Permission issue when attempting to use an alternate webui for Transmission
Hi everyone.
I want to replace the default webui of Transmission with something like Flood. I couldn’t find a NixOS option for this so I’ve turned to the manual method of setting the enviroment variable TRANSMISSION_WEB_HOME. NixOS seems to export this variable as expected however when accessing the webui Transmission claims it does not have permission to read the files. I have run chown -R media:media and chmod -r 777 on the webui folder and ls -l /var/lib/transmission/web confirms the files should be accessible:
Permissions Size User  Date Modified Name
drwxrwxrwx     - media 18 apr 20:04  build
drwxrwxrwx     - media 18 apr 20:04  fonts
drwxrwxrwx     - media 18 apr 20:04  images
drwxrwxrwx     - media 18 apr 20:04  style
.rwxrwxrwx  1,3k media 18 apr 20:04  index.html
.rwxrwxrwx  2,2k media 18 apr 20:04  sw.js
.rwxrwxrwx   14k media 18 apr 20:04  workbox-d249b2c8.js
.rwxrwxrwx    25 media 18 apr 20:04  config.json
.rwxrwxrwx  3,8k media 18 apr 20:04  sw.js.map
.rwxrwxrwx  137k media 18 apr 20:04  workbox-d249b2c8.js.map
.rwxrwxrwx   477 media 18 apr 20:04  manifest.webmanifest
.rwxrwxrwx   238 media 18 apr 20:04  browserconfig.xml
● transmission.service - Transmission BitTorrent Service
     Loaded: loaded (/etc/systemd/system/transmission.service; enabled; preset: enabled)
     Active: active (running) since Sun 2023-06-04 16:59:12 CEST; 6min ago
    Process: 41076 ExecStartPre=/nix/store/98smy0izzn1sgxagy8j6yqfa8jwyi5hi-transmission-prestart (code=exited, status=0/SUCCESS)
   Main PID: 41080 (transmission-da)
         IP: 21.7K in, 12.9K out
         IO: 0B read, 4.0K written
      Tasks: 3 (limit: 9414)
     Memory: 18.6M
        CPU: 320ms
     CGroup: /system.slice/transmission.service
             └─41080 /nix/store/1lsdzdw5crv70928dpzsm7swp8ixyi2b-transmission-3.00/bin/transmission-daemon -f -g /var/lib/transmission/.config/transmission-daemon
jun 04 16:59:13 helios transmission-daemon[41080]: [2023-06-04 16:59:13.722] Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (/build/source/libtransmission/natpmp.c:73)
jun 04 16:59:21 helios transmission-daemon[41080]: [2023-06-04 16:59:21.720] Port Forwarding State changed from "Not forwarded" to "Starting" (/build/source/libtransmission/port-forwarding.c:106)
jun 04 16:59:21 helios transmission-daemon[41080]: [2023-06-04 16:59:21.720] Port Forwarding (NAT-PMP) readnatpmpresponseorretry succeeded (0) (/build/source/libtransmission/natpmp.c:73)
jun 04 16:59:21 helios transmission-daemon[41080]: [2023-06-04 16:59:21.720] Port Forwarding (NAT-PMP) Found public address "176.10.146.132" (/build/source/libtransmission/natpmp.c:138)
jun 04 16:59:21 helios transmission-daemon[41080]: [2023-06-04 16:59:21.720] Port Forwarding (NAT-PMP) sendnewportmappingrequest succeeded (12) (/build/source/libtransmission/natpmp.c:73)
jun 04 16:59:21 helios transmission-daemon[41080]: [2023-06-04 16:59:21.720] Couldn't read "/var/lib/transmission/web/index.html": Permission denied (/build/source/libtransmission/utils.c:286)
jun 04 16:59:21 helios transmission-daemon[41080]: [2023-06-04 16:59:21.720] Port Forwarding (NAT-PMP) Port 51413 forwarded successfully (/build/source/libtransmission/natpmp.c:222)
jun 04 16:59:21 helios transmission-daemon[41080]: [2023-06-04 16:59:21.720] Port Forwarding State changed from "Starting" to "Forwarded" (/build/source/libtransmission/port-forwarding.c:106)
jun 04 17:05:57 helios transmission-daemon[41080]: [2023-06-04 17:05:57.718] Couldn't read "/var/lib/transmission/web/index.html": Permission denied (/build/source/libtransmission/utils.c:286)
Any ideas what’s causing this and how I can resolve it?
