I’m experiencing amdgpu issues when trying to run startx. This used to work fine and happened after updating my nixpkgs pin.
I have my configuration set as per the wiki. I also tried by including "radeonsi" in video drivers:
videoDrivers = [ "amdgpu" "radeonsi" ];
Any idea what might be going wrong here? Happy to provide further information if needed.
Here’s xorg log:
[ 1406.469]
X.Org X Server 1.20.12
X Protocol Version 11, Revision 0
[ 1406.483] Build Operating System: Nix
[ 1406.487] Current Operating System: Linux ryzen3950 5.13.4 #1-NixOS SMP Tue Jul 20 14:00:42 UTC 2021 x86_64
[ 1406.488] Kernel command line: initrd=\efi\nixos\kdda3z2w4jsa3kck7xildb73ayd3zyn1-initrd-linux-5.13.4-initrd.efi init=/nix/store/nz6ngz269i0mskb8sqah0kn3i3kddl44-nixos-system-ryzen3950-21.11.20210725.3ea51d0/init fbcon=rotate:3 loglevel=4
[ 1406.502] Build Date: 08 July 2021 07:22:56PM
[ 1406.507]
[ 1406.512] Current version of pixman: 0.38.4
[ 1406.522] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 1406.522] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 1406.541] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jul 25 19:25:05 2021
[ 1406.546] (++) Using config file: "/nix/store/h38lawz1w3ppdskg94x8izpvywgv42xc-xserver.conf"
[ 1406.551] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 1406.556] (==) Using system config directory "/nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/share/X11/xorg.conf.d"
[ 1406.561] (==) ServerLayout "Layout[all]"
[ 1406.565] (**) |-->Screen "Screen-amdgpu[0]" (0)
[ 1406.570] (**) | |-->Monitor "<default monitor>"
[ 1406.575] (**) | |-->Device "Device-amdgpu[0]"
[ 1406.584] (==) No monitor specified for screen "Screen-amdgpu[0]".
Using a default monitor configuration.
[ 1406.584] (**) Option "DontZap" "off"
[ 1406.589] (**) Option "AllowMouseOpenFail" "on"
[ 1406.599] (==) Automatically adding devices
[ 1406.603] (==) Automatically enabling devices
[ 1406.608] (==) Automatically adding GPU devices
[ 1406.613] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 1406.643] (**) FontPath set to:
/nix/store/8g9gq1dqcxpznsqcz5pvzxrql3y2l386-font-misc-misc-1.1.2/lib/X11/fonts/misc,
/nix/store/4ilvq4av99rn2prm1x32mxvky6wvh5r7-font-cursor-misc-1.0.3/lib/X11/fonts/misc,
/nix/store/a6jnpnma7iwwj81m6siqk5rny4sdpk9y-unifont-13.0.05/share/fonts,
/nix/store/2cjpybgjf5s4ydm9crw5jdpxc5c5bc7p-font-adobe-100dpi-1.0.3/lib/X11/fonts/100dpi,
/nix/store/ykdzrl3zji1i1gdb3qgfkf3h6h9kwyz6-font-adobe-75dpi-1.0.3/lib/X11/fonts/75dpi
[ 1406.669] (**) ModulePath set to "/nix/store/58an2zz0vid28ha9q8k40vx6zl9nx2m0-xf86-video-amdgpu-19.1.0/lib/xorg/modules/drivers,/nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/lib/xorg/modules,/nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/lib/xorg/modules/drivers,/nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/lib/xorg/modules/extensions,/nix/store/dz0mmz6s7c66n3jfi2pww3zs05xw4zq8-xf86-input-evdev-2.10.6/lib/xorg/modules/input,/nix/store/yimqcc55acwq32mibjzzs23m8ry02jkl-xf86-input-libinput-1.1.0/lib/xorg/modules/input"
[ 1406.680] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 1406.685] (II) Loader magic: 0x62cd40
[ 1406.691] (II) Module ABI versions:
[ 1406.696] X.Org ANSI C Emulation: 0.4
[ 1406.702] X.Org Video Driver: 24.1
[ 1406.707] X.Org XInput driver : 24.1
[ 1406.713] X.Org Server Extension : 10.0
[ 1406.724] (++) using VT number 1
[ 1406.725] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 1406.725] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1406.725] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 1406.728] (--) PCI:*(13@0:0:0) 1002:731f:1458:2313 rev 193, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfcb00000/524288, I/O @ 0x0000f000/256, BIOS @ 0x????????/131072
[ 1406.728] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 1406.728] (II) "glx" will be loaded by default.
