Able to run program from shell, systemd unit fails
Hi all. I’m relatively new to NixOS and I’ve run into this problem I cannot figure out on my own:
What are the differences when running a command from the shell vs running it from a systemd unit?
I’m trying to run a Pleroma instance. I am able to run it on the shell when logged in as the pleroma user. However, when I try to run it via a ported systemd unit, I am getting errors.
Here is the relevant section of /etc/nixos/configuration.nix:
    systemd.services.pleroma_backend = {
    description = "Pleroma Backend";
    after = [ "network.target" "postgresql.service" ];
    environment = {
      HOME = "/home/pleroma";
      MIX_ENV = "prod";
    serviceConfig = {
      User = "pleroma";
      WorkingDirectory = "/home/pleroma/pleroma";
      ExecStart = "${pkgs.elixir}/bin/elixir -S ${pkgs.elixir}/bin/mix phx.server";
      ExecReload = "/run/current-system/sw/bin/kill $MAINPID";
      KillMode = "process";
      Restart = "on-failure";
And the output of systemctl cat pleroma_backend:
# /nix/store/pa1q1cwbgsxl9ylc8al38gpp1klc4qcj-unit-pleroma_backend.service/pleroma_backend.service
[Unit]
After=network.target postgresql.service
Description=Pleroma Backend
[Service]
Environment="HOME=/home/pleroma"
Environment="LOCALE_ARCHIVE=/nix/store/vg0s4sl74f5ik64wrrx0q9n6m48vvmgs-glibc-locales-2.26-131/lib/locale/locale-archive"
Environment="MIX_ENV=prod"
Environment="PATH=/nix/store/cb3slv3szhp46xkrczqw7mscy5mnk64l-coreutils-8.29/bin:/nix/store/364b5gkvgrm87bh1scxm5h8shp975n0r-findutils-4.6.0/bin:/nix/store/s63b2myh6rxfl4aqwi9yxd6rq66djk33-gnugrep-3.1/bin:/nix/store/navldm477k3ar6cy0zlw9rk43i459g69-gnused-4.4/bin:/nix/store/f9dbl8y4zjgr81hs3y3zf187rqv83apz-systemd-237/bin:/nix/store/cb3slv3szhp46xkrczqw7mscy5mnk64l-coreutils-8.29/sbin:/nix/store/364b5gkvgrm87bh1scxm5h8shp975n0r-findutils-4.6.0/sbin:/nix/store/s63b2myh6rxfl4aqwi9yxd6rq66djk33-gnugrep-3.1/sbin:/nix/store/navldm477k3ar6cy0zlw9rk43i459g69-gnused-4.4/sbin:/nix/store/f9dbl8y4zjgr81hs3y3zf187rqv83apz-systemd-237/sbin"
Environment="TZDIR=/nix/store/brib029xs79az5vhjd5nhixp1l39ni31-tzdata-2017c/share/zoneinfo"
ExecReload=/run/current-system/sw/bin/kill $MAINPID
ExecStart=/nix/store/l1i8bfi23psnrh9jsj9707drlw2w17lj-elixir-1.6.2/bin/elixir -S /nix/store/l1i8bfi23psnrh9jsj9707drlw2w17lj-elixir-1.6.2/bin/mix phx.server
KillMode=process
Restart=on-failure
User=pleroma
WorkingDirectory=/home/pleroma
And the truncated output from journalctl -u pleroma_backend
Jul 16 18:31:31 cloud systemd[1]: Started Pleroma Backend.
Jul 16 18:31:31 cloud elixir[21905]: ** (Mix.Config.LoadError) could not load config config/config.exs
Jul 16 18:31:31 cloud elixir[21905]:     ** (ErlangError) Erlang error: :enoent
Jul 16 18:31:31 cloud elixir[21905]:     (elixir) lib/system.ex:622: System.cmd("git", ["rev-parse", "HEAD"], [])
Jul 16 18:31:31 cloud elixir[21905]:     (stdlib) erl_eval.erl:670: :erl_eval.do_apply/6
Jul 16 18:31:31 cloud elixir[21905]:     (stdlib) erl_eval.erl:269: :erl_eval.expr/5
Jul 16 18:31:31 cloud elixir[21905]:     (stdlib) erl_eval.erl:438: :erl_eval.expr/5
Jul 16 18:31:31 cloud elixir[21905]:     (stdlib) erl_eval.erl:122: :erl_eval.exprs/5
Jul 16 18:31:31 cloud elixir[21905]:     (elixir) lib/code.ex:192: Code.eval_string/3
Jul 16 18:31:31 cloud elixir[21905]:     (mix) lib/mix/config.ex:188: Mix.Config.read!/2
Jul 16 18:31:31 cloud systemd[1]: pleroma_backend.service: Main process exited, code=exited, status=1/FAILURE
Jul 16 18:31:31 cloud systemd[1]: pleroma_backend.service: Failed with result 'exit-code'.
