I have a Nixos server that among other things runs Adguard Home, just DNS, no DHCP. I also have it setup with it nameservers being 127.0.0.1. Below is what I think are the relevant part of the config:
# Enable networking.
networking.hostName = "auir";
networking.nameservers = [ "127.0.0.1" ];
# Enable Adguard Home and set bassic settigns
services.adguardhome = {
settings = {
bind_host = "127.0.0.1";
bind_port = 3000;
dns = {
bind_hosts = [ "127.0.0.1" "192.168.50.20" ];
upstream_dns = [ "64.59.135.135" "64.59.128.112" ];
all_servers = true;
bootstrap_dns = [ "64.59.135.135" "64.59.128.112" ];
rewrites = [
domain = "*.mydomain.com";
answer = "192.168.50.20";
domain = "mydomain.com";
I am in the process of upgrade it from 23.05 to 23.11 and running into some issues. I used the following step to take the upgrade:
sudo nix-channel --add https://channels.nixos.org/nixos-23.11 nixos
sudo nixos-rebuild boot --upgrade
sudo shutdown -r now
Everything seem to work correctly, however after the upgrade Adguard Home will not start:
sudo systemctl status adguardhome.service
● adguardhome.service - AdGuard Home: Network-level blocker
Loaded: loaded (/etc/systemd/system/adguardhome.service; enabled; preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Thu 2023-11-30 15:31:38 MST; 2s ago
Process: 110266 ExecStartPre=/nix/store/fw97wkhd53cl2phgw5h27qc0i3yj92ss-unit-script-adguardhome-pre-start/bin/adguardhome-pre-start (code=exited, status=0/SUCCESS)
Process: 110270 ExecStart=/nix/store/idf1g0533i94jwzy6k0l7d85fkz6j61s-adguardhome-0.107.36/bin/adguardhome --no-check-update --pidfile /run/AdGuardHome/AdGuardHome.pid --work-dir /var/lib/AdGuardHome/ --config /var/lib/AdGuardHome/AdGuardHome.yaml (code=exited, stat>
Main PID: 110270 (code=exited, status=1/FAILURE)
IP: 0B in, 0B out
CPU: 92ms
Nov 30 15:31:38 auir systemd[1]: adguardhome.service: Main process exited, code=exited, status=1/FAILURE
Nov 30 15:31:38 auir systemd[1]: adguardhome.service: Failed with result 'exit-code'.
Nov 30 15:31:38 auir systemd[1]: adguardhome.service: Triggering OnFailure= dependencies.
I am not sure why it will not start, but one thing that is limiting my troubleshooting, I now don’t have DNS on this machine. I have tried changing my /etc/nixos/configuration.nix to uses a different nameserver, but when I do a sudo nixos-rebuild switch I get Couldn’t resolve host name errors.
How would I change my nameserver in the live system, so I can get sudo nixos-rebuild switch to work? Also, if anyone has any idea why Adguard Home is not working, please share.
Thank you