NixOS Transmission config:
{pkgs, ...}: {
  boot.kernel.sysctl."net.core.wmem_max" = 1048576;
  systemd.services.transmission = {
    serviceConfig = {
      BindPaths = ["/DATA"];
    environment = {TRANSMISSION_WEB_HOME = "/var/lib/transmission/web";};
    user = "media";
    group = "media";
    performanceNetParameters = true;
    openPeerPorts = true;
    openRPCPort = true;
    home = "/var/lib/transmission";
    settings = {
      alt-speed-up = 10;
      rpc-port = 7000;
      alt-speed-down = 150;
      blocklist-enabled = true;
      blocklist-url = "https://github.com/sahsu/transmission-blocklist/releases/latest/download/blocklist.gz";
      rpc-bind-address = "0.0.0.0";
      rpc-whitelist-enabled = false;
      peer-port = 51413;
      incomplete-dir-enabled = true;
      incomplete-dir = "/DATA/D4/TM/incomplete";
      download-dir = "/DATA/D4/TM/complete";
      download-queue-enabled = true;
      download-queue-size = 10;
      idle-seeding-limit = 20;
      idle-seeding-enabled = true;
      ratio-limit-enabled = true;
      ratio-limit = 5;
      umask = 2;
It’s due to the hardening of the service: transmission only has access to services.transmission.home, /etc, /run and /nix/store.
I think the proper solution would be
environment.TRANSMISSION_WEB_HOME = pkgs.fetchzip
  { url = "https://github.com/johman10/flood-for-transmission/releases/download/latest/flood-for-transmission.zip";
    sha256 = "alsHOTF8EEF7iUNHvLC21V3VRVoYQSs78g2r7YGTDeQ=";
The result is accessible read-only from the Nix store, so it should work.
Useful to know, thanks. Also explains a similar issue I was having with completed torrents.
Unfortunately this still results in permission denied:
jun 04 19:22:02 helios transmission-daemon[49444]: [2023-06-04 19:22:02.472] Couldn't read "/nix/store/scx2r70fqv5wd4s8l9kixpnfs8c1b3p7-source/index.html": Permission denied (/build/source/libtransmission/utils.c:286)
I’m not sure… the /nix/store should be allowed: transmission wouldn’t be able to start otherwise. What does this shows?
systemctl cat transmission | grep Bind
BindPaths=/var/lib/transmission/.config/transmission-daemon
BindPaths=/DATA/D4/TM/complete
BindPaths=/DATA/D4/TM/incomplete
BindPaths=/DATA
BindReadOnlyPaths=/nix/store
BindReadOnlyPaths=/etc
BindReadOnlyPaths=/run
Transmission also seems to do some apparmor things, maybe that’s getting in the way? I don’t think it’s enabled by default, though.
Disabling apparmor solved it. Thank you!
Certainly one way to fix it, but you could probably also just fix the apparmor config to include that path: https://github.com/NixOS/nixpkgs/blob/c37ca420157f4abc31e26f436c1145f8951ff373/nixos/modules/services/torrent/transmission.nix#L464
That said, not much experience with apparmor myself.
My workaround was to use an overlay to copy it to the existing web directory (in addition to setting TRANSMISSION_WEB_HOME:
{ pkgs, ... }:
  flood = pkgs.fetchzip {
    url =
      "https://github.com/johman10/flood-for-transmission/releases/download/2023-04-18T18-03-53/flood-for-transmission.zip";
    hash = "sha256-alsHOTF8EEF7iUNHvLC21V3VRVoYQSs78g2r7YGTDeQ=";
  nixpkgs.overlays = [
    (self: super: {
      transmission = super.transmission.overrideAttrs (old: {
        postInstall = old.postInstall + ''
          cp -R ${flood} $out/share/transmission/web/flood
  systemd.services.transmission.environment.TRANSMISSION_WEB_HOME =
    "${pkgs.transmission}/share/transmission/web/flood";
Edit: You might as well replace the original web UI if you’re overriding the package. Then you don’t need to set TRANSMISSION_WEB_HOME:
{ pkgs, ... }:
    url =
    (self: super: {
          rm -rf $out/share/transmission/web
