Hello,
I switched to NixOS few days ago and I have trouble figuring out how to allow only specific unfree packages. I’m using flakes to configure my system and you can find it here: GitHub - MatejaMaric/nix-setup: My Nix Flake configuration
From the docs I saw that I can use this code the enable only specific unfree packages:
{lib, ...}: {
nixpkgs.config.allowUnfreePredicate = pkg:
builtins.elem (lib.getName pkg) [
# Add additional package names here
"hello-unfree"
However when I add it to my configuration.nix it fails with the following error:
mateja@hp-laptop:nix-setup$ sudo nixos-rebuild switch --flake ~/nix-setup/.#
[sudo] password for mateja:
error:
at /nix/store/jnk1mfi594y0dsmzla4nmkbr4rnrqa71-source/lib/attrsets.nix:960:11:
959| || pred here (elemAt values 1) (head values) then
960| head values
961| else
at /nix/store/jnk1mfi594y0dsmzla4nmkbr4rnrqa71-source/lib/modules.nix:809:9:
808| in warnDeprecation opt //
809| { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
810| inherit (res.defsFinal') highestPrio;
error:
Failed assertions:
- Your system configures nixpkgs with an externally created instance.
`nixpkgs.config` options should be passed when creating the instance instead.
Current value:
__toString = <function>;
_type = "option";
declarationPositions = [
column = 5;
file = "/nix/store/jnk1mfi594y0dsmzla4nmkbr4rnrqa71-source/nixos/modules/misc/nixpkgs.nix";
line = 148;
declarations = [
default = { };
definitions = [
allowUnfreePredicate = <function>;
definitionsWithLocations = [
definitionsWithLocations = [ [233/1106]
file = "/nix/store/lm6asgi57y3jhnyvn7zfs4ih19fs06q4-source/hosts/hp-laptop/configuration.nix";
value = {
description = ''
The configuration of the Nix Packages collection. (For
details, see the Nixpkgs documentation.) It allows you to set
package configuration options.
Ignored when `nixpkgs.pkgs` is set.
example = {
_type = "literalExpression";
text = ''
{ allowBroken = true; allowUnfree = true; }
files = [
highestPrio = 100;
isDefined = true;
loc = [
"nixpkgs"
"config"
options = [ ];
type = {
_type = "option-type";
check = <function>;
deprecationMessage = null;
description = "nixpkgs config";
descriptionClass = null;
emptyValue = { };
functor = {
binOp = <function>;
name = "nixpkgs-config";
payload = null;
type = null;
wrapped = null;
getSubModules = null;
getSubOptions = <function>;
merge = <function>;
nestedTypes = { };
substSubModules = <function>;
typeMerge = <function>;
value = {