[ 1406.728] (II) LoadModule: "glx"
[ 1406.728] (II) Loading /nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/lib/xorg/modules/extensions/libglx.so
[ 1406.729] (II) Module glx: vendor="X.Org Foundation"
[ 1406.729] compiled for 1.20.12, module version = 1.0.0
[ 1406.729] ABI class: X.Org Server Extension, version 10.0
[ 1406.729] (II) LoadModule: "amdgpu"
[ 1406.729] (II) Loading /nix/store/58an2zz0vid28ha9q8k40vx6zl9nx2m0-xf86-video-amdgpu-19.1.0/lib/xorg/modules/drivers/amdgpu_drv.so
[ 1406.729] (II) Module amdgpu: vendor="X.Org Foundation"
[ 1406.729] compiled for 1.20.12, module version = 19.1.0
[ 1406.729] Module class: X.Org Video Driver
[ 1406.729] ABI class: X.Org Video Driver, version 24.1
[ 1406.729] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 1406.729] (**) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 1406.729] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 1406.729] (==) AMDGPU(0): Default visual is TrueColor
[ 1406.729] (==) AMDGPU(0): RGB weight 888
[ 1406.729] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 1406.729] (--) AMDGPU(0): Chipset: "AMD Radeon RX 5700 XT" (ChipID = 0x731f)
[ 1406.729] (II) Loading sub module "fb"
[ 1406.729] (II) LoadModule: "fb"
[ 1406.729] (II) Loading /nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/lib/xorg/modules/libfb.so
[ 1406.729] (II) Module fb: vendor="X.Org Foundation"
[ 1406.729] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1406.730] (II) Loading sub module "dri2"
[ 1406.730] (II) LoadModule: "dri2"
[ 1406.730] (II) Module "dri2" already built-in
[ 1406.766] (II) Loading sub module "glamoregl"
[ 1406.766] (II) LoadModule: "glamoregl"
[ 1406.767] (II) Loading /nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/lib/xorg/modules/libglamoregl.so
[ 1406.768] (II) Module glamoregl: vendor="X.Org Foundation"
[ 1406.768] compiled for 1.20.12, module version = 1.0.1
[ 1406.768] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1406.770] (EE) AMDGPU(0): eglInitialize() failed
[ 1406.770] (EE) AMDGPU(0): glamor detected, failed to initialize EGL.
[ 1406.770] (WW) AMDGPU(0): amdgpu_glamor_pre_init returned FALSE, using ShadowFB
[ 1406.770] (II) Loading sub module "shadow"
[ 1406.770] (II) LoadModule: "shadow"
[ 1406.770] (II) Loading /nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/lib/xorg/modules/libshadow.so
[ 1406.770] (II) Module shadow: vendor="X.Org Foundation"
[ 1406.770] compiled for 1.20.12, module version = 1.1.0
[ 1406.770] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1406.770] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 1406.772] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 1406.774] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 1406.774] (II) AMDGPU(0): Output DisplayPort-2 has no monitor section
[ 1406.774] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 1406.808] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 1406.808] (II) AMDGPU(0): Manufacturer: GSM Model: 5b09 Serial#: 515045
[ 1406.808] (II) AMDGPU(0): Year: 2018 Week: 5
[ 1406.808] (II) AMDGPU(0): EDID Version: 1.4
[ 1406.808] (II) AMDGPU(0): Digital Display Input
[ 1406.808] (II) AMDGPU(0): 10 bits per channel
[ 1406.808] (II) AMDGPU(0): Digital interface is DisplayPort
[ 1406.808] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 60 vert.: 34
[ 1406.808] (II) AMDGPU(0): Gamma: 2.20
[ 1406.808] (II) AMDGPU(0): DPMS capabilities: StandBy
[ 1406.808] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 1406.808] (II) AMDGPU(0): Default color space is primary color space
[ 1406.808] (II) AMDGPU(0): First detailed timing is preferred mode
