Active Directory, odd prompt, odd arrows behavior and remote home directory not mounted
Hello,
I have a Synology NAS on which I installed Synology Directory Server Synology Inc.
I’m quite new to NixOS but want to connect it to this AD.
I’m using NixOS in Windows 11 thanks to WSL.
Thanks to Claude.ai I did a nearly good enough configuration for that purpose like so :
{ config, lib, pkgs, ... }:
 secrets = import ./secrets.nix;
 imports = [
   <nixos-wsl/modules>
 wsl.enable = true;
 wsl.defaultUser = "nixos";
   vim
   git
   wget
   sssd
   openldap
   krb5
   cifs-utils
 # Configuration des sudoers
 security.sudo.extraRules = [
     users = [ "scelles" ];
     commands = [
         command = "ALL";
         options = [ "NOPASSWD" ];
 # Script de montage pour le répertoire home
 environment.etc."mount-home.sh" = {
   text = ''
     #!/bin/sh
     USERNAME=$1
     mount -t cifs "//192.168.1.4/h0m3$/$USERNAME" "/home/$USERNAME" \
       -o "user=$USERNAME,domain=HOME.LOCAL,dir_mode=0700,file_mode=0600,vers=3.0,sec=ntlmssp"
   mode = "0755";
 # Configuration readline pour tous les utilisateurs
 environment.etc."inputrc".text = ''
   # Configuration de base
   set input-meta on
   set output-meta on
   set convert-meta off
   set bell-style none
   # Configuration des touches
   "\e[A": history-search-backward
   "\e[B": history-search-forward
   "\e[C": forward-char
   "\e[D": backward-char
   "\e[1;5C": forward-word
   "\e[1;5D": backward-word
   "\e[H": beginning-of-line
   "\e[F": end-of-line
 # Configuration bash plus complète
 programs.bash = {
   interactiveShellInit = ''
     PS1='\u@\h:\w\$ '
     HISTCONTROL=ignoredups:ignorespace
     HISTSIZE=1000
     HISTFILESIZE=2000
     if [ -f /etc/inputrc ]; then
       export INPUTRC=/etc/inputrc
     fi
   shellAliases = {
     ls = "ls --color=auto";
     ll = "ls -l";
     la = "ls -la";
 # Création des répertoires nécessaires pour SSSD
 systemd.tmpfiles.rules = [
   "d /var/lib/sss 0755 root root -"
   "d /var/lib/sss/db 0700 sssd sssd -"
   "d /var/lib/sss/pipes 0711 root root -"
   "d /var/lib/sss/pipes/private 0700 root root -"
   "d /var/lib/sss/mc 0700 root root -"
   "d /run/sss/pipes 0755 root root -"
 # Configuration SSSD
 services.sssd = {
   config = ''
     [sssd]
     config_file_version = 2
     domains = home.local
     services = nss, pam
     [domain/home.local]
     id_provider = ldap
     auth_provider = ldap
     access_provider = permit
     ldap_uri = ldaps://192.168.1.4:636
     ldap_search_base = DC=home,DC=local
     ldap_default_bind_dn = CN=Administrator,CN=Users,DC=home,DC=local
     ldap_default_authtok_type = password
     ldap_default_authtok = ${secrets.ldapPassword}
     ldap_tls_reqcert = never
     ldap_referrals = false
     ldap_schema = ad
     ldap_id_mapping = true
     ldap_user_search_base = CN=Users,DC=home,DC=local
     ldap_group_search_base = CN=Users,DC=home,DC=local
     enumerate = true
     case_sensitive = false
     fallback_homedir = /home/%u
     default_shell = ${pkgs.bash}/bin/bash
     override_homedir = /home/%u
 # Configuration PAM simplifiée
 security.pam.services = {
   login = {
     makeHomeDir = true;
     startSession = true;
   su = {
     makeHomeDir = true;
 # Configuration Kerberos
 environment.etc."krb5.conf".text = ''
   [libdefaults]
     default_realm = HOME.LOCAL
     dns_lookup_realm = false
     dns_lookup_kdc = true
     rdns = false
     forwardable = true
   [realms]
     HOME.LOCAL = {
       kdc = 192.168.1.4
       admin_server = 192.168.1.4
   [domain_realm]
     .home.local = HOME.LOCAL
 # Configuration du shell par défaut
 users.defaultUserShell = pkgs.bash;
 # Configuration NSS
 system.nssModules = [ pkgs.sssd ];
 system.nssDatabases.passwd = [ "files" "sss" ];
 system.nssDatabases.group = [ "files" "sss" ];
 system.nssDatabases.shadow = [ "files" "sss" ];
 # Création des répertoires et fichiers de base
 system.activationScripts = {
   createHomeDirectories = {
     text = ''
       mkdir -p /home
       chmod 755 /home
     deps = [];
 i18n.defaultLocale = "fr_FR.UTF-8";
 nixpkgs.config.firefox.enableFrench = true;
 system.stateVersion = "24.05";
What is working?
PS C:\Users\scelles> wsl -d NixOS
[nixos@nixos:/mnt/c/Users/scelles]$ getent passwd scelles
scelles:*:722201124:722200513:scelles:/home/scelles:/nix/store/syl4snn859kpqvn9qh91kr7n9i4dws04-bash-5.2p32/bin/bash
[nixos@nixos:/mnt/c/Users/scelles]$ su - scelles
Mot de passe :
\[\][\[\]scelles@nixos:~]$\[\]
I can query my AD and see that I can have uid/gid for an AD user and an associate shell.
I can log with any AD user.
but I still have several problems with this config that I can’t fix.
  1. Odd prompt:
    My prompt looks like
I don’t understand why these \
I was expecting a prompt like
[scelles@nixos:~]$
  1. Tab completion only works with nixos user (not with AD users)
  2. When I’m logged as nixos user I can use keyboard arrows (left right up down) without issues but when I’m logged as an AD user keyboard arrows behave differently. I’m getting thinks like so
\[\][\[\]scelles@nixos:~]$\[\] ^[[D^[[C^[[A^[[B
  1. A last problem is that my home directory (CIFS available at //192.168.1.4/h0m3$/$USERNAME ) is not mount automatically
\[\][\[\]scelles@nixos:~]$\[\] ls ~
is empty while it should show files and directories in my home on my NAS
I aware that’s a lot of problems… and my config is quite long (and some tries to fix these problems should probably be removed).
But some help will be very nice.
Best regards
Sébastien
