End of the installer of nix package manager say to run:
$ nix-shell -p nix-info --run “nix-info -m”
And it gave me:
these 49 paths will be fetched (65.92 MiB download, 342.49 MiB unpacked):
/nix/store/ndaag5w95krszi6g7c8jsddhd0agdhar-acl-2.3.2
/nix/store/lg6iq8irnjadx6274aqk96jzmkp51hr4-attr-2.5.2
Why is it installing 340mb?
Is that a 1time install for being 1st time running the nix-shell command?
Hello there!
I don’t know why the installer asks you to run the command, but here’s what it does (taken from the manpages):
nix-shell
: Start an interactive shell based on a Nix expression. A nix-shell will temporarily modify your $PATH environment variable. This can be used to try a piece of software before deciding to permanently install it.
-p nix-info
option: Set up a temporary environment in which the package nix-info
is present and can be used (-p
is shorthand for --packages
--run "nix-info -m"
: executes the command “nix-info -m” in the shell, provided by the nix-info
package
nix-info -m
: shows high level system info (like system architecture, host OS, Nix version)
By the way, don’t worry about the additional 342 MB - they will be removed from the Nix Store the next time you do a nix-collect-garbage
