Not a traditional job, but a small bounty.
A friend gave me access to his database(Progress OpenEdge) through odbc.
But I’m unable to package it in nix.
I could use some help.
https://discourse.nixos.org/t/packaging-odbc-driver-for-progress
Hi,
Not fully there yet, but I managed to run the command proinst _overly using the following shell.nix:
pkgs = import <nixpkgs> {};
unixodbc-progress-openedge = pkgs.stdenv.mkDerivation {
name = "OpenEdge";
src = ./PROGRESS_OE_12.2_LNX_64_SQLCLIENTACCESS.tar.gz;
sourceRoot = ".";
installPhase = ''
mkdir -p $out/bin
mv JavaVersion.ini JvmProperties.class common dbtools env-vars icupsc inst_hlp install.tab installd.ini intlsets.txt itermcap juniper namesvr perl pmame progress.cfg proinst proupdt secclnt seccmn sqlcom sqljdbc sqlodbc wscmn $out/bin
mv _ovrly $out/bin
autoPatchelfHook
buildInputs = with pkgs; [
stdenv.cc.cc.lib
unzip
in with pkgs;
name = "project-depending-on-unixODBC-cache";
buildInputs = [
nix-shell shell.nix --command " TERM=xterm proinst _ovrly"
I hope this helps a bit.
I looked at the other archive, it ships a 11MB binary script that tries to figure out your entire system to install its requirement. That looks really difficult to package for nixos …
Maybe this route could work.
If I run the installer once and extract the necessary files and add those to my declarative nixos config.
I was able to run it and answer the promps. It placed many files on the system.
I think the relevant folder is:
├── bin
│ └── pgtestlib
├── fixes.txt
├── ICULicense.txt
├── include
│ ├── license.txt
│ ├── odbcinst.h
│ ├── qesqlext.h
│ ├── sqlext.h
│ ├── sql.h
│ ├── sqltypes.h
│ ├── sqlucode.h
│ └── sqlunx.h
├── lib
│ ├── libodbcinst.so
│ ├── libodbc.so
│ ├── libpgicu27.so
│ ├── libpgmback.so
│ ├── libpgssl27.so
│ ├── odbccurs.so
│ ├── pgoe27.so
│ ├── pgtrc27.so
│ └── vscnctdlg.so
├── locale
│ └── en_US
│ └── LC_MESSAGES
│ ├── odbc.m
│ ├── odbc.po
│ ├── pgmback.mo
│ ├── pgmback.po
│ ├── pgoe27.mo
│ └── pgoe27.po
├── NOTICES.TXT
├── ODBC64README.TXT
├── PGODBC.LIC
└── samples
├── demo
│ ├── demoodbc
│ ├── demoodbc.c
│ ├── driver_connect
│ ├── driver_connect.cc
│ └── Makefile
└── example
├── example
├── example64.txt
├── example.c
├── example.h
├── example.mak
└── odbc.ini
I tried using libodbc.so directly as a driver in an odbc connection,
{:ok,_ref} = :odbc.connect(~c"Driver=/persist/progress/d/odbc/lib/libodbc.so;Server=192.168.1.2;Port=12345;Database=XYZ;Uid=readname;Pwd=pass123",[])
but it didn’t work.
** (MatchError) no match of right hand side value: {:error, ~c"[unixODBC][Driver Manager]Can't open lib '/persist/progress/d/odbc/lib/libodbc.so' : file not found SQLSTATE IS: 01000 Connection to database failed."}
I guess it needs to be packaged and added to unixodbc?
It does build, but I keep getting the same error?
** (MatchError) no match of right hand side value: {:error, ~c"[unixODBC][Driver Manager]Can't open lib '/nix/store/7pw0fjsayfi4m53nf069b17knq8kbm3c-progress-openedge-odbc-driver-12.2/lib/pgoe27.so' : file not found SQLSTATE IS: 01000 Connection to database failed."}
stdenv,
lib,
unixODBC,
openssl,
stdenv.mkDerivation rec {
pname = "progress-openedge-odbc-driver";
version = "12.2";
src = ./progress-odbc.tar.gz;
# Work around the "unpacker appears to have produced no directories"
# case that happens when the archive doesn't have a subdirectory.
sourceRoot = ".";
installPhase = ''
runHook preInstall
mkdir -p $out/lib
cp -r lib/* $out/lib
runHook postInstall
postFixup = ''
echo "---postFixup---"
patchelf --set-rpath ${
lib.makeLibraryPath [
unixODBC
openssl
stdenv.cc.cc
$out/lib/pgoe27.so
passthru = {
fancyName = "ProgressOpenedgeDriver";
driver = "lib/pgoe27.so";
meta = with lib; {
description = "ODBC driver for Progress OpenEdge";
homepage = "http://progress.com";
license = licenses.unfree;
platforms = platforms.linux;
config,
lib,
pkgs,
with lib;
config = {
unixODBC
pkgs.lun.progress-openedge-odbc-driver
environment.unixODBCDrivers = with pkgs; [
unixODBCDrivers.psql
Assuming the file path named in the ‘file not found’ message does actually exist, it probably needs to be patchelf’d. That’s a frequent cause of mysterious ‘file not found’ messages. I see you’re only patching pgoe27.so; you should probably instead add autoPatchelfHook to the nativeBuildInputs of your derivation, which should seek out and patch all of the libraries in your derivation.
Thank you, I added autoPatchelfhook.
Could add most inputs except for 1.
I think libXm is not in nixpkgs.
> auto-patchelf: 2 dependencies could not be satisfied
> error: auto-patchelf could not satisfy dependency libXm.so.3 wanted by /nix/store/4ygggry27pwq9sl7nz9hyi9zdg5a0df6-progress-openedge-odbc-driver-12.2/lib/vscnctdlg.so
> error: auto-patchelf could not satisfy dependency libXm.so.3 wanted by /nix/store/4ygggry27pwq9sl7nz9hyi9zdg5a0df6-progress-openedge-odbc-driver-12.2/lib/libpgmback.so
for now I removed
rm $out/lib/vscnctdlg.so
rm $out/lib/libpgmback.so
It seems they’re not necessary.
I no longer get the ‘not found’ error
I hope this error is because my connection string isn’t according to their standard. I’ll have a look
** (MatchError) no match of right hand side value: {:error, ~c"[DataDirect][ODBC 20101 driver]6015[DataDirect][ODBC 20101 driver]6013 SQLSTATE IS: 60 Connection to database failed."}
(stdlib 6.1.2) erl_eval.erl:652: :erl_eval.expr/6
iex:6: (file)
FYI libXm seems to be in motif package.
Bounty was split in 2.
Thank you all.
