A shell script and a Nix expression in the same file
let _=''1
# shell script starts here
echo "I am a shell script"
echo "followed by a Nix expression."
exit
''; in
# nix expression starts here
	This = "is a Nix expression";
	after = "a shell script.";
$ nix eval --file default.nix
{ This = "is a Nix expression"; after = "a shell script."; }
$ bash default.nix
I am a shell script
One caveat is that it would be painful if you want to use ${...} in the script though. If the string interpolation ${...} in bash does not have special characters, you can use unquoted ''${...}.
Update: With this version, you can have variables that are both accessible from Bash and from Nix, and there is a variable that you can refer to in Bash to get the contents of the Nix expression, and also a variable that you can refer to in Nix to get the contents of the Bash script.
#!/usr/bin/env bash
let _=0;
commonVariable="I can be accessed in both the shell script and the Nix expression";
__='';nixExpression="$(cat <<'NIX_EXPRESSION' | sed '1d;$d'
'';finalAttrs=
	inherit commonVariable bashScript;
;___=''
NIX_EXPRESSION
)";_='';bashScript=''
echo "I am a shell script followed by a Nix expression."
echo "The common variable is: $commonVariable"
echo "The Nix expression is: $nixExpression"
exit
'';in finalAttrs
$ ./default.nix
The common variable is: I can be accessed in both the shell script and the Nix expression
$ nix eval --file default.nix --json | jq
  "This": "is a Nix expression",
  "bashScript": "\necho \"I am a shell script followed by a Nix expression.\"\necho \"The common variable is: $commonVariable\"\necho \"The Nix expression is: $nixExpression\"\n\nexit\n",
  "commonVariable": "I can be accessed in both the shell script and the Nix expression"
Cool! Would even work with a #!/usr/bin/env bash or other suitable shebang at the beginning, with +x.
Here’s a version that fixes the ${…} issue:
#!/usr/bin/env bash
let _=1;
__=/*
echo "hello, ${USER}"
exit
*/_;
{ nix = "cool"; }
This construction also lets you have the script in scope, if you want, but you have to be a bit careful about ${…} (it’ll parameter expand if it contains spaces).
#!/usr/bin/env bash
let _=1;
script=''
echo hello, ''${USER}
exit
{ nix = "cool"; inherit script; }
Nice! I initially wanted to use the multiline comment but did not come up with something like this.
I did something similar a while back this way:
if false && /*;then :;fi # */ false then null else /*
echo Bash script goes here
: <<'EONix' # */
{ foo = "Nix expression goes here"; }
EONix
The only real caveat is that you have to be careful of putting */ into the bash section.
Here’s a flake:
#!/usr/bin/env bash
{# 2>/dev/null
  outputs=attrs@{...}:let
  _=/*
  exit
  */_;
  { nix = "cool"; };
