25.11 upgrade stuck on python3.11-aioquic-1.2.0 build failure
Is it just me or why I can’t upgrade my nixos cause it stuck with failed to build error:
error: Cannot build '/nix/store/rxhidgspf86sjwd4lj35a294hfcf5asd-python3.11-aioquic-1.2.0.drv'.
Is there a way to backtrack what programs depends on it cause it’s quite old me think.
What’s the output of
nixos-rebuild build --show-trace |& grep 'while evaluating derivation'
It’s fixed now, thanks for the tips.
Yes, it was fixed by ceph: remove unused dependency from httpcore by dotlambda · Pull Request #466339 · NixOS/nixpkgs · GitHub most likely.