[ 1406.808] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 1406.808] (II) AMDGPU(0): redX: 0.652 redY: 0.335 greenX: 0.305 greenY: 0.637
[ 1406.808] (II) AMDGPU(0): blueX: 0.148 blueY: 0.062 whiteX: 0.313 whiteY: 0.329
[ 1406.808] (II) AMDGPU(0): Supported established timings:
[ 1406.808] (II) AMDGPU(0): 640x480@60Hz
[ 1406.808] (II) AMDGPU(0): 800x600@60Hz
[ 1406.808] (II) AMDGPU(0): 1024x768@60Hz
[ 1406.808] (II) AMDGPU(0): Manufacturer's mask: 0
[ 1406.808] (II) AMDGPU(0): Supported standard timings:
[ 1406.808] (II) AMDGPU(0): #0: hsize: 1152 vsize 864 refresh: 60 vid: 16497
[ 1406.808] (II) AMDGPU(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 1406.808] (II) AMDGPU(0): #2: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 1406.808] (II) AMDGPU(0): #3: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 1406.808] (II) AMDGPU(0): #4: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 1406.808] (II) AMDGPU(0): #5: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 1406.808] (II) AMDGPU(0): Supported detailed timing:
[ 1406.808] (II) AMDGPU(0): clock: 533.2 MHz Image Size: 600 x 340 mm
[ 1406.808] (II) AMDGPU(0): h_active: 3840 h_sync: 3888 h_sync_end 3920 h_blank_end 4000 h_border: 0
[ 1406.808] (II) AMDGPU(0): v_active: 2160 v_sync: 2214 v_sync_end 2219 v_blanking: 2222 v_border: 0
[ 1406.808] (II) AMDGPU(0): clock: 266.6 MHz Image Size: 600 x 340 mm
[ 1406.808] (II) AMDGPU(0): h_active: 3840 h_sync: 3848 h_sync_end 3992 h_blank_end 4000 h_border: 0
[ 1406.808] (II) AMDGPU(0): Ranges: V min: 56 V max: 61 Hz, H min: 30 H max: 135 kHz, PixClock max 565 MHz
[ 1406.808] (II) AMDGPU(0): Monitor name: LG Ultra HD
[ 1406.809] (II) AMDGPU(0): Supported detailed timing:
[ 1406.809] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 600 x 340 mm
[ 1406.809] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 1406.809] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 1406.809] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 600 x 340 mm
[ 1406.809] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 1406.809] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 1406.809] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 1406.809] (II) AMDGPU(0): EDID (in hex):
[ 1406.809] (II) AMDGPU(0): 00ffffffffffff001e6d095be5db0700
[ 1406.809] (II) AMDGPU(0): 051c0104b53c22789e3035a7554ea326
[ 1406.809] (II) AMDGPU(0): 0f50542108007140818081c0a9c0d1c0
[ 1406.809] (II) AMDGPU(0): 8100010101014dd000a0f0703e803020
[ 1406.809] (II) AMDGPU(0): 650c58542100001a286800a0f0703e80
[ 1406.809] (II) AMDGPU(0): 0890650c58542100001a000000fd0038
[ 1406.809] (II) AMDGPU(0): 3d1e8738000a202020202020000000fc
[ 1406.809] (II) AMDGPU(0): 004c4720556c7472612048440a2001d3
[ 1406.809] (II) AMDGPU(0): 02031171449004030123090707830100
[ 1406.809] (II) AMDGPU(0): 00023a801871382d40582c4500585421
[ 1406.809] (II) AMDGPU(0): 00001e565e00a0a0a029503020350058
[ 1406.809] (II) AMDGPU(0): 542100001a0000000000000000000000
[ 1406.809] (II) AMDGPU(0): 00000000000000000000000000000000
[ 1406.809] (II) AMDGPU(0): 000000000000000000000000000000c8
[ 1406.809] (II) AMDGPU(0): Printing probed modes for output DisplayPort-0
[ 1406.809] (II) AMDGPU(0): Modeline "3840x2160"x60.0 533.25 3840 3888 3920 4000 2160 2214 2219 2222 +hsync -vsync (133.3 kHz UeP)