Jul 16 18:31:31 cloud systemd[1]: pleroma_backend.service: Service hold-off time over, scheduling restart.
Jul 16 18:31:31 cloud systemd[1]: pleroma_backend.service: Scheduled restart job, restart counter is at 5.
Jul 16 18:31:31 cloud systemd[1]: Stopped Pleroma Backend.
Jul 16 18:31:31 cloud systemd[1]: pleroma_backend.service: Start request repeated too quickly.
Jul 16 18:31:31 cloud systemd[1]: Failed to start Pleroma Backend.
I know the output points to a non-existent config/config.exs file, but the file is definitely there:
[pleroma@cloud:~]$ ls -la /home/pleroma/pleroma/config/config.exs
-rw-r--r-- 1 pleroma users 2761 Jul 16 08:52 /home/pleroma/pleroma/config/config.exs
and like I mentioned, the program works when run from the shell:
[pleroma@cloud:~/pleroma]$ MIX_ENV=prod /nix/store/l1i8bfi23psnrh9jsj9707drlw2w17lj-elixir-1.6.2/bin/elixir -S /nix/store/l1i8bfi23psnrh9jsj9707drlw2w17lj-elixir-1.6.2/bin/mix phx.server
19:47:16.447 [info] Running Pleroma.Web.Endpoint with Cowboy using http://0.0.0.0:4000
19:47:16.494 [info] Gopher server disabled
Maybe I’m approaching “porting” the unit wrong way? I have also tried this configuration:
    environment = {
      MIX_ENV = "prod";
    path = [ pkgs.elixir ];
    script = "mix phx.server";
    serviceConfig = {
      User = "pleroma";
# /nix/store/48dgyp8hcm6rikg8r0b2qq39mls9n82x-unit-pleroma_backend.service/pleroma_backend.service
[Unit]
[Service]
ExecStart=/nix/store/95kbgqwpfx3vckafvnnigjm94a9ryd1f-unit-script/bin/pleroma_backend-start
KillMode=process
Restart=on-failure
User=pleroma
WorkingDirectory=/home/pleroma/pleroma
cat /nix/store/95kbgqwpfx3vckafvnnigjm94a9ryd1f-unit-script/bin/pleroma_backend-start:
#! /nix/store/zqh3l3lyw32q1ayb15bnvg9f24j5v2p0-bash-4.4-p12/bin/bash -e
mix phx.server
Which I would assume more closely resembles running from the shell, yet I get the exact same result.
I don’t know how else to troubleshoot the issue. Any help is greatly appreciated.
Going from that line, I will hazard a guess: git is needed for this service, and you have git available in your systemPackages.
systemd services have quite a strict relation with PATH[1] (and most environment variables). You will need to add the required dependencies to the .path option for your service.
Double check your working dirctory. There seems to be mismatch between some of the confings.
Gah! That was it! Adding pkgs.git to path fixed it. Thank you so much!
My working configuration, in case it helps somebody in the future:
    environment = {
      MIX_ENV = "prod";
    path = [ pkgs.elixir pkgs.git ];
    serviceConfig = {
      User = "pleroma";
      ExecStart = "${pkgs.elixir}/bin/mix phx.server";
Thanks again!
This wasn’t the issue, but thanks for replying.
Sorry for the unexpected request. I’m trying to run Pleroma on my NixOS server, but I can’t define declarative server installation. If there’s no sort of sensible information, could you please provide full config, with which you deploy Pleroma(not only systemd service, but server binaries provision)?
Hi @anon22412468. Unfortunately, I don’t run Pleroma anymore. I see you’ve already managed to get a hold of someone smarter than me in another thread. Sorry for the delay in relpying, and best of luck!
