixer control 'DAC HPF Mode',0
Capabilities: enum
Item0: 'Audio'
Simple mixer control 'DAC NG',0
Simple mixer control 'DAC NG Off Threshold',0
Limits: 0 - 7
Mono: 0 [0%] [-102.00dB]
Simple mixer control 'DAC NG On Threshold',0
Limits: 0 - 7
Simple mixer control 'DAC NG Rampdown Rate',0
Capabilities: enum
Items: '0.88ms/dB' '14.08ms/dB'
Item0: '0.88ms/dB'
Simple mixer control 'DAC NG Rampup Rate',0
Capabilities: enum
Items: '0.22ms/dB' '0.0138ms/dB'
Item0: '0.22ms/dB'
Simple mixer control 'DAC NG Setup Time',0
Capabilities: enum
Items: '256 Samples' '512 Samples' '1024 Samples' '2048 Samples'
Item0: '256 Samples'
Simple mixer control 'DAC Soft Mute',0
Simple mixer control 'DAC Soft Mute Rate',0
Capabilities: enum
Items: '1 Sample' '2 Samples' '4 Samples' '8 Samples' '16 Samples' '32 Samples' '64 Samples'
Item0: '1 Sample'
Simple mixer control 'Gain Ramp Rate',0
Capabilities: enum
Items: 'Nominal Rate * 8' 'Nominal Rate' 'Nominal Rate / 8' 'Nominal Rate / 16'
Item0: 'Nominal Rate * 8'
Simple mixer control 'Headset Mic',0
Simple mixer control 'Out DACL Mux',0
Capabilities: enum
Items: 'ADC' 'Tone Generator' 'DAIL' 'DAIR'
Item0: 'DAIL'
Simple mixer control 'Out DACR Mux',0
Capabilities: enum
Item0: 'DAIR'
Simple mixer control 'Out DAIL Mux',0
Capabilities: enum
Item0: 'ADC'
Simple mixer control 'Out DAIR Mux',0
Capabilities: enum
Item0: 'Tone Generator'
Simple mixer control 'PGA1.0 1 Master',0
Capabilities: pvolume
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 Master',0
Mono:
Simple mixer control 'PGA3.0 3 Master',0
Capabilities: cvolume
Limits: Capture 0 - 80
Front Left: Capture 50 [62%] [0.00dB]
Front Right: Capture 50 [62%] [0.00dB]
Simple mixer control 'PGA4.0 4 Master',0
Simple mixer control 'PGA5.0 5 Master',0
Mono:
Simple mixer control 'PGA6.0 6 Master',0
Mono:
Simple mixer control 'PGA7.0 7 Master',0
Mono:
Simple mixer control 'ST Mixer Out FilterL Out FilterL',0
Mono: Playback [on]
Simple mixer control 'ST Mixer Out FilterL Out FilterR',0
Simple mixer control 'ST Mixer Out FilterL Sidetone',0
Simple mixer control 'ST Mixer Out FilterR Out FilterL',0
Simple mixer control 'ST Mixer Out FilterR Out FilterR',0
Mono: Playback [on]
Simple mixer control 'ST Mixer Out FilterR Sidetone',0
Simple mixer control 'Spk',0
Mono: Playback [on]
cat /proc/asound/cards
0 [sofglkda7219max]: sof-glkda7219ma - sof-glkda7219max
Google-Phaser360-rev3
cat /proc/asound/version
Advanced Linux Sound Architecture Driver Version k6.15.6.
