The setting to toggle single/double click behavior isn’t built into Dolphin itself. Rather, it’s configured globally for the entire plasma desktop. If you’re actually using KDE Plasma as your DE, you can simply change it in the graphical system settings app. I’m not using plasma, so I manually updated ~/.config/kdeglobals, with the following text:
[KDE]
SingleClick=true
However, without plasma, the changes won’t automatically apply to Dolphin. I needed to take another couple extra steps:
- Install
kdePackages.plasma-integration
- Set the environment variable
QT_QPA_PLATFORMTHEME='kde'
Putting it all together, here’s the home manager setup I came up with:
home.packages = with pkgs.kdePackages; [
dolphin
breeze # Nice to have for theming
plasma-integration
home.file."${config.xdg.configHome}/kdeglobals".text = ''
[KDE]
SingleClick=true
Now, executing QT_QPA_PLATFORMTHEME='kde' dolphin, I’m able to enter directories without double-clicking.
Update: I’ve moved this configuration to a system module (rather than Home Manager) and added support for opening files in their appropriate application when clicked.
{ config, pkgs, lib, ... }:
# NOTE: This file contains somewhat horrifying workarounds for proper file assocation and 1-click open functionality
# Based on the following commit, with edits:
# https://github.com/rumboon/dolphin-overlay/commit/f2a50da28161b1ed96a7999a5ce570f80392543a
pkgsDolphinOverlay = pkgs.extend (final: prev: {
kdePackages = prev.kdePackages.overrideScope (kfinal: kprev: {
dolphin = prev.symlinkJoin {
name = "dolphin-wrapped";
paths = [ kprev.dolphin ];
nativeBuildInputs = [ prev.makeWrapper ];
# Set XDG_CONFIG_DIRS to ensure environment.etc configs are respected
# Set QT_QPA_PLATFORMTHEME for 1-click open
# Run kbuildsycoca6 for file assocation MIME type cache
postBuild = ''
rm $out/bin/dolphin
makeWrapper ${kprev.dolphin}/bin/dolphin $out/bin/dolphin \
--set XDG_CONFIG_DIRS "/etc/xdg/:$XDG_CONFIG_DIRS" \
--set QT_QPA_PLATFORMTHEME "kde" \
--run "${kprev.kservice}/bin/kbuildsycoca6"
environment.systemPackages = with pkgsDolphinOverlay.kdePackages; [
dolphin
# For mounting drives within Dolphin
kio
kio-fuse
kio-extras
kio-admin
# For the integrated terminal panel
konsole
# For 1-click open
plasma-integration
# For 1-click open
environment.etc."xdg/kdeglobals".text = ''
[KDE]
SingleClick=true
[UiSettings]
ColorScheme=*
# For file assocations
# Based on the following commit:
# https://github.com/qweered/hyprnixos/commit/d53c18bdf51838b8268de282d25bdfc1bbfcdf39
environment.etc."xdg/menus/applications.menu".source = ./dolphin.menu;
If you use this configuration, be sure to drop the dolphin.menu in the same directory as the module: https://raw.githubusercontent.com/qweered/hyprnixos/d53c18bdf51838b8268de282d25bdfc1bbfcdf39/modules/system/dolphin.menu
See https://github.com/NixOS/nixpkgs/issues/409986#issuecomment-3931363516
I found a way without needing the pre-rendered dolphin.menu file.
"${pkgs.kdePackages.plasma-workspace}/etc/xdg/menus/plasma-applications.menu";
