Hello dear Nix community. This is my first post, so any meta to what I could improve about the post itself is very welcome ![]()
I am trying to partition a new device with disko on my Raspi 5. The partitioning will use ZFS, so I want to load the kernel module on boot.
Unfortunately, adding zfs to the supported filesystems and the system packages does not seem to be enough. sudo modprobe zfs exits with modprobe: FATAL: Module zfs not found in directory /run/booted-system/kernel-modules/lib/modules/6.12.34. This persists after a nixos-rebuild switch and reboot.
Subsequently, formatting with disko fails as well. I already searched the NixOS Wiki, the internet and debugged with AI but to no avail.
My default.nix for this system is
config,
pkgs,
nixos-raspberrypi,
adminPublicKey = "...";
imports = with nixos-raspberrypi.nixosModules; [
./hardware-configuration.nix
raspberry-pi-5.base
raspberry-pi-5.page-size-16k
./pi5-configtxt.nix
# Binary cache with prebuilt packages for the currently locked `nixpkgs`,
# see `devshells/nix-build-to-cachix.nix` for a list
trusted-nix-caches
./disko-nvme-ext4.nix
# ./disko-data-zfs-single.nix
boot = {
loader.raspberryPi.bootloader = "kernel";
tmp.useTmpfs = true;
kernelParams = [
"zfs.zfs_arc_max=200000000" # 200MB
supportedFilesystems = [ "zfs" ];
tree
btop
zfs
# disko.devices.disk.data1.device = "/dev/sda";
# disko.devices.disk.data2.device = "/dev/sdb";
services.zfs.autoScrub.enable = true;
services.zfs.trim.enable = true;
networking = {
# for zfs, must be unique
hostId = "8821e001";
hostName = "maximus-zone-aprill";
useNetworkd = true;
# Allow mDNS
firewall.allowedUDPPorts = [ 5353 ];
# We run sshd by default. Login is only possible after adding a
# password via "passwd" or by adding a ssh key to ~/.ssh/authorized_keys.
# The latter one is particular useful if keys are manually added to
# installation device for head-less systems i.e. arm boards by manually
# mounting the storage in a different system.
services.openssh = {
settings.PermitRootLogin = "yes";
# allow nix-copy to live system
nix.settings.trusted-users = [ "nixos" ];
# We are stateless, so just default to latest.
system.stateVersion = config.system.nixos.release;
# Enable mDNS on all networks
systemd.network.networks = {
"99-ethernet-default-dhcp".networkConfig.MulticastDNS = "yes";
"99-wireless-client-dhcp".networkConfig.MulticastDNS = "yes";
# This comment was lifted from `srvos`
# Do not take down the network for too long when upgrading,
# This also prevents failures of services that are restarted instead of stopped.
# It will use `systemctl restart` rather than stopping it with `systemctl stop`
# followed by a delayed `systemctl start`.
systemd.services = {
systemd-networkd.stopIfChanged = false;
# Services that are only restarted might be not able to resolve when resolved is stopped before
systemd-resolved.stopIfChanged = false;
services.udev.extraRules = ''
# Ignore partitions with "Required Partition" GPT partition attribute
# On our RPis this is firmware (/boot/firmware) partition
ENV{ID_PART_ENTRY_SCHEME}=="gpt", \
ENV{ID_PART_ENTRY_FLAGS}=="0x1", \
ENV{UDISKS_IGNORE}="1"
And the root flake is
nixpkgs-unstable.url = "github:nixos/nixpkgs?ref=nixos-unstable";
nixpkgs.url = "github:nixos/nixpkgs?ref=nixos-25.05";
home-manager = {
url = "github:nix-community/home-manager/release-25.05";
home-manager-unstable = {
inputs.nixpkgs.follows = "nixpkgs-unstable";
auto-cpufreq = {
url = "github:AdnanHodzic/auto-cpufreq";
nixpkgs-raspi.url = "github:nvmd/nixpkgs/modules-with-keys-25.05";
nixos-raspberrypi = {
url = "github:nvmd/nixos-raspberrypi/main";
inputs.nixpkgs.follows = "nixpkgs-raspi";
disko = {
url = "github:nix-community/disko";
sops-nix = {
url = "github:Mic92/sops-nix";
nixos-images = {
url = "github:nvmd/nixos-images/sdimage-installer";
inputs.nixos-stable.follows = "nixpkgs";
inputs.nixos-unstable.follows = "nixpkgs";
treefmt-nix = {
url = "github:numtide/treefmt-nix";
nixos-hardware.url = "github:nixos/nixos-hardware/master";
nixConfig = {
extra-substituters = [ "https://nixos-raspberrypi.cachix.org" ];
extra-trusted-public-keys = [
"nixos-raspberrypi.cachix.org-1:4iMO9LXa8BqhU+Rpg6LQKiGa2lsNh/j2oiYLNOQ5sPI="
outputs =
self,
nixpkgs,
nixpkgs-unstable,
home-manager,
home-manager-unstable,
auto-cpufreq,
nixpkgs-raspi,
nixos-raspberrypi,
disko,
sops-nix,
nixos-images,
treefmt-nix,
nixos-hardware,
}@inputs:
nixosConfigurations = {
maximusZoneAprilL = nixos-raspberrypi.lib.nixosSystemFull {
specialArgs = inputs;
modules = [
# Disk configuration
disko.nixosModules.disko
./maximus-zone-april-l
(import ./common/nix.nix {
trustedUsers = [
"root"
"nixos"
And the Disko config I am trying to apply is
poolName = "tank1";
disko.devices = {
disk = {
data1 = {
type = "disk";
content = {
type = "gpt";
partitions = {
zfs = {
size = "100%";
content = {
type = "zfs";
pool = "${poolName}";
zpool = {
"${poolName}" = {
type = "zpool";
mode = "mirror";
rootFsOptions = {
compression = "zstd";
"com.sun:auto-snapshot" = "true";
postCreateHook = "zfs list -t snapshot -H -o name | grep -E '^${poolName}@blank$' || zfs snapshot ${poolName}@blank";
datasets = {
# From NixOS wiki: On ZFS, the performance will deteriorate significantly when more than 80% of the available space is used.
# To avoid this, reserve disk space beforehand.
reserved = {
type = "zfs_fs";
mountpoint = "/${poolName}/reserved";
options = {
quota = "10G";
encrypted = {
type = "zfs_fs";
mountpoint = "/${poolName}";
options = {
encryption = "aes-256-gcm";
keyformat = "passphrase";
keylocation = "file:///tmp/secret.key";
# use this to read the key during boot
postCreateHook = ''
zfs set keylocation="prompt" "${poolName}/encrypted";
Can you help me? What am I missing?
The NixOS wiki mentions something about ZFS not being part of all linux kernels. Could this be the issue?