lsmod | grep snd
snd_seq_dummy 16384 0
snd_hrtimer 16384 1
snd_seq 118784 7 snd_seq_dummy
snd_seq_device 20480 1 snd_seq
snd_soc_sof_da7219 24576 4
snd_soc_intel_sof_board_helpers 28672 1 snd_soc_sof_da7219
snd_soc_intel_hda_dsp_common 16384 1 snd_soc_intel_sof_board_helpers
snd_soc_intel_sof_maxim_common 32768 1 snd_soc_sof_da7219
snd_sof_probes 32768 0
snd_soc_dmic 12288 1
snd_sof_pci_intel_apl 16384 0
snd_sof_intel_hda_generic 40960 1 snd_sof_pci_intel_apl
soundwire_intel 94208 1 snd_sof_intel_hda_generic
snd_sof_intel_hda_sdw_bpt 24576 1 soundwire_intel
snd_sof_intel_hda_common 208896 3 snd_sof_intel_hda_sdw_bpt,snd_sof_intel_hda_generic,snd_sof_pci_intel_apl
snd_soc_hdac_hda 28672 1 snd_sof_intel_hda_common
snd_sof_intel_hda_mlink 36864 4 snd_sof_intel_hda_sdw_bpt,soundwire_intel,snd_sof_intel_hda_common,snd_sof_intel_hda_generic
snd_sof_intel_hda 20480 2 snd_sof_intel_hda_common,snd_sof_intel_hda_generic
snd_hda_codec_hdmi 90112 1
snd_sof_pci 24576 2 snd_sof_intel_hda_generic,snd_sof_pci_intel_apl
snd_sof_xtensa_dsp 16384 1 snd_sof_intel_hda_generic
snd_sof 495616 8 snd_sof_intel_hda_sdw_bpt,snd_soc_sof_da7219,snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_hda_generic,snd_soc_intel_sof_maxim_common,snd_sof_probes,snd_sof_intel_hda
snd_sof_utils 16384 1 snd_sof
snd_soc_acpi_intel_match 131072 3 snd_soc_intel_sof_board_helpers,snd_sof_intel_hda_generic,snd_sof_pci_intel_apl
snd_soc_acpi_intel_sdca_quirks 12288 1 snd_soc_acpi_intel_match
snd_soc_acpi 16384 2 snd_soc_acpi_intel_match,snd_sof_intel_hda_generic
snd_soc_sdca 57344 2 snd_soc_acpi_intel_sdca_quirks,soundwire_bus
snd_soc_avs 262144 0
snd_soc_hda_codec 28672 1 snd_soc_avs
snd_soc_da7219 98304 1
snd_soc_max98357a 16384 1
snd_hda_ext_core 36864 7 snd_sof_intel_hda_sdw_bpt,snd_soc_avs,snd_soc_hda_codec,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda_mlink,snd_sof_intel_hda
snd_hda_intel 69632 0
snd_soc_core 438272 13 snd_soc_avs,snd_soc_hda_codec,snd_soc_sof_da7219,snd_soc_da7219,soundwire_intel,snd_sof,snd_soc_intel_sof_board_helpers,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_intel_sof_maxim_common,snd_soc_max98357a,snd_sof_probes,snd_soc_dmic
snd_intel_dspcfg 40960 5 snd_soc_avs,snd_hda_intel,snd_sof,snd_sof_intel_hda_common,snd_sof_intel_hda_generic
snd_intel_sdw_acpi 16384 2 snd_intel_dspcfg,snd_sof_intel_hda_generic
snd_hda_codec 225280 7 snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_soc_intel_hda_dsp_common,snd_soc_hdac_hda,snd_sof_intel_hda
snd_compress 36864 3 snd_soc_avs,snd_soc_core,snd_sof_probes
ac97_bus 12288 1 snd_soc_core
snd_pcm_dmaengine 20480 1 snd_soc_core
snd_hda_core 151552 10 snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_intel_hda_dsp_common,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
snd_hwdep 24576 1 snd_hda_codec
snd_pcm 204800 15 snd_soc_avs,snd_hda_codec_hdmi,snd_hda_intel,snd_soc_da7219,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_compress,snd_sof_intel_hda_generic,snd_soc_core,snd_sof_utils,snd_soc_intel_sof_maxim_common,snd_hda_core,snd_pcm_dmaengine
snd_timer 57344 3 snd_seq,snd_hrtimer,snd_pcm
snd 159744 22 snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_soc_sof_da7219,snd_hda_codec,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_pcm
soundcore 20480 1 snd
I tried searching through the forums (and elsewhere) but couldn’t find this specific problem with Pipewire (and other solutions that I did try did not fix it).
