Applications not finding org.freedesktop.secrets
I am trying to use pass-secret-service as the backend for the libsecret dbus API on my system, and I cannot get this to work. I have this in my /etc/nixos/configuraiton.nix,
  services.dbus.packages = with pkgs; [
    pass-secret-service
And every application I run that tries to call the libsecret API, outputs this error,
The name org.freedesktop.secrets was not provided by any .service files
(Even after a reboot.)
The documentation for the libsecret API seems to be rather sparse, and I cannot find any kind of logging around it to even confirm that the service in the pass-secret-service nixpkg is actually running. Has anyone else had any success with this or a similar setup?
https://github.com/shiftkey/desktop/issues/642
hmmm, bit of arch error, but it’s seems org.freedesktop.secrets is provided by gnome keyring.
A bit of quick guess, but do you have that? gnupg: Gnome3 pinentry fails · Issue #112914 · NixOS/nixpkgs · GitHub
might have some clues, and it says you can debug dbus with
busctl monitor --user
which may or may not help you, but looks like fun.
gnome keyring is only one provider of org.freedesktop.secrets. (I think the original implementation, actually.) Some comments on that ticket mention this.
busctl looks useful, though. Thanks for mentioning that!
The package does not seem to contain any .service files. Maybe you need to start it manually?
Ah, yes, that’s the problem: upstream provides no .service file, and expects the user to run it manually. (Issue #22 on the upstream GitHub project seems relevant.)
How did you get org.freedesktp.secrets to work at the end of the day? I’m new to NixOS and I can’t wrap my head around what needs to be done here
I wrote a NixOS module for pass_secret_service (which is only one of several provider of org.freedesktop.secrets, and added
  services.passSecretService.enable = true;
to my system configuration.
If you want to use a different provider, then I don’t know. Also worth noting that there are some outstanding problems with the spec itself. See xdg-specs/-/issues/75.
Could you post the required configuration options to get it running? I’m banging my head against the wall since nothing seems to work :exploding_head:
# hm.nix
services.pass-secret-service = {
  package = pkgs.libsecret;
That’s looks like a home-manager config, and I never had success with the home-manager module. I think my issue was that dbus units have to be installed at the system level, so I needed to do this in a NixOS module. The configuration option in my previous post should be all you need besides setting up pass itself. pass_secret_service talks to pass, but you need to have it installed and set up already.
Thanks for letting me know!
I personally only needed this to authenticate with Github and I ended up doing it in a different way which circumvents the initial issue with HM:
  1. SSH auth:
Add contents of: ~/.ssh/id_rsa.pub to Github as a SSH key. Generate it with:
$ ssh-keygen -t rsa -C “case@sensitive.email”
Verify if it works:
$ ssh -T git@github.com
  1. GPG signing:
Use “RSA and RSA” with 4096 bits keysize
$ gpg2 --full-generate-key
Add the key to Github as a GPG key from:
$ gpg2 --list-keys case@sensitive.email | grep pub
$ gpg2 --armor --export keyID
Verify if it works:
$ touch test.tmp && gpg2 -sea -r case@sensitive.email test.tmp
  1. .nix:
# $ git config --list
programs.git = {
  userName = "case.sensitive.username";
  userEmail = "case@sensitive.email";
  signing = {
    key = null; # GnuPG decides what signing key to use depending on commit’s author details
    signByDefault = true;
# Daemon to manage secret (private) keys independently from any protocol
programs.gpg.enable = true;
services.gpg-agent = {
  enableSshSupport = true;
  pinentryFlavor = "gtk2"; # Hyprland/Wayland