[ 1406.809] (II) AMDGPU(0): Modeline "3840x2160"x30.0 266.64 3840 3848 3992 4000 2160 2214 2219 2222 +hsync -vsync (66.7 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1920x1200"x60.0 533.25 1920 3888 3920 4000 1200 2214 2219 2222 +hsync -vsync (133.3 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1600x1200"x60.0 533.25 1600 3888 3920 4000 1200 2214 2219 2222 +hsync -vsync (133.3 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1680x1050"x60.0 533.25 1680 3888 3920 4000 1050 2214 2219 2222 +hsync -vsync (133.3 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1440x900"x60.0 533.25 1440 3888 3920 4000 900 2214 2219 2222 +hsync -vsync (133.3 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1406.809] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1406.811] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 1406.811] (II) AMDGPU(0): Manufacturer: GSM Model: 5b09 Serial#: 318563
[ 1406.811] (II) AMDGPU(0): Year: 2018 Week: 11
[ 1406.811] (II) AMDGPU(0): EDID Version: 1.4
[ 1406.811] (II) AMDGPU(0): Digital Display Input
[ 1406.811] (II) AMDGPU(0): 10 bits per channel
[ 1406.811] (II) AMDGPU(0): Digital interface is DisplayPort
[ 1406.811] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 60 vert.: 34
[ 1406.811] (II) AMDGPU(0): Gamma: 2.20
[ 1406.811] (II) AMDGPU(0): DPMS capabilities: StandBy
[ 1406.811] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 1406.811] (II) AMDGPU(0): Default color space is primary color space
[ 1406.811] (II) AMDGPU(0): First detailed timing is preferred mode
[ 1406.811] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 1406.811] (II) AMDGPU(0): redX: 0.652 redY: 0.335 greenX: 0.305 greenY: 0.637
[ 1406.811] (II) AMDGPU(0): blueX: 0.148 blueY: 0.062 whiteX: 0.313 whiteY: 0.329
[ 1406.811] (II) AMDGPU(0): Supported established timings:
[ 1406.811] (II) AMDGPU(0): 640x480@60Hz
[ 1406.811] (II) AMDGPU(0): 800x600@60Hz
[ 1406.811] (II) AMDGPU(0): 1024x768@60Hz
[ 1406.811] (II) AMDGPU(0): Manufacturer's mask: 0
[ 1406.811] (II) AMDGPU(0): Supported standard timings:
[ 1406.811] (II) AMDGPU(0): #0: hsize: 1152 vsize 864 refresh: 60 vid: 16497
[ 1406.811] (II) AMDGPU(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 1406.811] (II) AMDGPU(0): #2: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 1406.811] (II) AMDGPU(0): #3: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 1406.811] (II) AMDGPU(0): #4: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 1406.811] (II) AMDGPU(0): #5: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 1406.811] (II) AMDGPU(0): Supported detailed timing:
[ 1406.811] (II) AMDGPU(0): clock: 533.2 MHz Image Size: 600 x 340 mm
[ 1406.811] (II) AMDGPU(0): h_active: 3840 h_sync: 3888 h_sync_end 3920 h_blank_end 4000 h_border: 0
[ 1406.811] (II) AMDGPU(0): v_active: 2160 v_sync: 2214 v_sync_end 2219 v_blanking: 2222 v_border: 0
[ 1406.811] (II) AMDGPU(0): clock: 266.6 MHz Image Size: 600 x 340 mm
[ 1406.811] (II) AMDGPU(0): h_active: 3840 h_sync: 3848 h_sync_end 3992 h_blank_end 4000 h_border: 0
[ 1406.811] (II) AMDGPU(0): Ranges: V min: 56 V max: 61 Hz, H min: 30 H max: 135 kHz, PixClock max 565 MHz
[ 1406.811] (II) AMDGPU(0): Monitor name: LG Ultra HD
[ 1406.811] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 600 x 340 mm
[ 1406.811] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 1406.811] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 1406.811] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 600 x 340 mm
[ 1406.811] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 1406.811] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 1406.811] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 1406.811] (II) AMDGPU(0): EDID (in hex):
[ 1406.811] (II) AMDGPU(0): 00ffffffffffff001e6d095b63dc0400
[ 1406.811] (II) AMDGPU(0): 0b1c0104b53c22789e3035a7554ea326
[ 1406.811] (II) AMDGPU(0): 0f50542108007140818081c0a9c0d1c0
