Hi, i have problem with monitor resolution.
i change to latest kernel(6.6) then rebuild my nixos and…
after reboot when enter to GUI mode(lightdm login) after boot log(cli) failed.
blank and on monitor onscreen display show message “wrong resolution, should use 1366x768 @60hz” and i cant enter to tty.
my monitor usually use 1366x768 @60hz
on my configuration.nix i use video driver “fbdev” because my GPU broken(artefak) if use intel driver. my GPU is intel.
my question is how to setting the proper resolution?
now, temporarily I use the default kernel channel unstable, it resolution configured automatically(use 1366x768 @60hz).
why is the Intel driver broken for you in the first place? It works great for me on my laptop.
Edit: You can switch to linuxPackages for boot.kernelPackages in your configuration instead of running the latest kernel. In all likelihood that is going to revert the change that affected you.
my cpu is Intel Core 2 6300 (2) @ 1.861GHz
GPU: Intel 4 Series Chipset (onboard)
Host: G41 Series
bios: American megatrend
desktop computer not laptop.
So this GPU is more or less like the ThinkPad T400. It should work with Intel drivers.
Apart from that: you most likely get no benefits from running a bleeding edge kernel. If you need to stay on the framebuffer driver, just stick with the older kernel and be happy as long as your machine runs.
