Hi,
I find nix to be really useful, and I started using it in my company. However, it’s currently quite inconvenient. The reason is that we work on servers which host many users, where only IT people have root access. I consulted with the IT guy, and he really didn’t want to install the full nix daemon. He agreed to create an empty directory /nix
, which allowed me to use bubblewrap to bind it to a personal directory. However, this means that everything using nix must run under bubblewrap.
I had an idea which would allow multiple users to use nix without having IT being responsible for a daemon which compiles stuff and may use a lot of storage not associated with specific users. I created a very simple read-only FUSE filesystem, which has two files, store
and var
, which are symlinks to ~/nix/store
and ~/nix/var
of the user viewing the filesystem. So, it looks like this:
❯ ll /nix
total 1.0K
lrwxrwxrwx 1 noamyr noamyr 22 Jan 1 1970 store -> /home/noamyr/nix/store
lrwxrwxrwx 1 noamyr noamyr 20 Jan 1 1970 var -> /home/noamyr/nix/var
However, I then discovered that nix forbids symlinks. I added the configuration allow-symlinked-store = true
, but it still doesn’t work:
❯ nix-shell --packages cowsay
error:
at /nix/store/1wirgshrfl96hc8nj397n98llpj30w3m-nixpkgs/nixpkgs/pkgs/stdenv/booter.nix:99:7:
… in the right operand of the update (//) operator
at /nix/store/1wirgshrfl96hc8nj397n98llpj30w3m-nixpkgs/nixpkgs/pkgs/stdenv/booter.nix:84:7:
error: path '«unknown»/nix/store' is a symlink
I found here a reason for not allowing symlinks:
The reason is that builders could canonicalize a path (e.g. do
realpath $dir
) and end up storing the symlink target in derivation outputs. Which is bad if the output is shared with other machines via a binary cache.
Hmm. So I thought that I can add a simple command, say nix-realpath
, which will be exactly like realpath
, except for that if the path starts with /nix/store
or /nix/var
, the first two elements would remain as they are. Then, all realpath
usages in nixpkgs could be replaced with nix-realpath
, and then the home directory would not reach the binary cache.
And now to the question: what is the chance of the Nix project accepting such a change? Specifically, those are the changes I see:
- Modify PosixSourceAccessor::assertNoSymlinks() to avoid checking for symlinks at
/nix/store
or/nix
, ifallow-symlinked-store = true
. - Add a utility
nix-realpath
(or whatever should be the name, or even adding an argument--nix
to therealpath
shipped with nix in coreutils). - Modify many
realpath
usages to usenix-realpath
. That would be a large pull request.
The benefit is that it would be much easier for IT people to agree to having this tiny read-only filesystem, than to agree to being responsible for a daemon which could use significant computation and storage.
What do you think?