[ 1406.811] (II) AMDGPU(0): 8100010101014dd000a0f0703e803020
[ 1406.811] (II) AMDGPU(0): 650c58542100001a286800a0f0703e80
[ 1406.811] (II) AMDGPU(0): 0890650c58542100001a000000fd0038
[ 1406.811] (II) AMDGPU(0): 3d1e8738000a202020202020000000fc
[ 1406.811] (II) AMDGPU(0): 004c4720556c7472612048440a200151
[ 1406.811] (II) AMDGPU(0): 02031171449004030123090707830100
[ 1406.811] (II) AMDGPU(0): 00023a801871382d40582c4500585421
[ 1406.811] (II) AMDGPU(0): 00001e565e00a0a0a029503020350058
[ 1406.811] (II) AMDGPU(0): 542100001a0000000000000000000000
[ 1406.811] (II) AMDGPU(0): 00000000000000000000000000000000
[ 1406.811] (II) AMDGPU(0): 000000000000000000000000000000c8
[ 1406.811] (II) AMDGPU(0): Printing probed modes for output DisplayPort-1
[ 1406.811] (II) AMDGPU(0): Modeline "3840x2160"x60.0 533.25 3840 3888 3920 4000 2160 2214 2219 2222 +hsync -vsync (133.3 kHz UeP)
[ 1406.811] (II) AMDGPU(0): Modeline "3840x2160"x30.0 266.64 3840 3848 3992 4000 2160 2214 2219 2222 +hsync -vsync (66.7 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1920x1200"x60.0 533.25 1920 3888 3920 4000 1200 2214 2219 2222 +hsync -vsync (133.3 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1600x1200"x60.0 533.25 1600 3888 3920 4000 1200 2214 2219 2222 +hsync -vsync (133.3 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1680x1050"x60.0 533.25 1680 3888 3920 4000 1050 2214 2219 2222 +hsync -vsync (133.3 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1440x900"x60.0 533.25 1440 3888 3920 4000 900 2214 2219 2222 +hsync -vsync (133.3 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1406.811] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1406.811] (II) AMDGPU(0): EDID for output DisplayPort-2
[ 1406.811] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 1406.811] (II) AMDGPU(0): Output DisplayPort-0 connected
[ 1406.811] (II) AMDGPU(0): Output DisplayPort-1 connected
[ 1406.811] (II) AMDGPU(0): Output DisplayPort-2 disconnected
[ 1406.811] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 1406.811] (II) AMDGPU(0): Using user preference for initial modes
[ 1406.811] (II) AMDGPU(0): Output DisplayPort-0 using initial mode 3840x2160 +0+0
[ 1406.811] (II) AMDGPU(0): Output DisplayPort-1 using initial mode 3840x2160 +0+0
[ 1406.811] (II) AMDGPU(0): mem size init: gart size :1fe5bb000 vram size: s:1fbd42000 visible:fdf6000
[ 1406.811] (++) AMDGPU(0): DPI set to (192, 192)
[ 1406.811] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 1406.811] (II) Loading sub module "ramdac"
[ 1406.811] (II) LoadModule: "ramdac"
[ 1406.811] (II) Module "ramdac" already built-in
[ 1406.812] (II) AMDGPU(0): Front buffer pitch: 15360 bytes
[ 1406.812] (==) AMDGPU(0): DRI3 disabled
[ 1406.812] (==) AMDGPU(0): Backing store enabled
[ 1406.812] (WW) AMDGPU(0): Direct rendering disabled
[ 1406.812] (II) AMDGPU(0): 2D and 3D acceleration disabled
[ 1406.812] (==) AMDGPU(0): DPMS enabled
[ 1406.812] (==) AMDGPU(0): Silken mouse enabled
[ 1406.840] (II) Initializing extension Generic Event Extension
[ 1406.840] (II) Initializing extension SHAPE
[ 1406.840] (II) Initializing extension MIT-SHM
[ 1406.840] (II) Initializing extension XInputExtension
[ 1406.841] (II) Initializing extension XTEST
[ 1406.841] (II) Initializing extension BIG-REQUESTS
[ 1406.841] (II) Initializing extension SYNC
[ 1406.841] (II) Initializing extension XKEYBOARD
[ 1406.841] (II) Initializing extension XC-MISC
[ 1406.841] (II) Initializing extension SECURITY
[ 1406.841] (II) Initializing extension XFIXES
[ 1406.841] (II) Initializing extension RENDER
