A question about consistent installation of fonts
Hi all,
I have grouped my fonts in my /etc/nixos/configuration.nix like this:
fonts.packages = with pkgs; [
  # — Monospace (coding)
  jetbrains-mono
  maple-mono.truetype
  atkinson-monolegible
  julia-mono
and it works. But I can’t add libertinus inside that array and I have to group it with the rest of my packages:
  libertinus
What is causing this dichotomy?
PS: are these errors harmless when installing input-fonts:
Parsing 'GPOS' table...
Parsing 'GSUB' table...
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
Dumping "/nix/store/dspy1a7my14njvhd0sfjsk761i1cv9nd-input-fonts-1.2/Input_Fonts/InputSans/InputSans/InputSans-ExtraLightItalic.ttf" to "/nix/store/dspy1a7my14njvhd0sfjsk761i1cv9nd-input-fonts-1.2/Input_Fonts/InputSans/InputSans/InputSans-ExtraLightItalic.ttx"...
Dumping 'GlyphOrder' table...
Thanks in advance.
What goes wrong?
Well it’s a “list”, but also, that doesn’t make sense.
fonts.packages also just adds to environment.systemPackages underneath. But it does some extra work to make sure the font is actually visible on your system - most importantly this:
I don’t think what you’re saying is possible - if nix evals it in one it’ll eval in the other. Also, it works on my machine.
Typo probably?
@rhendric @waffle8946
Thanks all. Looks like it was a typo.
