Hey all. I’ve been refactoring my configuration to make it easier to define new hosts. Today I tried it for the first time and I found that the amdgpu
module isn’t getting loaded. Here’s the relevant kernel logs:
[ 2.711936] [drm] amdgpu kernel modesetting enabled.
[ 2.711957] amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.GP17.VGA_.ATPX handle
[ 2.712316] amdgpu: ATPX version 1, functions 0x00000201
[ 2.712350] amdgpu: ATPX Hybrid Graphics
[ 2.714042] amdgpu: Virtual CRAT table created for CPU
[ 2.714061] amdgpu: Topology: Add CPU node
[ 2.714179] amdgpu 0000:07:00.0: enabling device (0006 -> 0007)
[ 2.714234] [drm] initializing kernel modesetting (YELLOW_CARP 0x1002:0x1681 0x1043:0x1A5C 0xC7).
[ 2.714242] [drm] register mmio base: 0xFC500000
[ 2.714243] [drm] register mmio size: 524288
[ 2.717620] [drm] add ip block number 0 <nv_common>
[ 2.717622] [drm] add ip block number 1 <gmc_v10_0>
[ 2.717624] [drm] add ip block number 2 <navi10_ih>
[ 2.717625] [drm] add ip block number 3 <psp>
[ 2.717626] [drm] add ip block number 4 <smu>
[ 2.717627] [drm] add ip block number 5 <dm>
[ 2.717629] [drm] add ip block number 6 <gfx_v10_0>
[ 2.717630] [drm] add ip block number 7 <sdma_v5_2>
[ 2.717631] [drm] add ip block number 8 <vcn_v3_0>
[ 2.717633] [drm] add ip block number 9 <jpeg_v3_0>
[ 2.717655] amdgpu 0000:07:00.0: amdgpu: Fetched VBIOS from VFCT
[ 2.717657] amdgpu: ATOM BIOS: 113-REMBRANDT-X35
[ 2.717701] amdgpu 0000:07:00.0: Direct firmware load for amdgpu/yellow_carp_toc.bin failed with error -2
[ 2.717704] [drm:amdgpu_device_init [amdgpu]] *ERROR* early_init of IP block <psp> failed -19
[ 2.717964] amdgpu 0000:07:00.0: Direct firmware load for amdgpu/yellow_carp_dmcub.bin failed with error -2
[ 2.717966] [drm:amdgpu_device_init [amdgpu]] *ERROR* early_init of IP block <dm> failed -19
[ 2.718176] amdgpu 0000:07:00.0: Direct firmware load for amdgpu/yellow_carp_pfp.bin failed with error -2
[ 2.718178] [drm:amdgpu_device_init [amdgpu]] *ERROR* early_init of IP block <gfx_v10_0> failed -19
[ 2.718386] amdgpu 0000:07:00.0: Direct firmware load for amdgpu/yellow_carp_sdma.bin failed with error -2
[ 2.718389] [drm:amdgpu_device_init [amdgpu]] *ERROR* early_init of IP block <sdma_v5_2> failed -19
[ 2.718608] amdgpu 0000:07:00.0: Direct firmware load for amdgpu/yellow_carp_vcn.bin failed with error -2
[ 2.718610] [drm:amdgpu_device_init [amdgpu]] *ERROR* early_init of IP block <vcn_v3_0> failed -19
[ 2.718796] amdgpu 0000:07:00.0: amdgpu: Fatal error during GPU init
[ 2.718798] amdgpu 0000:07:00.0: amdgpu: amdgpu: finishing device.
If error -2 means ENOENT, that would mean the amdgpu
module isn’t finding some firmware files. I would suspect that something is terribly wrong with my config and setting boot.intird.kernelModules = [ "amdgpu" ]
is configuring the wrong kernel instance or something.
The reason I suspect it’s the configuration is because I’m setting a custom instance of pkgs
, adding an overlay for unstable, and setting boot.kernelPackages = pkgs.linuxKernel_latest
The working configuration is in this folder, just a configuration.nix
and hardware.nix
My rewrite is a lot more verbose, with modules, library functions, etc. The most relevant stuff would be in modules/default.nix
here, which sets the kernel packages:
boot = {
# Prefer the latest kernel
kernelPackages = mkDefault pkgs.linuxPackages_latest;
loader = {
efi.canTouchEfiVariables = mkDefault true;
systemd-boot.enable = mkDefault true;
systemd-boot.configurationLimit = mkDefault 10;
lib/hosts.nix
here, which configures the top level nixosSystem
invocation:
vicos,
pkgsDefaults,
mkHost =
name,
system,
configuration,
inherit (vicos.inputs) nixpkgs nixpkgs-unstable home-manager;
pkgs =
import nixpkgs {
inherit system;
overlays = [
(self: super: {
unstable = import nixpkgs-unstable { inherit system; } // pkgsDefaults;
// pkgsDefaults;
nixpkgs.lib.nixosSystem {
modules = [
nixpkgs.nixosModules.readOnlyPkgs
nixpkgs.pkgs = pkgs;
networking.hostName = name;
(import ../modules)
vicos.flake = {
inherit (vicos) lib path inputs;
inherit system;
configuration
] ++ (vicos.lib.walkModules ../modules);
and hosts/thunkbox
here which is the config I’m testing.
Any help would be appreciated, as well as some sources or documentation that would be relevant!