[ 1406.841] (II) Initializing extension RANDR
[ 1406.841] (II) Initializing extension COMPOSITE
[ 1406.841] (II) Initializing extension DAMAGE
[ 1406.841] (II) Initializing extension MIT-SCREEN-SAVER
[ 1406.841] (II) Initializing extension DOUBLE-BUFFER
[ 1406.841] (II) Initializing extension RECORD
[ 1406.842] (II) Initializing extension DPMS
[ 1406.842] (II) Initializing extension Present
[ 1406.842] (II) Initializing extension DRI3
[ 1406.842] (II) Initializing extension X-Resource
[ 1406.842] (II) Initializing extension XVideo
[ 1406.842] (II) Initializing extension XVideo-MotionCompensation
[ 1406.842] (II) Initializing extension GLX
[ 1406.842] (II) AIGLX: Screen 0 is not DRI2 capable
[ 1406.844] (II) IGLX: Loaded and initialized swrast
[ 1406.844] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 1406.844] (II) Initializing extension XFree86-VidModeExtension
[ 1406.844] (II) Initializing extension XFree86-DGA
[ 1406.844] (II) Initializing extension XFree86-DRI
[ 1406.844] (II) Initializing extension DRI2
[ 1406.844] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[ 1406.861] (EE)
[ 1406.861] (EE) Backtrace:
[ 1406.861] (EE) 0: /nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/bin/X (OsSigHandler+0x25) [0x5a32f5]
[ 1406.862] (EE) 1: /nix/store/j5p0j1w27aqdzncpw73k95byvhh5prw2-glibc-2.33-47/lib/libpthread.so.0 (funlockfile+0x50) [0x7f661cc17ef0]
[ 1406.862] (EE) 2: /nix/store/j5p0j1w27aqdzncpw73k95byvhh5prw2-glibc-2.33-47/lib/libc.so.6 (gsignal+0xca) [0x7f661ca7bbaa]
[ 1406.862] (EE) 3: /nix/store/j5p0j1w27aqdzncpw73k95byvhh5prw2-glibc-2.33-47/lib/libc.so.6 (abort+0xff) [0x7f661ca66523]
[ 1406.863] (EE) 4: /nix/store/j5p0j1w27aqdzncpw73k95byvhh5prw2-glibc-2.33-47/lib/libc.so.6 (__assert_fail_base.cold.0+0xf) [0x7f661ca6641f]
[ 1406.863] (EE) 5: /nix/store/j5p0j1w27aqdzncpw73k95byvhh5prw2-glibc-2.33-47/lib/libc.so.6 (__assert_fail+0x42) [0x7f661ca745f2]
[ 1406.863] (EE) 6: /nix/store/58an2zz0vid28ha9q8k40vx6zl9nx2m0-xf86-video-amdgpu-19.1.0/lib/xorg/modules/drivers/amdgpu_drv.so (dixGetPrivateAddr.part.0+0x23) [0x7f661c310fc3]
[ 1406.863] (EE) 7: /nix/store/58an2zz0vid28ha9q8k40vx6zl9nx2m0-xf86-video-amdgpu-19.1.0/lib/xorg/modules/drivers/amdgpu_drv.so (amdgpu_pixmap_get_handle+0x19a) [0x7f661c31132a]
[ 1406.863] (EE) 8: /nix/store/58an2zz0vid28ha9q8k40vx6zl9nx2m0-xf86-video-amdgpu-19.1.0/lib/xorg/modules/drivers/amdgpu_drv.so (amdgpu_pixmap_get_fb+0xdd) [0x7f661c31d3fd]
[ 1406.864] (EE) 9: /nix/store/58an2zz0vid28ha9q8k40vx6zl9nx2m0-xf86-video-amdgpu-19.1.0/lib/xorg/modules/drivers/amdgpu_drv.so (drmmode_set_mode_major+0x71a) [0x7f661c31f55a]
[ 1406.864] (EE) 10: /nix/store/58an2zz0vid28ha9q8k40vx6zl9nx2m0-xf86-video-amdgpu-19.1.0/lib/xorg/modules/drivers/amdgpu_drv.so (drmmode_set_desired_modes+0xfa) [0x7f661c3211fa]
[ 1406.864] (EE) 11: /nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/bin/X (MapWindow+0x23c) [0x46eb2c]
[ 1406.864] (EE) 12: /nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/bin/X (dix_main+0x315) [0x4460e5]
[ 1406.864] (EE) 13: /nix/store/j5p0j1w27aqdzncpw73k95byvhh5prw2-glibc-2.33-47/lib/libc.so.6 (__libc_start_main+0xd0) [0x7f661ca67780]
[ 1406.864] (EE) 14: /nix/store/hl7p4gxnjnwfh0c4csp4y1wfdprg0a68-xorg-server-1.20.12/bin/X (_start+0x2a) [0x42f8aa]
[ 1406.864] (EE)
[ 1406.864] (EE)
Fatal server error:
[ 1406.864] (EE) Caught signal 6 (Aborted). Server aborting
[ 1406.864] (EE)
[ 1406.864] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 1406.864] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 1406.864] (EE)
[ 1406.902] (EE) Server terminated with error (1). Closing log file.
